Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint HSS25GFP: No water coming out of my water dispenser
I have the same problem. Ice is fine. After I disconnected the hosses at the bottom, water spurts out the bottom when the dispenser flap is pushed. I tried to us compressed air in the lines but it did not work
  • 1 more comment
  • J12Just12 Jan 22, 2008
    i have the same problem at least once a year. Im shutting off the fridge tonight and turning the light on over night hope it works.
  • jbrya Nov 20, 2008
    I have the same freezing problem on our water line. It has froze up three times this month. This is has to be a design flaw. Their has to be a fix for this.
  • kwells2008 Feb 26, 2009
    i have a hotpoint hss25gfp and it started to not dispenser water i do not use the ice maker just water i thought it was the filter i changed the filter did not fix getting water to the door but not out of the dispenser any ideas?
I have 'repaired' the exact same problem as yours by opening the door and transferring all door items to freezer proper, then putting plasic lined insulation (can be bought at most big box home centers for about $20 a roll) in the door opening to keep cold air in. Then I taped the interior freezer light to the off position, turned the light on at the dispenser, and checked every 15 minutes by pressing dispense paddle. My water started to flow after app. 30-45 minutes. This is after I troubleshot all other avenues and got to where you are now (disconnected at quick connect just before line enters door) where I also had water flow when paddle was press to dispense). I called GE/Hotpoint with problem and their response was that it is not a known issue and I needed to call for a service call at my own expense.
Posted on Jan 25, 2008
  • 447 Answers
GE has an issue with the water line freezing in the door. Try turning dispenser light on for 24hours the heat it generates warms the line. Also GE has a heater kit available
Email me for Service Bulletin on Water lines freezing
amasuperbike@comcast.net
Posted on Jan 18, 2008
Your guys are great. I just fixed my refrigerator by following what is suggested here.
Posted on Feb 19, 2008
No water coming through to "ice water" tap
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Oct 10, 2010 | Hotpoint HSS25GFP Side by Side...
Hot point model hss25gfp. can get water at coupling but not out of door dispencer . ice maker works fine. When coupling is disconnected and water is depressed water flows fine from the coupling.
The water line is frozen in the door .Turn on the dispenser light for several hours , or , use a hair dryer aimed up into the dispenser , or , use compressed air in the tube going up into the bottom of the door ( computer cleaning bottle with a small tube ) , or , air compressor hose at the bottom of the door tube , or , order GE dispenser heater kit pt # WR49X10173 ( it comes with instructions ) . After you get it working , turn up ( warmer ) the freezer temp only slightly .
Aug 08, 2010 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint HSS25GFTA WW Fridge that has side by side doors with ice/water dispenser in the freezer (L) door. I still get ice fine but my water dispenser has 'died'. The water has always come out tap...
Hello:
It is very common to have the line in the freezer door freeze up. I would start there first. If that's not it then next step would be your water valve which is located in the back/bottom of the fridge. It is a dual valve( one side for ice maker the other for water dispenser). you can check that by taking off the front kick plate and on the bottom freezer door hinge you will see the line entering the door. Follow it towards the under the fridge and you will find a coupling. Disconnect it and see if there is any water coming out when you press actuator on the door .. If yes then its frozen if no your valve is Kaput.
Cheers
Jun 10, 2017 | Hotpoint HSS25GFP Side by Side...
Refrigerator makes ice and dispenses ice, but does
could be valve, it is located underneath on back. it also could be the mother board. Check valve with ohms metter. Also make sure water resevior or water lines are not frozen inside refrig section. Also water feed line going up through door bottom hinge on freezer is not frozen. Disconnect at couplin at left bottom front and blow through line
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP with a loud howling sound in freezer and no water dispensing
The howling sound usually comes from an electronic control when it's going bad. I've also heard of the noise coming from the special shaped condenser fan you have underneath around back. GE may have a fix for this.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happing again. The part number for this heater is WR49X10173.
Feb 14, 2010 | Hotpoint HSS25GFP Side by Side...
Water to door stopped. I replaced filter. Still no water to door.
the line could have froze in the door,or you have a bad water valve,go to the back of fridge,disconnect the water line and hit the dispenser to make sure it's the valve,if water comes out you know the line is iced up,if it is you can use a hair dryer and heat up the door where the bottom hindge is half way up the freezer door and hit the area where the ice dispenses out the door,
Jan 30, 2010 | Hotpoint HSS25GFP Side by Side...
Ice not dispensing and water not coming out
Our ice maker is not working..water is coming out just fine...the bar is down but not making ice...stylnd@comcast.net
Mar 04, 2009 | Hotpoint HSS25GFP Side by Side...
No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Jan 23, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Water dispenser keeps running
Allen, one of two things here. The dispenser target switch has gone bad or the actuator arm is not releasing the switch. Remove the front cover by using a small screw driver to unlock the tabs at the bottom. Slide the panel down and out. Disconnect the wire harness. Remove the 4 phillip screws in the door dispenser housing. Slide the housing out and disconnect the target switch and light connectors. Now you can spread out the locking tabs and examine the switch. If this all checks good, then the board is the problem...Catriver...post back.
Dec 11, 2006 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
1,633 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
