Question about Samsung YP-U1 MP3 Player
Crash The unit will only power up to 40% and stop there. It won't turn off at switch. When I try to look at hard drive of unit with pc it locks up the pc also.
Flash it. maybe a new firmware
Posted on Jan 30, 2008
Dban problem ( crash : "dev/sda" )
Use fdisk and / or format from command prompt. Easy and no fuss. gl
Nov 03, 2012 | Computers & Internet
HP Mini 1000 VT won't turn on, lights flash when plugged in
This is a common issue when the unit has been dropped or jarred really hard. The click is more than likely the hard drive trying to read the disk but can not access information.
With that in mind, try this: Remove all USB, SD, or any cards and attachment from you computer. If you have one at hand, connect an external monitor to the pc. Power on. If you get an image on the external monitor, restart pc and press F8, select "Enabel-low-resolution video" and move forward. If you get a picture after this, your video drivers need updating. BUT......
The clicking sound is a major concern because usually the hard drive is the only hardware part that have moving parts. (other than the optical drive or if you have a solid state hard drive.) If you have a dard drive the same size or close with an operating system on it, replace your hard drive with the GOOD drive and retry. If it boots, you need to replace the hard drive. (and hopefully you have a backup of your data)
Worst case, you may need an authorized HP agent to service your pc.
Good Luck
Feb 14, 2012 | HP Mini 1000 VT series PC Notebook
My brother has a presario CQ62 ,without the webcam ,windows 7, 64bit and it crashed on him right before the crash the screen froze up and all it was all scratchy copy of a image like as if it just copyed a...
What happened is that your hard drive has died. The hard drive is the only moving piece of machinery inside a computer besides obviously the fans that can make that type of noise. The best course of action would be to buy a new hard drive, install it, then install Win7 again. Here is a good replacement drive.
Jul 21, 2011 | Compaq Presario CQ62-215DX Laptop
Drive won't spin up
WD drives are very vulnerable to overheating, power surges and streaks. Quite often bad power supply unit combined with power streak is usually enough to fry the spindle driver chip on the electronics and make the data can try to swap PCB from another WD drive of the same model but your chances of success are close to zero. Sorry for the bad news, but your drive is most likely toast. I hope this helps.
Jul 04, 2011 | Western Digital WD Caviar Blue WD6400AAKS...
Pointer is frozen
sounds like your hard drive is getting ready to crash when that starts to happen you see that alot on smaller hard drives 20 to 40 gig and not enough memory installed. the hard drive han only handle so much data. try starting off in sfe mode by hitting your f8 key bunch of times when your pc starts up, then click on safe mode then copy all your important data on to another external drive or disk, then do a full format of your pc.meaning wipe it and install windows same goes with laptop but laptops have a little button on the mouse pad that easily hit by accident to stop your laptop mouse pad
May 25, 2011 | Computers & Internet
I can try to turn my HP laptop on 50 times...not even a fan is audible and then it might turn on... is this a bad motherboard? It had its first hard drive crash after on owning it 2 months...can you help...
The first thing I would be testing is the power supply as you sound as if you are having power issues.
You can acquire cheap power supplies on ebay for around $30-$40 but this will of cause depend on how much you have paid for the PC and how much you can afford to spend to fix it.
Hope this helps.
If you have any further questions please let me know.
Nov 23, 2010 | Computers & Internet
Hi, I have bought this dell vostro 1015 laptop one and half year ago. Day before yesterday my windows XP hanged and I was unable to shut down. So I pressed power on button for few seconds to switch off...
It sounds like your hard drive has gone bad. As this is a laptop you can try to reseat the hard drive, if that does not help then it might be a case of hard drive crash.
Oct 29, 2010 | Dell Vostro 1510 Laptop
The hard drive crash I can get the recover up but it will not reformat the hard drive it has a lot of bad sector. have new hard drive have windows disk, try loading windows install driver for SATA drive,...
Try copying the driver files (install and otherwise) to a USB flash stick. Put it into a usb port, turn computer on. You should then be able to access the files throughout the installation.
Jun 29, 2010 | Gateway MX6912 Notebook
Toshiba 160 GB usb hard drive, has clicking sound when powered up. Computer(s) don't react to unit when plugged in. Power light only indication unit is plugged in.. Suspect drive head stuck in protected...
Clicking sound is the motor trying to move the head. Unplug it and try gently tapping it from the side, it seem to help time to time with some drives. If that doesn't work, put it in a zip-lock bag and freeze it for 40 minutes and try again. If still doesn't come up, you're out of luck.
May 31, 2010 | Toshiba 160GB USB 2.0 Portable External...
Hard Drive Crash
then it would be total bad can u try to install it on other comp as a slave drive to get in it to pull info out if they total die there sno way unless you fbi to get info off k
Oct 07, 2008 | Western Digital Protege WD400EB 40 GB Hard...
Samsung YP-U1 MP3 Player Logo
44 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
