Question about HP LaserJet 5si Printer
LaserJet 5Si printing slow use to be able to hit the print key then the printer would fire away. seems like the printer pauses between pages then prints maybe 3 to 4 pages per minute
Could be software. I have seen the last several Adobe latest version documents take several seconds to print. I have also seen increased print times with MS office 2003 Powerpoint documents.If it is a single page MS Word or Excel document and u are printing several copies of it, you should turn off the collate feature for printing of that document
Posted on Feb 17, 2010
Slow printing
Slow printing I have a Laserjet 4200
Jun 26, 2013 | HP LaserJet 4200 Printer
SLOW COPY SPEED
Sir/Madam
I Think It's a hardware Problem,Beside That You Need Some Help,Then Visit
Slow Printing HP Support Other wise Follow Us For
HP Printer Support
Nov 07, 2012 | HEWLETT-PACKARD Hewlett Packard...
Our HP Laserjet P4015N printer prints slow. It prints, stop, prints, stop and so on. It is working from a print server (Windows 2003) and we have update the driver. It might work for a day, but then it...
If it is a local issue to your printer it is likely that the fuser temperature is set to low. If the fuser temp is set low then it will pause printing in order to maintain a whatever temp it is set at. If you web out to your printer(type in the ip address of your printer) you will find the menu for the printer. Somewhere in there will be the option to increase or decrease the fuser temp. Sometimes it is as obvious as FuserTemp;Higher, HIgh, Normal, Low, Lower. Other times like on the cp2025 color laser i have it is under the extended print modes option, and it is under fusing with the options of; less fusing (-2), less fusing (-1), normal, more fusing(+1), more fusing (+2). however the option is presented on your printer you will want to increase the fuser temp. do it incrementally and see what works best from you. If this does not solve the problem there may be a problem with the spooler dropping packets from your print server. Hope this helps.
Jun 09, 2011 | HP LaserJet P4015N Printer
HP 5Si printer, multiple images on one sheet HP 5Si, Windows XP, Networked Jetdirect card, 20MB memory, duplex option. Unit worked fine before. Power outage occurred, seemed to have knocked out the...
If this is a "ghost" image like whats on the top of the page is re-appearing on the middle and/or bottom. The fuser is defective and needs to be replaced. Part # RG5-4447
Jan 03, 2011 | HP LaserJet 5si Printer
Hp laserjet p3015 pausing after 5 or so pages whilst printing large amounts, the printer prints 5 pages then has a pause before starting printing again, this can can make printing very slow i've...
I have seen this problem before. Basically what is happening is the fuser is losing it's heat. When the printer pauses it is waiting for the fuser to get back up to temperature. The first course of action would be to reinstall the print drivers. This will rule out the communication aspect. Then to replace the Fusing assembly (fuser) and if that doesn't work to replace the Power supply.
If it is the power supply it wouldn't be worth the time or money to repair the printer based on the original cost of the machine.
Aug 16, 2010 | HP Office Equipment & Supplies
HP Color LaserJet 2550N. Slow printing takes 16
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Jun 30, 2009 | HP LaserJet 2550n Printer
Slow Printing
You need to change the pickup roller. The rubber dries out and it is not able to pick up the paper quickly. I had this problem with our printer at work. We changed the rollers and its printing like new again.
Apr 24, 2009 | HP LaserJet P3005n Printer
Printer Pauses every few pages, seems to print slower than it shouls
More likely to be Network print spooler issue, check settings on driver.
Nov 09, 2007 | HP LaserJet 4100n Printer
Hp LaserJet 5 si
Check the print processor settings in the advanced tab of the printer properties. This should be set to Winprint, and not anything else.
May 01, 2007 | HP LaserJet 5si Printer
HP LaserJet 5si Printer Logo
315 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
