Question about Brother MFC 6800 All-In-One Laser Printer
No power when plugged in
One day it just quit running. No power at all- tried different plug ins and cords- still no power
  • 11 Answers
This sounds like a failed power supply. Most Brother units don't just blow a fuse they usually blow components on the power supply and need to be replaced completely. Sorry for the "Good News".
Posted on Jan 19, 2008
Electric chain saw wont run
Did you try plugging it into a different plug ? Did you by chance cut your electrical cord? Was it plugged into a GFI receptacle? Might have to reset it or maybe blew a circuit breaker.
Feb 16, 2017 | Electric Garden
With unit plugged in, the control lights, and fans go off and will sometimes go back on when unplugged for several min. the plugged back in. Sometimes it will cool and run for 2 days then quit again.
Sounds like a bad relay, ground or power cord. But try this, write down your model number and go to See the trouble shooting section, enter your model number to get model specific advice to the problems with your appliance. Good luck.,
Jul 07, 2015 | Refrigerators
When i turn on my xbox i'm getting 3 flashing red lights what does this mean
it means your xbox is overheating, you can send it back as they extended the warranty on it for this common fault unless you have modified it, in which case look up ring of death on youtube.
Jun 13, 2011 | Microsoft Xbox 360 Elite Console - Black
We had 52' HD JVC Tv for 2yrs and the other day, the power button was flashing and didn't have a picture and now it won't even turn on. We tried unplugging it for a while and still nothing
This can be a power problem it can be a power problem inseide the tv or a power distribution problem from your power outlets. So before you send this to a repair shop you can try to plug the tv to a different outlet by using an extension cord. I understand that you have tried to unplug the tv for several minutes but plugging the tv to a different plug in can make a difference.
Sep 09, 2010 | Televison & Video
HP Compaq plugged in & blue light on but icon says NOT plugged in
Check power out put of the adapter is it giving you the correct readings
Try to remove the battery and run it from adapter itself check to see if its working
Reset the battery removing it from the system
Nov 10, 2008 | Compaq Presario Notebook
8600 scanner won't power up
Pls check the power adapter. If you have a multimeter, pls check the output voltage of the power adapter.  S. Mohan
Sep 23, 2008 | Visioneer OneTouch 8600 Flatbed Scanner
My PC won't power on.
First, check all connections insid the computer. then,depending on your skill level and warranty status, you can try the following:
Remove or disconnect all accessories from the pc (Hard drive, floppy, cd/dvd roms and accessory cards) Then see if it will turn on. If yes, the replace the items one by one unrtil it fails.
If no, then you must either try a different (known good) power supply on your motherboard. (you can also see if your power supply powers a known good motherboard).
If not, the you motherboard is likey faulty.
Jun 02, 2008 | E-Machines T3985 PC Desktop
Power cords
You will constantly draw power from the outlet. Though it may not be as much draw as if you were running a device on it. Try picking up the AC adapter one day when not plugged in to the laptop. It still gets hot.
On another note,
When using AC power you should ALWAYS plug it into the back of the device before plugging it into the wall outlet to avoid excessive power surge.
Apr 17, 2008 | Televison & Video
Facing No lights at all on router.
How long ago was it purchased? No lights at all would certainly seem to be a power cord issue. There's a possibility there may have been a surge that fried out the router, or the power cord may not be putting out the correct (or any) voltage anymore, but to check that you'd need a voltmeter. Have you tried plugging it into a different outlet to see if that makes a difference?
Sep 16, 2007 | Netopia 3346N-VGx Router (3346NVGX)
Brother MFC 6800 All-In-One Laser Printer Logo
462 people viewed this question
James Cagle
James Cagle
Jim Keysor
