Error Fix When scanning Registry, the window will show 52 entries have been found. The programme continues to run, but then ceases to show any more entries & the Total Progress remains stationary @ about 20 % of the bar. I allowed my computer to operate for over one hour & there was no change. I tried to ‘Abort’ but the ‘Abort’ failed to operate. Eventually, I closed the programme thru the ‘X’ in top right corner of window. Please help me?
Hi there, I don't recommend that you using free tools to fix your computer problems because most of them not really find the critical problem, they more destroy then fix this. because they don't guarantee this problem will fixed that why.
What you can do this give try for free trial of some the top registry cleaners in the market.
there quality proven works registry cleaners, that you can give them try free trial and see how this really fix you errors computer.
Best,
John
You can always close your application in the task manager, simply right click next to the the tray icons, select Task Manager and then choose the program or process you want to close :O) (all programs has at least one process).
What kind of cleaner do you use ?? Take care with these registry cleaners they can make a mess :oO. Read my article here, this is a reliable registry cleaner :
http://www.fixya.com/support/r3581476-how_to_use_ccleaner_to_keep_your_compute
Have a nice time over there
Let me know :O)
Getting the erdmpg-6.dll error pretty much indicates there is something wrong with the erdmpg-6.dll file, either it is absent from the computer or is damaged (corrupted), if so, the system will unable to read or access to the file when needed. When you encounter the error, first reboot your computer once, if the error persist, you can try to download the erdmpg-6.dll file from the internet, or get a healthy copy from another computer, and then replace the file in the suitable area in the computer.
Secondly, you can try to reinstall the program/application that trigger the error tofix erdmpg-6.dll error. but remember not to reinstall it until you uninstall the current installed one, to uninstall a program, go to Start > Control Panel, click onAdd/Remove program option and use it to do the removal.
Most of the time, registry problem is responsible to the erdmpg-6.dll error. Windows registry is part of the system, it is much important than any other system components, all the software & hardware data are stored in the registry. The erdmpg-6.dll error usually happen when the Windows registry gone corrupted or the related entries inside is damaged. To test if the registry of your computer is having problems, you can perform the steps below:
If you are experienced enough, you can open the registry editor, find out all the unnecessary or wasted entries inside, and delete them all, then modify the problematic key value to the proper status. Before any modification, we suggest you to backup the registry first to avoid crucial problems caused by mistaken operation.
Registry modification is kind of a complicated task for average computer users since there are thousands of registry entries, it is hard to spot out and clean every wasted one, no mention to modify the incorrect entry value, it can be dangerous if the value is modified improperly, your computer may end up crash, even registry backup can't save it. Fortunately you can use registry tool to help you out, simply follow the below three steps, you will be able to fix the registry as well as fix erdmpg-6.dll error automatically:
Step1: Free download erdmpg-6.dll error fix tool, and then install it in your computer.
Step2: Click Start Scan Now button to scan over your computer for existing problems and errors.
Step3: Click Fix All button to completely fix erdmpg-6.dll error.
you did not say which program you are using to scan your Registry. There are several versions which are free which are in themselves spyware. I need to know the program you are using.
