Question about Logitech Z-560 Computer Speakers
Where can I purchase...
I think that I have a shortage in the male piece stemming from the control tower that plugs into the computer/ipod/tv etc(the green head). The sound either comes out of 3 speakers or none. The sub is fine. When I jiggle and torgue the coil next to the green head I occasionally get to enjoy surround sound. I've thought of cutting the piece off, going to radioshack, finding a replacement, and reattaching it. Or openning the tower and replacing the wiring. some feedback would be great. How much would that tower cost alone?
thanx J
    An expert who has answered 500 questions.
  • 620 Answers
I think is better to get your equipment, to repair shop and see to fix the input for the sound, it is better, or buy a new board, it is cheap, you may found, on 140.00 less ASUS or SOYO brands,
good luck
Posted on Jan 19, 2008
How do I connect my Lenco IPOD/IPhone Tower 1 docking station to my LG LeD tv to play tv audio through the tower speaker insteat of the tv speaker?
If your TV has RCA (L/R) audio outputs, buy a 3.5 mm Male to 2-Male RCA Adapter cable to hook up your TV to the 3.5 mm AUX IN jack on your docking station.
Dec 27, 2014 | LG Audio Players & Recorders
FCan get my Ipod to play through my Roland TD-20 Mudule
You need to get yourself a cable - with a 3.5mm male jack plug on one end (which will fit into your ipod), and a 1/4 inch male jack plug on the other end.
(you could use a lead with a 3.5mm male plug on each end, and used a 3.5mm female to 1/4 inch male adaptor to achieve this)
Connect the 3.5mm end into the ipod - play a track, with the volume at say, 75%.
Connect the 1/4 inch end of the cable to the 'Mix In' input in the back of your TD20.
Use the 'Mix In' control - at the top right hand side of your TD-20 module to control the volume.
If you wish only to have the iPod going to (for example) headphones - and not Front Of House (PA) speakers - which you will have connected via the Master and / or Direct Out(s); this can be achieved in the 'Mixer' settings (accessed via pressing the 'Mixer' button).
Oct 22, 2012 | Roland TD-20X V-Drum Sound Modul
Install external monitor from desktop to laptop
If your laptop does not have the 15 pin plug (VGA Port) then you will need to get some type of adapter that will make the monitor work. You probably have a DVI monitor.
You just need to make sure you get the correct type of adapter and make sure the ends that plug into the computer are correct such as male or female. For example think of the human male and female body parts when you look at adapters. The vga port on the computer is called a Female port, but the piece that plugs into it is called Male. It's the same with DVI ports.
I think you need a VGA Male to a DVI Female so below is a link to one and for $2.54 from Cable Wholesale.
Below is a picture of what it looks like.
Jun 03, 2012 | Dell Computers & Internet
While driving my ford taurus bogs down and does not want to accelerate
Hi well if this is happening most likely you have a fuel shortage this maybe caused by a carburetor being out of tune, or indeed it maybe dirty, points and/or spark plugs, bad sparkplug leads, or even a faulting Coil, but I doubt that it is anything to serious? In any event I think that a good tune up will most likely fix your problem. If you can do it yourself, then give the motor a FULL tune up, replace/clean the leads, points. plugs, adjust the carburetor's mixture etc. etc. Check the Fuel filter, get yourself a workshop manual, this will show you what and how to do it if you are to DIY. If NOT then simply take it in to a reputable mechanic and ask them for a "Tune Up", explain what's what, I know this may sound sexist, but anyway, if you are a lady, please take a male friend etc, with you, or indeed to take care of it all, for you, as i have found that sometimes ladies get "Taken advantage of" from time to time, having a male seems to lessen this risk, especially if the male is a car buff etc.
Oct 18, 2011 | 2004 Ford Taurus
I just got the logitech z323 speakers for my computer and i wanted to see if i could hook them up to my sony flat screen. i was wondering if there is a way to do that and if so how?
Logitech speakers connect with a cable that fits into something like an iPod or computer (Usually with a green tip). If your TV uses the usual 3 connectors (White Red and Yellow) you can go to the store (Best Buy, Wal-Mart, Online, etc.) and purchase a converter that will convert the Red White and Yellow cables to the Green cable. These are cheap and involve no electronics, but make sure that you buy one that has a male to female connection (will plug IN to your TV and has an opening to plug the green cable into)
Mar 14, 2011 | Logitech Z323 2 Speakers
Dell lime green subwoofer cable 5G068 for an older Dell Dimension deck top tower. I lost it when moving and need a replacment
all you need to do is run over to radio shack or best buy, and purchase a 3.5mm to 3.5mm male to male cable, about 6-10 feet should be plenty
Jan 24, 2010 | Dell HK395 Computer Speakers
I have a male ipod connector in my car to attach an ipod to. I do not have an ipod but would like to be able to connect a standard mp3 player to this connect point via a jack plug. Please can you advise if...
If your Sony has female RCA Aux inputs, then you can use that going headphone out of MP3 player to the RCA inputs. You won't be able to view or controll any other player from the head unit except an iPod.
Larry T
Winona Lake, IN
Jan 24, 2009 | Sony CDX-M730 CD Player
No sound from speakers
If you buy a 1/8 - 1/8 male on each end of cord and plug it into your stereo headset plug on your computer (probably the front of tower) and the other end to the analog in on the back of your ba735 will work great....... Good Luck,
Mar 20, 2008 | Boston Acoustics BA735 Computer Speakers
I see no way to plug my ipod into my coby mp37
I think the input is right under one of the legs that swings the cover open. I just looked at mine but can't try it until I get a cord for it. Let me know if that works.
Sep 12, 2007 | Coby CS-MP37 Computer Speakers
Hi, Did you install the sound driver in your new computer? That is the first issue you should try. If the little speaker appearr at the lower right of the screen then the spearkers should be ready to go.
Oct 09, 2006 | Boston Acoustics BA735 Computer Speakers
Logitech Z-560 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
