Question about Compaq iPAQ MP3800 Multimedia Projector
I have the above projector the blulb has 340 hours it has a flicker, not bad but enough to notice, you can stop it by bumping the projector gently however it returns. It is when it is hot. Can any one assist?
  • 5 more comments
  • yom207 Jan 18, 2008
    Because it can be altered by moving the projector I doubt the coolong exp. Maybe I should explain better it happens when it reaches opreating tempetature, it was not there when I purchased the projector so doubt the heat theroy
    Still no good, have checked all the wires did wriggle tests.Yesterday it went for 2 hours with no concerns however suddenly it started, I tapped the side of the projector it stopped, then started about 5 min later. It is 100% that movement has an impact on the concern however internally I would know where to look. Are the Bulbs in these affected by movement when they are going to fail? Thanks I just don?t want to pay $700 for a bulb and find I still have the same concern
  • yom207 Jan 21, 2008
    History below would someone be able to assist?
    Comment by yom207, posted on Jan 18, 2008
    Maybe you need to improve the cooling system of the projector, because the fan inside mya not enough to cool the system. this also a problem encountered here in our office and we assigned one electric fan to cool the said projector. we try calling the dealer but that is not covered with warranty and costly to replace.
    Comment by melnavz, posted on Jan 18, 2008
    that is not supposed to be happen except when bulbs something wrong however projector produce fliker when the cable connection or the cable had comitted damage or loss connection.You can try fixing that changing cable.
    I already check this and can't see anything.Thanks
  • yom207 Jan 24, 2008
    Please refer to the previous notes
    Continuing the saga above
    I tried removing the dust still no success, it did seem to change it to a more cyclic effect. Next question where in the world can you get cheap bulbs?
    I was a little afraid so did not get too agresssive with the air but I will give it another go. Your assistance is appreciated.
    Sergeant:
  • 226 Answers
Try to check the air flow filter. it might be dusty. try to attach some exhaust near the bulb. you encountered over heat of your projector. Try to consult a cetified technician for repair and to check if some components are burnt. It seems like grounded that overheats the system.
Posted on Jan 24, 2008
  • 871 Answers
Either its a defective bulb or something in the board is not soldered enoght. please refer to the manufacturer for defective item.
  • Compaq Master
  • 1,113 Answers
Well lets put it this way, you will need a bulb one day they are not going to get cheap, so I'd get one to have anyway and use it as a test, but with that said it may in fact turn out not to be the problem still no great loss you needed a bulb anyway.
I'd say though that you should have a good read of
THIS
Cheers Mate ;)
  • 1 more comment
  • Soulvisitor
    Soulvisitor Jan 24, 2008
    DUST IN THE COLOUR WHEEL SENSOR. If you open up your projector as described originally and have the lens facing you, the colour wheel is just to the left where the lamp goes. To clean the sensor, 1st remove the screw holding the small green circuit board. With it detached, you will easily see the sensor, and probably some dust/dirt. remove the offending dust, and wipe it clean. Also, if you spin the colour wheel carefully, you will see a black tape section. Wipe round where this tape is - the sensor picks up the black tape to sync which is used to sync the colours projected by the dlp chip
  • Soulvisitor
    I'm sure that you will find it is dust, did you strip and blow it out with a compressor?
    You could try looking at ebay for discount bulbs.
  • Soulvisitor
    Seems to be a common issue, that thread I asked you to look at is three pages long and quite a few people have found it to be effective solution to problem same as yours.
    Cheers
  • 8,617 Answers
Sounds like a loose conection within the bulb housing. I would check to make sure everything has good contact.
Posted on Jan 21, 2008
    Genius:
  • 1,226 Answers
Posted on Jan 18, 2008
  • Emelio Navaja
    Emelio Navaja Jan 18, 2008
  • Emelio Navaja
    Emelio Navaja Jan 24, 2008
    Its better bring your projector to the nearest repair center for check and let them repair so that you have no risk, if ever has the warranty then you can avail it. if non, look for an option so that you can less cost. thank you very much.
Cannot get image on screen from xbox 360 to mp3800 using hdmi to dvi cables
mp3800 can not got the HDMI source,even if you use the "HDMI TO DVI" cable
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 12, 2014 | Compaq iPAQ MP3800 Multimedia Projector
The fuse directly is broken when the power is on
The 5 leg black plastic chip part is a "VIPer100a" I have one with the same problem, but mine burned up pcb tracks and other parts.
Good luck.
Peter
May 29, 2009 | Compaq iPAQ MP2810 Multimedia Projector
Greenish picture when i play my Compaq Ipaq MP3800 projector
The greenish image is due just by one sof the terminals of the cable. You just need to replace it. Or try anothr RGB cable and look what happen.
Nov 18, 2008 | Televison & Video
System shuts down
Hi labiancad
Were you able to see if all of the fans are working ?
Is there any of the LED's on the Projector flickering and what colour if they are ?
May 28, 2008 | Compaq iPAQ MP2810 Multimedia Projector
Screen Cut off
This sometimes happen when different PC are used on the Projector - sort of confuses it sometimes.
Press the Auto button and it should be ok.
If it still occurs after pressing the Auto button - then your Mainbaord might be faulty.
Mar 19, 2008 | Compaq iPAQ MP1410 Multimedia Projector
Compaq iPAQ Microportable Projector MP1200
you will not be able to find these parts
really...
Good luck
honestly
buy a new projector
Jan 16, 2008 | Compaq iPAQ MP1200 Multimedia Projector
hi all... i have this projector and it boosts up flashes the blue screen and sometimes the projected image too. then goes to standby mode.
I have managed to keep it going enough to see the problem for myself. Here is what i did.. lye the projector on its left side while a cool blower blows through the left side of the lamp housing. fire it up and it will stay on. I went to the menu and did a factory reset as well as lamp hours reset. checked the lamp hours and it was at zero. so its never going to stay on for long for one reason.
As the lamps get older the emit more heat and therefore cause the unit to shutdown. so if you want it to work your going to have to order that lamp. The cheapest i found is from austrailia link off ebay below.
http://cgi.ebay.co.uk/COMPAQ-HP-MP2800-MP2810-MP-2800-MP-2810-Lamp-L1552A_W0QQitemZ280387113761QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item41485fd321&_trksid=p3286.m63.l1177
last link is for the manual found in this forum but not clear on how to get it.
http://h10032.www1.hp.com/ctg/Manual/bpj07855.pdf
Hope you get a good result bulb on order.
AndystUK
vote me happy
Oct 19, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Compaq iPAQ MP3800 Multimedia Projector Logo
303 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Computer Links
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
