Question about Onkyo TX-SR605 Receiver
Onkyo 605 HDMI Sound
I recently purchased the Onkyo 605. I do not have any remote speakers connected yet. I connected the HDMI output to my the HDMI input on my monitor and there is no sound. I bypassed the Onkyo 605 and connected the cable directly to the Dish HDMI output and ther is sound.
Please help.
  • 2 more comments
  • ScottHopper Jan 29, 2008
    Thanks. It worked.
  • phsinnaeve Jan 03, 2009
    same pblm with Onkyo 605 and HDMI from portavle computer... no sound
  • Anonymous Mar 13, 2014
    no video from HDMI connection from tv to onkyo
  • Anonymous Mar 15, 2014
    Onkyo 626, sound goes off & on then eventually picture comes on HDMI SET UP.
Change the setup in the Hardware control/HDMI/ HDMI Audio...
Posted on Jan 26, 2008
Ps3 doesnt give out a surround sound output
Hi
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
Ajin
May 21, 2012 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
No audio sound from HDMI connection from TV to Onkyo 606 amp.
you have the output of the receiver going to the input of the TV?
i believe that you should be running the TV output to the receiver input to get your sound from the TV to the receiver and thus speakers.
the easiest setup is to just run your cable box and DVD player HDMI's into your TV inputs. then run another HDMI from the TV output to the receiver input.
Feb 28, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 getting no sound from HDMI sources on speakers. I have a motorola cable box and a panasonic DMP BD-35K blueray player both attached to the SR606 via HDMI cables (HDMI3 and 1 respectively)...
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
HELP: Onyo Remote Does Not Recognize Receiver when using Cable
Since you have the cable connected to the reciever thru the HDMI, you may have accidently changed the input source of the reciever from HDMI or digital to analog.
When you have the reciever set to listen to the cable, check the input mode and make sure it is set to use the HDMI or digital input and not the analog.
The rca jacks are analog, and they worked, so I think you have just solved your own problem without realizing it.
Let me know if this works and if so a good rating would be appreciated. Thanks and have a great day
Jun 16, 2008 | Audio Players & Recorders
Onkyo 875 suboofer problem
Is the subwoofer got a power? If not then troubleshoot the input power maybe fuse damage.
if there is power, EXamine the connection from the woofer to the output of the source. check the jacket of the of termination.
Apr 22, 2008 | Onkyo TX-SR605 Receiver
Onkyo 875 - No sound
YOU ARE PROBABLY USING 5 SPEAKERS WITH OR WITHOUT A SUB, AND YOU CONNECTED THE REAR SPEAKERS TO THE REAR SPEAKER OUTPUTS. THEY WON'T WORK THIS WAY. RECONNECT THE REARS TO THE SURROUND SOUND SIDE SPEAKERS, AND RERUN THE AUDISY SETUP. THIS SHOULD TAKE CARE OF THE PROBLEM. YOU HAVE TO FOLLOW THE DIRECTIONS AND SET UP THE DVD INPUT, IT WON'T WORK RIGHT OUT OF THE BOX, TOO MANY VARIABLES.
JACK
I CAN'T GET MY 875 TO RECOGNIZE COMPONENT VIDEO SIGNALS, I GUESS I'M STUCK USING HDMI, AND COMPOSIT INPUTS.
Feb 25, 2008 | Audio Players & Recorders
Sound won't play thru stereo from t.v.
take the main tv digital opti outto sterio ok on ch or from dish box to sterio on a ch
Feb 02, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 conected to Mitsubishi DLP TV
What I think I did and how I fixed it!
FACTORY RESET ON EVERYTHING!
All you have to do is to do a factory reset on everything, but I thing mostly on your 605, but I would do it on the TV as well. I think what had happened is after I set everything up for the first time, it worked great. As the days when on I started to play with all of the futures the 605 and the TV had to offer. I was turning them on and off to see what everything did. What I think I did was, I turned on something in the 605 that the TV did not know how to cope with. If I had to guess, I think it is the Lip-sink feature (Spelling?) in the 605.
Anyway disconnect everything, look in your manuals of the TV and the 605 to see how to do the factory reset on both. Then turn your TV on. After it does it’s start up for the first time (again), start connecting the 605.
It has been working great for me after I did this. Do not count on help from the people you bought it from or the people who made it. This stuff is so new they do not really know how to fix it.
Robert…
Jan 04, 2008 | Onkyo TX-SR605 Receiver
Onkyo 605 Reciever no sound from zone 2 RCAs
did the AS amp ever work properly from the RCA's?
Dec 05, 2007 | Onkyo TX-NR801 Receiver
Onkyo TX-SR605 Receiver Logo
909 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
