Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
Posted on Dec 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phono sockets at the back of the t.v.set(sony kdl 32p3020,I wish to connect a video/dvd machine,using these sockets.
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Dec 06, 2009
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368760
Points
33650
You can download the user manul here, it will show you how to connect the DVD to the TV.
http://tv.manualsonline.com/search.html?q=Sony+BRAVIA+KDL-40S2010+&submit.x=34&submit.y=13
1helpful
Sony Trinitron KV-C29 has no video input ports helps
The BG-1S chassis has a BNC video input socket and a high impedance audio input socket.
It was built in 1999 and I am sure we didn't have digi boxes then.
You have a choice; Purchase a BNC/Phono to whatever socket in in your decoder/dvd thing or purchase a new TV.
2helpful
Sony CCD-TRV438E Hi-8 Analog Camcorder i need driver to connect with my pc
You need to buy a TV card which comes with audio /video composite sockets. these are female RCA or phono sockets which are also found on your camera.TV cards come with their own software to be able to capture pictures from your Hi 8 Camcorder using the av cables like the ones you use from your DVD to your TV set. There are other cards which carry the av sockets and come with video capture software. These cards are usually PCI cards which are fitted into your PCI slot in your PC motherboard. One other software that comes with such a card is Pinnacle Studio. Its called the Pinnacle AV/DV pci capture card. The one I use is just a DC 10 which works with Studios version 8. Please try any of these cards for your video capture
I need to copy,from a video camcorder to dvd,how can I do this.
Depending on what connections you have on your camcorder.
You can use a IEEE 1394 LEAD,or if your camcorder has only Phono connections then you can use those.
There will be the sockets,normally under a flap on the front of the DVD,the phono connections are normally marked AV3.
Hope this helps.
Trying to hookup old dvd/vcr to new flat screen. have cable box hooked up nad working. dvd/vcr no hdmi connections. what cable hookup do I use
You need to use composite inputs. They have three connections, yellow for video, white for left audio and red for right audio. It does not matter which input you go into. I would imagine there are about 7 separate inputs like the ones I described, just remember which one you use because you will have to set the input to that number to see the VCR/DVD later. Get a phono or RCA patch cable and connect the same colors from out on the vcr/dvd box to in on the tv. Turn everything on, set the tv to the proper input using the menu or input selection and you should be able to view video tapes or dvds. Let me know if you need more help.
hardrocko
1helpful
Connecting Bravia to PC using HDMI cable
You did okay but the phono sockets are not for Computer/TV use. Phono sockets should be checked int the manual on why they're there. If you have connected the Bravia to your computer, using the appropriate cable, then you should also purchase or request from the retailer where you purchased the TV a cable that has stereo phono plugs and, you didn't say what size phono sockets they are but I presume they are 3.5 mm. So, if the TV has 3.5 mm sockets, you purchase a cable with stereo 3.5 mm plugs. This is adequate for the stereo wav sound coming from the computer and going into the TV. Remember, having 2 Phono inputs on the TV doesn't mean anything. The TV could have a number of video inputs too, ATD AVT, AV, COMPONENT1, COMPONENT2, HDMI1, HDMI2, HDMI3, etc. each have it's respective sound inputs for AV, S-VIDEO, DVD, Blue-Ray, etc. But for the computer there may be a different type of socket for it's sound inputs, normally it is the old phono sockets. Seek help from the retailer or else you could cook the circuitry of the TV's sound system.
HOOKING UP SONY C450
If the tv has scart sockets you can connect,if not you can use phono lead if there is a phono output connection on the sony.
1helpful
Connecting the dvd player via a scart cable
If you select component in on the tv, this should give you a picture,using the current set up. As for audio, depending on the tv, have you used audio in on the tv, or audio out?
It sound obvious but I (even after 5 years+ of installing tv/vcr/dvd) still get caught out with input and out put.
I am unfamiliar with Sansui dvd, if it has a scart connection on the back then yes you can connect to a spare scart on the tv. If it has the single yellow phono for video and the red/white phonos for sound, you can buy a scart to phono lead and use that, not to confuse with the component(blue/green/purple) connections. You cuold also connect the yellow/red/white phono to the same on the tv front/side or rear if available.
Optical ouput
Sony KDL-40P3020 LCD TV;
Connections:
• 1 x Component Video Connection/s
• 1 x PC D-Sub Connection/s
• 1 x RS232 Connection/s
• 2 x HDMI Connection/s
• 2 x RGB Scart Connection/s
• RCA Phono
• Stereo mini jack
So this Unit has no optical output.
UMC 19in TV with built-in DVD player - model L19/7TCD
Try connecting earphones or headphones to the 3.5mm Headphone socket on the TV and check this works correctly, i.e hear TV when watching TV, hear DVD when watching a DVD etc.
If all is OK, purchase a 3.5mm Jack to L/R Audio/Phono cable. Connect the 3.5mm jack in to the headphone socket on the TV and connect the red/white phone ends to the 5.1 surround system.
It should solve it. SCART out is not always live in all sources so is not a reliable way to connect.
1helpful
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
