Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi vs 45607
Works fine and then just shuts down and won't come back on for a while. Last time it shut down I did the diagnostic test and it gave me a code of 2 4 what causes this and is it something I can repair myself? I have copier/digital printer/fax tech background.
  • Float Feb 10, 2008
    Our Mitsubishi Big Screen Model No.VS-45607 had no problems until we moved to a new house and had it reinstalled with Comcast. Now it will shut down in the middle of a movie. Sometimes it will play for several days with no problems and then all of a sudden it will shut itself off and we cannot get it back on for an hour or so. Had a technician come out and he said it would have to be taken into his shop and the repair would be $465.00. Can you give us some help on this problem? Since it plays for many days without problems, we think it must be something that can be repaired at home.
  • Float May 11, 2010
    Since I cannot solder, is there another solution that I could use? Maybe I could just contact a t.v. repairman and see if he can make the repair.
  • Mitsubishi Master
  • 8,617 Answers
Code 24 for mitsubishi means Veritcle deflection failure. Its an easy fix if you can solder , however you will need the service manual to diagnose which component in the verticle circuit is faulty. You can get the manual and unlimited support at the following link for 10.99, and if you want them to email it to you they will. After purchase just go back to the site and click on the contact us link and provide your email, they will also email instructions on how to obtain your support. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jan 18, 2008
Mitsubishi VS-45607 turns off immediately when I try to power up
STK ICS replace Both of them STK393-570 big black ICs will have STK on them Call mats for parts 1-800-628-1118
Dec 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607
there is a protection circut that will shut down the tv when it detects a failure in one of the components , when components heat up to much they go into thermal breakdown, the part that is heating up and failing is getting worse , so it will need to be test to determine which one
Oct 09, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-4541
clean it out it is over heating, use a air hose to blow all the dust out
Sep 01, 2008 | Mitsubishi VS-45607 45" Rear Projection...
VS-45607 Rear Projection Television
Resoldered connector DY on the yokes and check caps C411, 2200uf/35v and C412, 10uf/50v on main pc board.
Bill
May 04, 2008 | Mitsubishi VS-45607 45" Rear Projection...
TV keeps shutting off
Push the menu and inputs buttons on the set in both together and hold for 8 seconds this should make the led flash a two digit code. Let me know what happens after doing this test.
Apr 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Power shut down
go to the following link and leave an email indicating your problem. They have new and rebuilt boards and if you order one of their boards they are quaranteed and they include complete installation instructions. Just click on the "contact us" link in the info section on the left side and leave a detailed email with model number and what you are needing, They get back quickly with a response
Apr 02, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi Big Screen VS-45607
probaly bad wiring or shorts in the wires or something is intefearing with your tv if it is wiring it might be a fire hazard
Feb 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607
Do self test first goto www.ctechnicians.com
Dec 08, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
100 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
