Check the CPU fan it may not be spinning at the full speed or not turning at all. Check that there is not cable that is obstructing the fan blades. When the CPU over heats the machine will shutdown to save it from any damage. Then other thing to check is the power switch make sure that it is not sticky or stuck in. It also could be a memory issue but normally there will be a blue screen fault and audio beeps when you first switch on.
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP...
(More)
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP scanning software, but I have not been able to install the scanner so that it works with the Vistascan software. I much prefer Vistascan as it is much more user friendly & offers more flexibility. Any help would be appreciated.
how do i make adjustments to the dclcd s1702d monitor. the screen is completely light green. i get...
(More)
HOW DO I MAKE ADJUSTMENTS TO THE DCLCD S1702D MONITOR. THE SCREEN IS COMPLETELY LIGHT GREEN. I GET NO RESPONSE TO ANY OF THE BUTTONS LOCATED AT THE BOTTOM FRONT OF THE MONITOR. THANK YOU
