tv doesn't give option in menu to program channels. the only options in the menu are for cc or sleep timer.tv doesn't give option in menu to program channels. the only options in the menu are for cc or sleep timer.
THE FEATURES MENU ONLY GIVES ME 3 OPTIONS CC,SLEEPTIMER AND EXIT HOW DO I AUTOPROGRAM IN THE REST OF THE CHANNELS?THE FEATURES MENU ONLY GIVES ME 3 OPTIONS CC,SLEEPTIMER AND EXIT HOW DO I AUTOPROGRAM IN THE REST OF THE CHANNELS?
You can't post conmments that contain an email address.
Have you went through your menu options to see if it has a SLEEP TIMER set up? Your SLEEP TIMER may be on. If it is then it will automatically shut down when specified.
Hi if you are using a universal remote control that will be the cause, if not the tv has a problem with the system control IC this IC is responsible all the signal being transmitted to the unit solving this fault must be check and test in actual by a well experienced technician I suggest that you should contact a service technician to do it for you and save you from stress. Or replace the battery of your remote if no changes you really have to contact a tech. good day and best regards.
Which timer do you want to use? To use the On/Off Timer, press Menu and use the navigation arrows to select Time. Press Enter and navigate (up/down arrows) to select either On Time or Off Time. Press Enter and then use the up/dwon arrows to select Repeat. Select the frequency for the timer function (off, once, everyday etc.) with the left/right arrows. Use both the up/down and left/right arrows to set the time (hour or minute). Press Return to return to the previous menu and Menu to leave the OSD menus. For the On Time, you can also select the input source that will be shown when the TV comes on. (Select Input similarly to the above directions and set the desired channel if the source is TV.) The time must be for this to work (select Time and then Clock then Auto (gets the time from a digital channel) or Manual) and the TV must be in Standby mode for the On Timer to work. The TV will go into standby in two hours after coming on unless a button is pressed on the remote or the TV. The Off timer will override the TV On if they are set for the same time.
The Sleep timer is set in the same Time area or in the Q.menu (from the remote). Select Sleep time and then the length of time you want the tv to stay on before going to sleep. This is reset when the TV goes off.
The Shut-off time is set in the Time menu as well; select Auto Sleep. When this is on (on/off options), the TV will shut off after 10 minutes without a signal.
I hope this helps.
Cindy Wells (you will have to reset the timer after a power failure)
Go in ur tv menu go to SETUP.Check for Sleep timer might be on.This timer have setting like 30 60 120 mins.Turn off the sleep timer tv well not auto shut off.Check ur remote control might have a button said sleep.
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
I need to add channel 66 to this tv and it only goes to channel 60.- the remote or the tv.?. if remote doit mannuly on the tv. if tv. .............................
