Question about Telrad Phones
Dial restrict 411 in Telrad Digital Key BX
Anyone have access to instructions to restrict calls to 411 and 555-1212 in a Telrad Digital Key BX?
  • 108 Answers
SOURCE: Restrict a mitel superset from dialing 1900 and international calls
What Mitel system are you using and what are the numbers you want to allow and what extension are we talking about ??
Posted on Jul 28, 2008
0 characters
1 Points
How to restrict outgoing calls to 411?
I was told by my Phone company that they couldn't restrict the 411. The only thing they could do is put a block on the phone.
Jan 03, 2014 | Vtech DECT 6.0 Digital Cordless Phone
KX-Ta824 Speed dialing problem has a FAQ for this model here
In that FAQ, there is this explanation of your problem:
When I tried to access speed dial, it does not call out.
When storing speed dial number of external parties, the stored speed dial number must include CO (outside line) access code (9 or 81…etc) even with direct line access. If the external number is 1234567, you must store the speed dial number as 91234567.
This rule applies to all system speed dial, station speed dial and speed dial key.
It looks like you're just going to have to add a leading 9 to all the speed dial numbers for that function to work.
Nov 04, 2007 | Panasonic KX-TA824PK Phone
My phone will NOT let me call out when i dial a number it says its restricted. how do i fix this problem???
Here's a phone system lesson. Panasonic discontinued your TD phone system about 8 years ago, so you either got a super deal or the system has been installed that long ago. Restrictions are programmed into the system by an installer and manager. There's a Class of Service override access by dialing 47 on the intercom and a code. Since the 7436 is a special phone, it's probably the one attached to extension 101. If that phone is restricted, clearly whoever owns the system doesn't want whatever you're dialing to be dialed.
Now you wouldn't be asking "someone on the internet" for instructions on how to beat the restrictions would you?
I didn't think so. Check with the system owner or installer.
May 18, 2011 | Panasonic KX T7436 Corded Phone KX-T7436
I need to block certain extensions from being able to dial long distance
Best way to do that is to sit down with the manual and look at programs 400-408. At a minimum, if you restrict 1 and 0 in a table and assign it to your extensons in 405, those phones can't dial long distance. That's fairly worthless in today's calling climate when some carriers let you dial just 10 digits or you have to dial 1 for any local call outside your area code. 404 lets you build 8 tables of 10 number sequences each for restriction and 407 lets you build 8 tables of 10 number sequences for allow. For example You could put 1 HOLD HOLD HOLD (hold is the wildcard) in one table and entry of 404 with traditional dialing and that would restrict all 1+ long distance. Then, in 407 5 of your entries in one table would be 1800, 1888, 1877, 1866 and 1855 to allow toll free calling. These tables get assigned to extensions in programs 405 and 408. A simple restriction (ie local calls only, internal calls only) get assigned in 401. There are some other tricks and, above all, remember that you have to keep 911 availabe for access and allowing 0 is never a good idea because 0 alone will get the operator and that defeats the purpose of toll restriction.
Other tricks involve custom CLASS codes. You need to account for the clever worker who dial *67. That gives them second dial tone and they can dial the world. It would be easy if you could block first digit *, but you ought to allow *57 for nuisance call trace. If you have the above where long distance is dialed with only 10 digits, then you can always start with HOLD HOLD HOLD in a table and allow 911 and the local area code in an allow table. The table digits can be up to 12 so you may have to go to 6 digit screening in allow tables for local exchanges. In my area, we have 10 digit dialing and 419352 419353 419354 (among others) along with 567213 are local calls. If I were programming a customer 6 miles to the North, there would be extensive programming in both area codes.
Outside of that, it's just a function of analyzing your local calls, area codes, how a call is dialed, and building your tables. We do this with billing by the hour :-)
Apr 07, 2011 | Lucent PARTNER18 Corded Phone
Can we make it so the phone can receive calls but not make out going calls?
You can, but you need access to Installer level programming. I'm not going to give you detailed instructions here, because any fool can do the reverse and UNrestrict a phone with the same instructions, but system program 500 and 501 sets day and night restrictions on a phone. Setting the COS to 7 lets the phone dial 0, intercom, and, by programming, System speed dial numbers.
COS 8 allows Operator only (internal operator).
By building tables, you can actually program different restrictions and exceptions for COS 2-6. There's a fairly comprehensive discussion in the Panasonic Features Manual of your TD 816/1232 manual.
Feb 18, 2011 | Panasonic KX-T7431 Corded Phone
I have a starplus sp7050-02 I am having trouble with forwarding calls. my phone company started a new program last week. I used to dial 72# and the phone would automatically transfer to the answering...
That's an easy one....sort of. If you have a DHS manual, you'll have to go into your restriction tables and allow *72 on whatever phone you are using, or better yet, put it into speed dialing where it is not subject to dialing restrictions. The reason for restricting * in the first place is because you can use other telco features like *82 and dial the world. It keeps your users from finding ways around toll restrictions. When * is required, you have to specifically allow *72 and *73.
Aug 26, 2010 | Vodavi Starplus SP7314-08 Corded Phone
Can't dial long distance from one phone
Sounds like that station is programmed to restrict certain digits (like 1 in the prefix) -- this is usually done by the tech because the owner doesn't want unauthorized calls to take place from a publicly accessible phone. To confirm this, swap the phone with another identical working phone and see if it's still restricted. Good luck!
Jan 29, 2009 | Samsung Phone PDCSLCD12B
Dialing out
Usually picking up the handset and dialing " 9 " will get you another dialtone and then you dial the number you want. If you receive a busy signal it could mean your system requires another number to dial out or your phone is restricted from dialing out. When you pick up your handset or press the INTERCOM key you should get a triangle shapped light which means you can proceed with dialing your access code for making a call ( 8 or 9 ). Hope this helps, let me know ...Mike
Aug 17, 2008 | Nortel T7316E 2-Line Corded Phone
Telrad ICMR application manual
I called a phone company that deals with Telrad systems. They were able to walk me thru it.
The specific issue i was dealing with was changing the auto attendant hours. Once i tried the default password of 0000, i was able to use the Telrad IVM application successfully.
Apr 01, 2008 | Telrad Phones
Programming the DSS/BLF
Need to login in system and program buttons from there.
Nov 07, 2007 | Inter-Tel Axxess Phone 5504400
Phones Logo
50 people viewed this question
Top Telrad Phones Experts
Are you a Telrad Phone Expert? Answer questions, earn points and help others
