Question about GE 27GT271 TV
DVD player to 27GT623 Television
I have a DVD player I would like to plug into the TV. There are white, red and yellow outlets in the back of the TV and everything is connected. However I don't know how to find an AUX channel on the TV or where the DVD channel would be. Any ideas?
  • pattonsmail Jan 19, 2008
    Unfortunately we do not have the original remote. I have been all
    up and down the channels and can't find an AUX channel. It goes
    from 01 to 125. I've tried to find the channel in the setup mode,
    but no luck there either. Any other ideas? Is there any way
    to change the input without the remote?
    Problem Solver:
  • 5 Answers
Just press the AV / Tv button from the remote control or press the channel up or down until it reaches the input mode next to the last channel slot.
Posted on Jan 19, 2008
  • Marcis Jan 19, 2008
    all you can do is to use an RF modulator, it converts the audio and video signal into Radio Frequency and feed it into the antenna terminal of your tv then set the tv to channel 13
I have the 3 RCA red, yellow, white cables on back of dvd and to tv. Video only plays when I select video 1 under the input. When when I select video 3 only sound and no video. What else can I try?
Sounds like from the symptoms that you have plugged the white and red cables into AV3 input on the back of the Teleivsion and plugged the yellow cable into AV1 on the back of the Television.
Check the cables are all plugged into AV1 input ports on the back of the Television. Red and White go into the Audio inputs and Yellow goes in the video input. Also make sure you have not plugged cables into component inputs on television look for AV1 in on back of Television .
Mar 08, 2015 | RCA Televison & Video
How to hook dvd player to tv
The dvd player should have come with three cables. A yellow red and white one, or 5 cables, a blue a green an orange a white and a red. on the back of your dvd player and the back of your television there should be holes with these same colors. Plug these cables into the corresponding holes on both the tv and dvd player.
Feb 03, 2011 | Video Game Consoles & Games
Dvd screen comes up on TV but dvd player says "disc error".
unplug the pwr cord from dvd for 5-10 min..plug back into outlet..make sure the av cable is connected white-white yellow-yellow red-red...now press play on the dvd
feel free to rate help
Jul 04, 2010 | Toshiba SD-2800 DVD Player
Can't get the DVD player to play on new TV
turn dvd off ,unplug cables, turn dvd on, plug cables back in
Mar 11, 2009 | Proscan 32LA30Q Television
Plug into Tv?
In your accessories kit that came with your DVD, you should find a cable with a red ,yellow and white RCA ends. at the other end is a 1/8 inch Tip /ring/sleeve plug. Insert the plug into the output of the DVD. Insert the yellow wire to the same color coded INPUT of your television, insert the red and white wires to the Audio input on you TV. Your DVD should be sending the signal directly to your TV. hope this helps . if it does , vote.
Dec 22, 2008 | Mintek MDP-1760 Portable DVD Player
Hooking up a d.v.d player to a vcr/tv combo?
RCA plugs (the yellow, red, and white outlets you speak of) consist of a video plug (yellow) and stereo plugs for audio (red and white). Just match the colors from the DVD RCA colors to the RCA hook-ups on the TV (ex. Yellow the Yellow, White to White).
You don't need to worry about the red one, it just makes the DVD player play stereo audio. Instead, you'll have mono, which is fine, and most modern players can detect mono and switch it for you so don't worry about changing settings and what not (unless you're missing sound on one side.)
Sep 13, 2008 | Optical Coating Model 108 VHS VCR
Trying to Install
Do you have the red, white and yellow hookups on the back of your TV????? If you don't then you need to get an RF Modulator. You can buy one at Walmart. Older TVs don't have the red, white and yellow hookups. You hook up the RF modulator with a short cable to the cable outlet on your TV. Then you plug in your DVD player to the RF modulator. You also plug your cable for the TV into the RF modulator. It really is very simple. Directions are included with the RF modulator. You will need a short piece of cable also.
Feb 04, 2008 | Panasonic DVD-RV41 DVD Player
Having problems connecting dvd vcr combo to tv
Hey Pat. Red Yellow White Plugs into back of MVD4544. Red Yellow and white plugs into back of TV. If you have an older TV that has only coax cable outlet, go to Radio Shack or Best Buy and get an RF Modulator. You may need to get another set of Red Yellow White Plugs if you have a cable box. The front connections are Video 2, if placed on the back they are Video 1. When you first turn the DVD/VCR player on, be sure to select the appropriate setting. If you figure out how to timer record on this please let me know. No where in the 52 page book is there any info and their website is a joke. Good Luck.
Sep 14, 2007 | Televison & Video
GE 27GT271 TV Logo
178 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
