Brother mfc 4800
My printer keeps saying that there is a paper jam and there is no paper jam. I keep turning off and on my machine and nothing happens. It won't print.
What can I do, I need to use it.
  • Anonymous Oct 23, 2008
    I have the same problem
    We tried to clean the ribbon part. Clean the area where ribbon goes but still it does not work.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 14 Answers
At the back you can open a door check for paper stuck in the fuser, or check if in the paper tray your paper go up some time there is a part in the cassette that break so your paper dont lift to the feed roller.
Posted on Jan 18, 2008
    Genius:
  • 1,003 Answers
TRY UNPLUGGING IT FROM THE WALL 12 SEC AND PLUG IT BACK UP
6ya staff
SOURCE:
I have a MFC brother printer 8460n it keeps saying paper jam but done all the normal things nothing is jammed
SOUNDS LIKE PAPER FEED NOT FEEDING, CLEAN PICK UP WHEELS WITH WINDEX A SEE IF IT WILL PULL A PAPER THROUGH. IF IT DOES, NEW PAPER, CLEAN WHEELS OR REPLACE.
Jun 27, 2018 | Brother Office Equipment & Supplies
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
My brother mfc 465cn keeps saying paper jam. I do
The paper sensor is either stuck or dirty.
Just open it and follow the paper path and you should see where it is.
Otherwise, the sensor may be bad.
Apr 18, 2010 | Brother MFC-465CN InkJet Printer
My brother mfc-230c keeps saying "paper jam" and there is no paper jammed in the printer
this is an error that could get stuck in the memory, try removing the paper tray then unplugging and replugging the printer then when it's warmed up replace the tray.
if problem persists you may have a broken sensor
Sep 27, 2009 | Brother MFC-230c Printer
My fax machine keeps saying there is a paper jam.
look on the bottom of your drum unit. there is a sensor opening that might have a tiny piece of paper in it, not allowing the sensor flag to reset. if thats not it, closely inspect behind rear door.
hth,
razors
Apr 05, 2009 | Brother MFC 8500 All-In-One Laser Printer
My Brother Multi-Function Center MFC-240C All-in-0ne Paper Jammed
how i can i plug mymulti-function center mfc model mfc240c to my pc
Dec 08, 2008 | Brother Multi-Function Center MFC-240C...
I have a brother MFC 8440
Have you checked the back paper door?, the paper tray?, and the drum/toner unit? If a paper was torn out of the machine, you may not be able to see the piece that is still triggering the jam signal. You can also pull down the paper guide around the orange fuser roller through the back door by pulling it gently to the left.
Sep 11, 2008 | Brother MFC-8440 All-In-One Laser Printer
Mfc240 all in brother printer
i need the install utilities cd to program my mfc-240 machine
Sep 06, 2008 | Brother Multi-Function Center MFC-240C...
Paper jam
push menu then start mono (b/W) then 4x arrow-up button. maintenance should be displayed. What error code does the machine give to you?
Sep 11, 2007 | Brother MFC-410CN All-In-One InkJet...
273 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
