Back to:
Tags:
Jaton GeForce MX4000,  PCI Graphic Card
Windows doesn't load
posted by IFERGET on Jan 17, 2008
I have an old Dell GX110 (4mb onboard video memory) running windows 2k. I installed this video card and windows hangs up while loading (windows screen status bar is abut half way) and won't go any further. Take the card out, everything works. Reinsert the card, hangs up. Changed the bios to "onboard", plug monitor into onboard plug, everything is fine. The only options in the bios are "auto" and "onboard". I can view the bios on the new card and see everything up to the windows 2k screen.
any suggestions?
Comment by IFERGET, posted on Jan 18, 2008
found a solution!...led to new problem.
I found an article on this subject (http://www.dbsys.com/content/video_driver_update_for_GX110s.pdf). It seems all I had to do was go into the device manager and disable the onboard graphics driver there, then reload the driver for the card.
Reinstalled driver, couple of reboots, It works... for 5 minutes. Then my monitor got possessed by a psychodelic demon. The screen started to squish and expand horizontally, then vertically, then TWISTED. The monitor shut off and back on. Wierdness accellerates. Now monitor just turns on and off at about 1 cycle per second.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
stejeda777
Rank:Master Master
Rating: 88%, 14 votes
Here's 2 things i would try:
1. Install the latest bios first:
click here
2. When you install the new card, go into the bios first and disable onboard graphics (seems like theres isn't an option for that unfortunately, but check again anyway) choose "auto" if you have no "disable" feature.
3. If you have another pc, or a friend with another pc i would test the card on a different pc just to make sure its not a faulty card.
Comment by stejeda777, posted on Jan 18, 2008
1. boot into vga mode by pressing f8 at startup
2. change the refresh rate to a lower one
Rating Locked! (?) IFERGET has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on windows doesn't load:
I don't want to Accept this solution
Can you Help with these Graphics Cards problems?
Graphics Cards
windows doesnt load or show after installing pci video...
Graphics Cards
Hello, I need to get my tv tuner working on vista home...
Graphics Cards
hi I installed a GeForce6200 256Mb(64bit) AGP on a compaq...
Graphics Cards
" Your friends list may be inaccurately displayed....
Loading problems.
Repair Service
Find Graphics Card Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
