PowerMac G4 won't allow me to reinstall operating system
I hear a strange sound when I get to a certain point, as if the disk drive or hard disk is really spinning like crazy. But I used a diagnostic disk check before I did the re-install and no hard-disk problems were detected. Could it be my disk drive itself?
  • firefoxfawgo Feb 23, 2008
    all im getting is a black screen when im try,ing to reinstall..i put the cd in ..then i hold down command key =c ..then it goes to a black screen can any one help plz thanks
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    in your question, are the disk drive and hard drive the same thing?
Its ur hdd problem please use anotgher hdd and watch saqme problem arising if if no problem replace the damaged hdd
Posted on Jan 19, 2008
I got mac g4 just got face and ? on it, any have idea what going on it
Typically this is operating system corruption or a failed hard drive. If you can boot to your install media (CD, USB, or recovery partition) try a clean install. You could also try third party software solutions like Disk Warrior or Drive Genius (they supply bootable media) to fix the OS issues or check the disk for failures / corruption
Oct 16, 2012 | Apple iMac G4 Desktop
Powermac screen developed fine black grid and won't operate properly
Isolate the problem to see if it's the screen or video card by connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without a problem then your original screen is bad and your video card is good. If the Borrowed monitor displays the same problems as your original then your video card inside the computer is bad.
May 29, 2012 | Apple Powermac G4 Quicksilver Logic System...
I bought a new hardrive for my m2000 and when i load it it is giving me a "media test failure" response..... how do i load it properly?
If you bought a new hard drive (meaning the internal hard disk), it won't have anything on it. If you just install it and try booting your computer, there won't be an operating system to load. The BIOS (the operating system built into the motherboard) is set up to try loading the operating from connected devices in a certain order. Usually it tries the optical drive first, then the hard drive, and finally it tries to boot over a network connection. The media test failure message means it tried that last resort and still didn't find an operating system, and it's telling you that maybe you have a bad network cable.
You'll need to reinstall your operating system and applications so that the computer will start normally. If your computer came with a restore disc set, or you made a set yourself, you'd use those. If you don't have restore discs, you can do a fresh installation of Windows from CD. You need to find the disc for the version that came installed on your computer, since you'll need to use the product key from the sticker on the bottom. Drivers and utility programs you can download from Compaq's (HP, actually) support and drivers website.
Once you've got a bootable Windows system on the new drive, you won't get that strange message any more.
Jun 03, 2011 | Compaq Presario M2000 Notebook
My ibook stays on the white screen but the apple and the spinning thing doesnt show up but i hear the chimes and i am trying to download my new os x software please help me get it to work
You may have a bad hard drive. The "chime" means that the iBook was able to power on, and the white screen means that it foung the efi or firmware, but the fact that it will not go to the apple or the spinning gear means that it cannot detect an operating system on a hard disk.
Do you have the OSX CD? Put the CD in your ibook, power it on, and hold down the "C" key. This will allow you to boot to the CD. if the hard drive is still good, then it will allow you to install, if not then it will tell you there are no hard disks available. Hope this helps.
Mar 14, 2011 | Apple iBook G4 Mac Notebook
Hi We have a Powermac G4 (mirrored drive doors) with dual 887MHz processor and 2 hard drives. running MacOS X10.4.11 Graphics NVISIA AT4 MX Pro AGP (DVI &ADC) the second/slave hard drive has an image...
Sounds like the hard drive may be on it's last leg. You're going to need an OS on a second disc if you're not able to launch from the existing one.
If you can get the Mac OS disc dvd, you can start up your computer while holding down the C key and it will launch on the DVD system and you can install the system software onto a new drive (or your second existing drive).
Once the computer starts up normally on the other drive, you may be able to access the failing drive and pull files... it may take a while and stop alot but you may be able to save it.
Nov 27, 2009 | Apple Power Mac G4 Desktop
My WD 250GB passport portable hard drive is not recognized
If your system detects the connected device that is a good start. Was the drive formatted for another operating system? Certainly try the drive on another system and/or another drive on your system.
Aug 26, 2009 | Western Digital WD Passport 250GB Portable...
Transferring software and files from PowerPC G3 to PowerMac G4
to mount somthing in a mac is basicly cutting it on for use.
For example if you instal a flash drive or an hard drive via an out side connection, The mac will mount it so you can use it.
Aug 09, 2009 | Computers & Internet
Powerbook g4 15 not turning on
Something is wrong with the operating system. If there is a flashing folder with a question mark, then it might be with the hard drive as well. If you just get that warning, then you may only have to reinstall your operating system (OS X). Get your CD/DVDs out and insert the OS X disk. Hold down C when you start the computer so it will start from the disk and not from the hard drive. After the startup program has loaded, you can try to check the hard drive and repair permissions and such to see if that works, or you can just reinstall the OS. Good luck.
Mar 21, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My G4 powermac wont start up it got small icon of a file folder with a "?" and the "smiley apple face" flashing back and forth in the file folder icon. Even when i press my power button it keep doing all...
When your mac comes up with a folder with a "?", it means that you have either a corrupt operating system, or a missing operating system. This means that your MAC OS is broken, and needs to be re-installed. You will lose all the data on your machine, so if you have any information that is important to you, you should try to get that data off of your hard drive. If you dont know how, take it to any Apple certified technician (or anyone who is good with computers) and tell them that you need the information off of that hard drive.
Mar 15, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
G4: I keep getting a blinking folder
To things can be wrong
1 the system folder is corrupt
2 The hard drive is bad
Too find out which one it is get the boot disk that came with it and restart holding the C key. If it boots and there is no hard drive image on the desktop it is bad if there is one then reinstall the system and you should be good.
Apr 15, 2008 | Apple Power Mac G5 Desktop
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
