Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint bwd129 Hi My washing machine will not empty tried to turn it off and on as it says in manual but nothin happening..can you help??
  • 1,314 Answers
O k find the acess panel in the front or back then follow this procudure most likely there is something jamming the pump look on the back and you might see an access panel remove it and you will see a large hose coming down from the tub.Now the washer will still be full of water.There are three ways to deal with this the best way is to get a shop vac.remove the drain hose from the stand pipe and vac the water out,the second is to get a pair of radiator hose clamps from the auto parts store and clamp the large hose as close to the tub as possible ,the third is you can get a bucket remove the drain hose from the stand pipe and getting as close to the floor as possible let the water drain in the bucket .after that put some towels around the pump.Remove the clamp and slide the large Rubber boot off the pump look in the pump for foreign objects jamming the impeller blades and for broken blades if broken replace the pump.feel in the boot for same as pump .Then reassemble if nothing found then go check drain hose.
Posted on Jan 17, 2008
Hi i cant seem to get the pump cover off at all.... i've tried to use pliers etc... i can get it loose so that water drains from it but cant take it out to access any blockages... help please :)
Posted on May 06, 2011
  • Anita Narayan Nov 09, 2012
    I'm having this problem as well. Was there a solution, cf84? Cheers.
Can't seem to work it all it does no matter what setting is wash nothing else
Posted on Nov 08, 2009
Thank you so much for this I have fixed my machine yay and no call out for an expensive engineer
Posted on Oct 26, 2008
Had this same problem on BWD129, had a tech in and there is generally only one cause. Something stuck in the impeller (pump) in our case it was a shirt collar insert but is normally coins. If the machine makes any noise on the spin, this is likely the cause too (but it hasn't jammed.. yet)
Look at the front of the machine. In the bottom right corner there is a black cover.
Tilt the machine backwards so any water would run to the back of the machine.
Put a bowl under the filter cover and use a pair of pliars (other sites had said they use a special tool so I hadn't done it) to remove the cover slowly.
Remove cover & filter, check inside and remove the blockage.
This is a no fault found tech call and will set you back £106 + VAT.
Posted on Sep 22, 2008
Where does the plastic ball go does it go in the filter ?
Posted on Jan 30, 2008
Hi there, my washing machine will not spin dry and the machine wont empty, i have tryed turning it off at the wall and nothing! please help
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Jun 30, 2011 | Fisher and Paykel IWL12 Top Load Washer
Indeset washing machine has stopped working. You select the programme the green light comes on but nothing happens. It in not filling up/ draining/ spining nothin, Can you help????
this may sound silly but just had the same problem changed the pump and it works fine now, if the pump does not work it wont let the washer start
Oct 18, 2010 | Indesit W 123 Front Load Washer
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Nov 22, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Fisher/Paykel Smart-drive 5.5 auto washing machine was on final spin cycle and starte making unbalanced load noises. I stopped it,redistributed load and tried to restart. It restarted in spasms so I took...
sound like the controller opr micro board is sick. unplug leave off for a few minutes then power up again and try empty wash cycle if its the same call the engineers.
Apr 22, 2008 | Washing Machines
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
2,530 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
