Question about JVC AV-32260 32" TV
Locked I have a JVC AV-32260 32'' TV without a remote. My three-year old somehow locked the set by pushing the buttons on the front panel. I have tried every combination I can think of to unlock the set. How can I get the set unlocked? ron
  • 2 more comments
  • p ron Jan 18, 2008
    Thanks for trying, but how do you enter the defaul code without a remote?
    Yes the set turns on; it has sound but no picture.
    By pressing the menu button, I am able to scroll to "V-Chip" or "Set Lock Code," which upon entering either the locked icon appears.
    Thanks for helping.
    p ron
  • p ron Jan 28, 2008
    Hi bobbyj,
    been on vacation.
    the tv is strictly used for showing dvds. the video feed connects directly to the set.
    p ron
  • p ron Jan 29, 2008
    Bobbyj,
    Thanks, but no luck. The channel is on 2 while the input is on video 1--the screen is black.
    When I change the input to tv the screen becomes snowy.
    The V chip summary displays the locked icon as does the set lock code.
    Sergeant:
  • 395 Answers
Press and hold the power button for 5 to 10 seconds
Posted on Jan 17, 2008
  • 2 more comments
  • Robert Johnson Jan 18, 2008
    If you are talking about the parental lock simply unplug the set it will reset the lock code to the default code of 0000
    according to the manual removing the power resets all the parental lock back to default no need for the remote. does the set turn on?
  • Robert Johnson Jan 20, 2008
    ok, sound but no picture is not an issue of lock, the lock icon would show up when a lock rated show is on. I need more info on how you have it hooked up. also if you go to a PBS station is there picture?
    cable box or streight cable(no box)?
    sat box?
    can you change inputs( dvd, vcr)? if so do you have picture?
    does the picture appear to be on the edges but not in the middle?
  • Robert Johnson Jan 28, 2008
    ron,
    try using the channel down button on the tv to get the desired input you maybe on the worng input make sure that the DVD is turned on first with a dvd playing. if it shows snowy picture then you are on the tuner you should be able to get to the input by the channel buttons go below channel 2. also check the cables to the set, if using the yellow ,red, white make sure they are pluged into there color coded jacks both on the tv and the DVD. if using S Video cable replace it it may be bad.
The set is connected to the dvd player attached at the video one port. Once menu key is pressed, all the appropriate functions appear. When I enter the Set lock code function, the "locked" icon appears. It used to be unlocked.
Posted on Jan 21, 2008
Locked front panel on jvc 27x32 and dont have remote
To unlock the tV, you must have its remote control. For proceedigs to unlock it, refer its user manual [parential code setting], section.
Mar 09, 2012 | JVC AV-27320 27" TV
I cant plug my jvc to my tv .Each time i try,nothing shows up.
I am assuming that you have an AV cable which you need to have connected to your camcorder at the AV output socket, and the other end should have RCA phono plugs (one red, one white and one yellow) which usually connect to three corresponding sockets on the front or side of most modern TV sets, these may be inside a front panel which opens. Once connected, you need to select the appropriate AV input on your TV remote, very often this will be "Front AV" or AV3 or AV4, you need to check your TV instruction manual to be sure of which input is required for your specific model of TV...hope that helps!
Oct 13, 2009 | JVC GZ-MG130U Camcorder
Programming problem
a universal remote control is programmable without codes using this general process:
  • push and hold 3 sec the button set up
  • select the device to control (TV DVD etc)
The tv has to be ON at this step (use the power button in the tv front panel
  • use the remote control power button and try to get your tv pushing the button again and again and again
  • Caution! Go slow because when finally the tv turns on you have to push enter in the remote control to save this code that actually is the one the tv needs,
Apr 14, 2009 | Radio Shack 15-2142 Remote Control
I can not get the time off of the front display
Hi There,
Try unplugging the TV for 2 minutes then plug it back in. Let me know what happens.
Mar 14, 2009 | JVC AV-32D305 32" TV
JVC AV-36950 TV won't turn on
In this case wat u can do is try to Turn On the set without the memroy card inserted....
If still same Problem u can try replacing the batteries.......
If the set turns on without the Memory card replace the memory card....
Good Luck.....
Jan 20, 2009 | JVC AV-36950 TV
52 inch rear projection tv turns off after a minute
try turning off the auto shut off feature in you set up screens . you can find them through the menu button on your remote. scroll through till you find it and turn it off.
Jan 18, 2009 | JVC AV-56WP74 56" Rear Projection...
The digital clock on my 30"JVC is showing in the bottom of screen
The menu screen does not function the display. Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes or more and plug the tv back in. This should reset the tv display. If the universal remote has a display button, depress the display button until you get the desired display results. Reference the user guide below for the display button.
neww.gif JVC AV-36D503 36" TV - User Guide (page #43)
Dec 20, 2008 | JVC AV-36P902 36" TV
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
UNLOCKING THE FRONT LOCK CONTROL
hold it in and it will change. mike
Aug 15, 2007 | JVC AV-27230 27" TV
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
JVC AV-32260 32" TV Logo
1,117 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
