Hopefully you don't have a TRE (timing ****** eliminator) on it, if you do take it off, removing it ill make it easier to hold a smooth rpm especially in a turn. Also, the first generation power commander is ****. You can take it off that bike and most likely get the same results on the dyno. Those bikes self adjust whether you put a slip on or full system it and the first generation power commanders were still experimental. I've taken one off of a problematic race bike and personally had better results and faster lap times. I used to road race, now just do track days. I've always owned gixxers and still have 2.
there is but it does it at vertical when holding set throttle for noise testing
Is there a cut off switch the kills the engine if you fall over? Might be defective.
