Question about Dell OptiPlex GX520 PC Desktop
Curly one Power switch plays up The motherboard is a new one and inspects fine. Also replaced control panel (power switch ) and power supply. It starts after multiple presses of the switch sometimes up to thirty presses. I observe the power supply and processor cooling fan when trying to switch ON and they just spin for a second or 2 then stops, motherboard may be intermittently grounding to the case.How do i remedy this? Thanks in advance.
  • 383 Answers
Replace or have inside Battery : RUN CHECKDISK
go to SYSTEM PROPERTIES CHECK :
NEVER STANDBY/HIBERNATE
GOOD LUCK/Please dont for get to Rate, Thank You.
Posted on Jan 18, 2008
  • 417 Answers
I think that you have a faulty power switch there. I know it is new but there could still be a fault. Suggest try a new power switch as for the earthing check that the motherboard screws are all in place and secured to the case.
Thanks J
Posted on Jan 17, 2008
2 Suggested Answers
6ya staff
SOURCE:
yashan.co.in
  • 202 Answers
SOURCE: curly one
Hi
there is way to find out
First ,disconnect all power cable and data cable from hdd,fdd,and remove all pci devices.
Now you have to check your pc mother board not touch to your pc case.
Second, check heat sink on cpu is mount properly check ram also.
now check on button if it is ok push it to on.
if now occouring same problem.
change cpu and check
if the problem is not solved you mother board is faulty.
Posted on Jul 30, 2008
Power supply or main board ? RCA flat screen
At a guess, main board. I agree if power supply board is bad, you won't get DVD working.
Dec 31, 2015 | RCA 26LA30RQD 26 LCD TVDVD Combo
What problem a change over switch caurses to a 60kva diesel gen set
is the auto transfer switch rated to handle a 60 kva gen set cus you can use a larger auto switch on a smaller gen set but it don't work the other way cus you'll be burning up wires and contactors and have a fire !
May 21, 2014 | UST GG2300 Portable Gas Powered Generator
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
No power from transformer
If the switch mode power supply does not power up then it maybe be faulty.
First check the power button wires from the front panel to the motherboard is seated correctly on the motherboard.
If it still does not boot up then replace the switch mode power supply, make sure the new switch mode power supply has the same or higher wattage rating.
Apr 05, 2012 | Computers & Internet
My HP Media Center PC m1180n had been running fine. I just went to shut it down and after it powered off, I saw a spark come from inside the tower. No there is no power to the PC. Any help would be...
I've had this happen and was able to resolve by removing the power cord for about a minute.
If still nothing, remove the side panel and inspect the motherboard for melting or charring. If you see some you will need to replace the motherboard, if none is present, start by replacing the power supply. Still nothing then it's motherboard replacement
There is a possibility the spark fried more than just the motherboard.
Comment back if you need clarification or more help.
Sep 14, 2011 | HP Media Center m1180n PC Desktop
Emachine W2047 No BIOS Start Screen
Replace motherboard. Processor socket burnt out, contact me for further support at [email protected]
Dec 07, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Asus K8V SE Deluxe - will not turn on
it should have pins to reset it touch the two reset pins with screwe driver to activate it if still gont work you have a bios problem
Dec 05, 2008 | ASUS K8V-MX Motherboard
Curly one
Hi
Jul 30, 2008 | Dell OptiPlex GX520 PC Desktop
Emachine T2484 will not power up
Try to start it without any memory in it (RAM), if it beeps then you have bad RAM. If you have more than 1 piece of RAM then try one at a time and see if it will boot. If it doesn't beep and still doesn't turn on your CPU is probably the culprit since you have a new motherboard and power supply. I would also try unplugging everything that is unnecessary like the CD-ROM, Hard drive, sound card, etc..
Jan 11, 2008 | E-Machines eMachines Desktop PC
KV7-V power supply
follow the power cable from the PSU to the motherboard and see if the 21 connection has melted to the motherboard. You are better getting a 500W silent type, but it depends on the peripherals you have installed, try www.ebuyer.com for various makes.
Oct 09, 2007 | Abit KV7-V Motherboard
Dell OptiPlex GX520 PC Desktop Logo
88 people viewed this question
Ekse
Clive
Clive
Alun Cox
