Question about Samsung SCX 4200 All-In-One Laser Printer
Error message H2 or 2H
I have fitted new parts to the printer but cannot clear the above error message. Any ideas?
Its not worth the cost of having somebody out to see to this unit so keeping it going is a DIY affair.
  • 417 Answers
I think H" is the fuser not warming up. Suggestion trace back your replacements and make sure that all the cables are connected as sometimes when you refit the cover etc. you can knock or pull out a connection without knowingly doing it.
Thanks J
Posted on Jan 17, 2008
What is error B200 & how can I fix it? Canon MP560
Sorry but scrap it as the cost of the parts is more than the printer is worth. You need and new printhead and logic board and they MUST be fitted together at the same time.
Dec 13, 2016 | Canon MP560 All-In-One InkJet Printer
Engine scanner error (internal hardware laser scanner error) error message laser scanner
This means that the laser unit inside your printer has failed. It costs around 100 dollars for the part and it needs to be installed by a trained technician. Best idea is to buy another printer. Sorry.
Sep 29, 2013 | HP Laserjet P1505 Printer, Remanufactured,...
When I power on the IBM 4317 printer the machine goes thru a self test and some of the gears that move the paper appear to be partially stripped. The printer throws an 61 error. Is it worth fixing? Are...
Resident ROM checksum error. Ensure the controller PWB is properly installed and restart the printer. If this action does not clear the code, install a new card. get more information from here
Aug 19, 2010 | IBM (4317-4162) Network Adapter
Dymo Labelwriter 450 Turbo errors
450 label is stuck in machine. How can I fix this problem?
Dec 11, 2009 | Dymo LabelWriter Thermal Printer
I have four Treadmills of Stairmaster(clubtrack510), when I try to start the machine the error (1)ERROR CODE EPLO & (2)ERROR CODE E211 message I am getting please kindly help me how to over come these...
I will start from your Question 2 than Question 1 :)
Error 211 - Clear the error by pressing Power or Clear. Attempt to operate the treadmill again. If error persists, replace VSD or grade motor. Belt and display may continue to be used during Fault conditions by pressing Clear.
Error EPLO - It refers to an electrical problem or might be a Blown Fuse.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 27, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
Clean unaible48
Unable to clean means that the waste-ink "sponge" is full. If you've already checked for small paper part (which is very unlikely, yet possible, to cause this error message), the error is mechanical. Unfortunately, that's not something us users can change, but the machine would require to be sent to service. So if your machine is not within warranty, I'd doubt it'll be worth the service cost.
Actually, there is a possability to order new parts, changed them yourself and enter service mode to reset counters.. But if it's worth it, good question.
Jun 02, 2009 | Brother DCP 130C All-In-One InkJet Printer
I need help repairing my HP Deskjet 5110xi all-in-one
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 10, 2009 | HP OfficeJet 5110 All-In-One InkJet...
Samsung CLP-510 Engine Fuser Low Heat error
I would purchase a new colour printer, Brother make some good stuff now and put your toner on fleabay.
1 747results for colour laser printer
Apr 21, 2017 | Samsung CLP-600N Laser Printer
Photoconductor and error 537
Perhaps a copy of the parts diagram and/or the multi part service manual might be of more help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 14, 2008 | Epson Aculaser C1100 Printer
Brother MFC 3220c machine error 41
I had the same problem with a Brother MFC3420C after replacing the print head with a new one the same error 41 occured 4 weeks later.
I finally fixed the problem (see photo's) and sent the parts back to Brother :-)
Don't buy Brother Inkjet technology its all ****!.
Their laser technology seems to be much more robust and reliable, have had a Brother HL-1440 since 2004 and its still running well.
Jan 12, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Samsung SCX 4200 All-In-One Laser Printer Logo
106 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
