Question about HP OfficeJet 7310 All-In-One InkJet Printer
Scanner seems to jam when faxing, scanning or coppying
When I try to scan, copy or fax, the machine makes a load growl/whir and says to cycle the power to reset
  • 7 more comments
  • bentwrench Feb 15, 2008
    When using document feed for scanning or faxxing there is a whirring/growling noise from inside the machine. This will be accompanied by an error message on the printer display "Scanner failure. Turn power off then on."
    When using the document feed tray to copy a series of originals everything works correctly.
    P.S. I did clean all of the rubber drive wheels. It seems to me that there is a faulty gear drive or spindle on the scanner carriage assembly.
    I'd appreciate any help!
  • pipinLondon Feb 21, 2008
    Growling printer disabling operation
  • trambo Mar 04, 2008
    I had the same problem but the growling/whirring noise is coming from the scanner, not the document feeder. The scanner will scan about half the document before getting the noise and the scanner error message. I removed the scanner bed but I did not locate any possible problems.
  • Anonymous Mar 07, 2008
    I had the same problem with mine. Ended up contacting HP got replacement machine. It ended up doing the same thing. Sent back & got another replacement machine & (knock on wood) its been working GREAT. Of course mine was still under warranty.
  • tickedinwis Mar 28, 2008
    I have the same motor problem during faxing only and was told by HP that they have never heard of this problem. Ifound a replacement motor (used) online for $152+ but ended up buying a refurbished printer thru the HP upgrade. I'm not happy with HP after reading your comments about the same issues and will tell them that.
  • Anonymous Apr 07, 2008
    I have the same problem when using the feeder only in all three functions. Whirring sound appears to be and aborting problem from the feeder?
  • Anonymous Apr 08, 2008
    Same problem. Out of waranty.
  • bbaumeister Apr 10, 2009
    Power Fail when sending fax from document feed. I can receive faxes and send from the manual loading on the flat glass panel. But when I try to send from the document feeder it will dial the number and start to pull the document into the reader, but just before it starts sending, there is a loud whirling sound and I get a "Power Fail" light and the unit freezes up and I have to turn it off and restart to get the document out of the feeder.
  • hmekkel May 06, 2009
    same problem: scanner jams with the growl/whir and power must be turned off to reset. does not seem to be a problem with the document feeder.
Posted on Apr 08, 2008
  • 1,003 Answers
Posted on Jan 17, 2008
Cant send nor receive faxes
dear sir,kindly follow the below instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
Receiving faxes alright, people receiving faxes from us are getting an all black page
Your document scanner has died. Meaning that the row of LED's that light up to scan the documents you are trying to fax are not lighting up. The result is a scanned document that is read as all black. Make a will get a black sheet because the same process is used to scan the document when making copies.
It might be time for a new fax machine as these machines have become so cheap to buy new that I doubt you could get this machine repaired for what you can just buy a new one for.
Good Luck and Thank You for using Fixya.
Sep 24, 2010 | Brother IntelliFAX 4100 Laser Fax
Black copies being received
Your image scanner is bad. Try making a copy....if it comes out black but your incoming faxes are fine then your image scanner is bad. You can also print a report from the machine and it should come out fine.
The image scanner is the part that scans your originals before faxing them out or making a copy. There is a light bar that lights up when scanning. Either that light bar(l.e.d. array) has gone bad or the scanner itself is bad. If this is the case it is probably going to cost more to fix than the machine is worth. You could buy a new machine for what it would cost to fix.
Apr 22, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
When you send a fax, the other person only gets lines on there copy, not the paper that i faxed
Make a copy with your fax machine. If your scanner is bad you should have a similar problem making copies. The same scanner is used to make a copy as is used to scan and send a fax. If the copy comes out bad your scanner is either dirty or bad. If you can see your copy but it just has a few lines running vertically up and down the page then you need to clean the scanner glass. This is a small strip of glass in the port where you feed it your originals.
Good Luck
Jan 25, 2010 | Panasonic KX-FP151 Plain Paper Thermal...
Large Black streak on outbound fax/copy
1 or 2 LEDs are burned out in the scanner unit.
Sep 23, 2009 | Brother IntelliFAX 4100 Laser Fax
HP Officejet Pro L7680 All in One - cannot send faxes - keeps jamming and says "scanner failure unable to scan copy or send a fax. Turn the power off and on and try again" I have done this several times...
The scanner is the problem, the scanner is the real bright light that comes on to scan the orginal document. Does your Scanner lamp come on? mite be burned out? stating scanner failure, doses your scanner move when it scannes the document? Motor or cicruit board that control scanner mite be bad, check the scanner "Home " position sensor maybe the scanner board and main board don't know where the scanner is phyiscal when it goes thur its routine.
Jul 08, 2009 | Office Equipment & Supplies
Black vertical lines on the sent copies when faxed on Sharp UX 510
Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Mar 31, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Scanner failure when faxing of coppying
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Will not scan
With the power off & the machine unplugged, remove the scan glass & move the scanner a few inches from "home" position. Plug in & turn on machine. Does the scanner return to home position? If not, you either have a bad scanner motor or scanner cable. I'll look for you to post the results of the scanner drive test.
Jun 19, 2007 | Canon PC-1080F Copier
HP OfficeJet 7310 All-In-One InkJet Printer Logo
228 people viewed this question
Ben Johnson
