Question about Itronix GoBook IX250 Notebook
Ethernet and usb not working
Hi, I can't get my system to recognize that a ethernet cable is plugged in, I had previously tried installing linux on this unit over the network. Perhaps I confused windows into thinking I have a different ethernet card. It is recognized as a intel 8255x-based pci ethernet adapter. Also my usb will not detect anything i plug in to it.
  • Patrick  Haines
    Patrick Haines Jan 17, 2008
    I got this used and it did not come with any disks.
  • Patrick  Haines
    Patrick Haines Jan 29, 2008
    I believe this may be an IRQ discrepency. Anyone xnow how to reconfigure this? Perhaps a bios update?
    Genius:
  • 1,003 Answers
Use your recovery disk tHAT CAME WITH YOUR COMPUTER TO RESTORE THOSE DRIVERS BUT BACKUP ALL IMPORTANT DOCUMENTS & PRINTER DRIVERS fIRST.
Posted on Jan 17, 2008
Fix hard disk
with the device plugged in, open your device manager. The device should show a yellow exclamation mark next to it. Select it and delete it.
Unplug the device.
Power the computer completely off.
Plug the device into a different USB port (one you know works)
Boot it back up
If this doesn't fix it, repeat the process a few times with different ports and also using a different USB cable, if you have one.
If this still doesn't work, the troubleshooting gets significantly more complex.
Oct 22, 2013 | Transcend StoreJet Computers & Internet
Computor doesn't recognize it from usb cable I have an Hipstreet HS m701 4GB and when i plug in the usb cable the computor does not recognize it
Hi, Mine did not at first either. So I tried the ac plug in and it began to charge. Then I tried the computer again then it found it and installed the driver. Works now.
Sep 18, 2011 | Computers & Internet
In my dell xps L501x ethernet cable is shown unplugeed even when it's plugged in. The cable which i m using works fine on my desktop which i connect to my adsl2+ mt882 modem through this cable. Cable also...
1. laptops USB port is not recognized by the router .
2. This could be due to the usb hub drivers for this unit not being installed on the laptop.
3. check your "device manager" to see if you have all the usb hub driver installed.
4. Also check your router manual for the usb setup for a laptop connection.
Feb 20, 2011 | Skque Ethernet Cable Cat5e RJ45 White 30...
Can i connect ethernet cable to my 6 years old packard bell desktop
As your Laptop itself doesn't have a ethernet card, you can't connect it. But I have a solution, you can buy a USB Ethernet Adapter, which you can buy for a cheap price and you won't need to open up your laptop or any stuff like that. Just plug into your USB port and start working with Ethernet.
It looks like this:
Hope this helps.
Apr 17, 2010 | Packard Bell Easy One Silver 2101 Notebook
Computer doesn't recognize hard drive
Basic Troubleshooting:
-Check all connections (Ethernet, Power, USB, etc)
-Install the appropriate driver for the device, usually included on a CD
-Double Check compatibility with your system (system requirements usually on packaging of product)
-If you haven't rebooted since you set it up, then reboot, this fixes a lot of things
-Try the product on another computer
-Try different cables/ports on the comptuer.
If nothing works, then send it in if it's under warranty or contact a professional service.
Feb 14, 2010 | Western Digital My Book Essential 1TB...
C5180 all in one is not connecting via ethernet.
Before you begin: Check requirements Make sure you have the following items:
  • One of the following types of wired access points or routers: Ethernet router, switch, hub, or wireless router with Ethernet ports
  • A computer that connects to the wired access point or router
  • A Category 5 Ethernet cable to use for the HP product. (Do not use a standard telephone cable.) Figure 2: Cable comparisonc01710115.gif 1 - Ethernet cable 2 - Telephone cable (do not use) Although an Ethernet cable looks similar to standard telephone cable, each has a different plug and a different number of wires. The plug on an Ethernet cable (also called an RJ-45 connector) is wide, thick, and always has eight wires. The plug on a telephone cable is narrower and has between two and six wires.
Are you changing from USB connection to Ethernet connection?If you previously installed the software for a USB connection and now want to change to an Ethernet connection, follow these instructions to remove the USB installation before continuing.
  1. Click Start , click Printers and Faxes , and then right-click the icon for HP product.
  2. Click Delete to remove the product.
  3. Disconnect the USB cable from the product and the computer.
Step one: Connect the HP All-in-One to the network
  1. Remove any plug or protective cover from the Ethernet port on the back of the product. Figure 3: Remove plugc01710117.gif
  2. Connect the Ethernet cable to the Ethernet port on the product, and then connect the other end of the cable to an available port on the wired access point or router. Figure 4: Connect the Ethernet cablec01710118.gif
  3. Connect the power cord to the product, and then plug it into an electrical outlet.
  4. Turn the product on.
Step two: Decide whether to install with the product CD or download the software Don’t worry if you don’t have the product CD! You can download the most current software available for your product from the HP Web site at no cost. The following information might help you decide which installation method to use:
CD Download For a new product: CD installation is a quick and easy method. If you do not have a CD, you can download the software you need. For an older product: CD installation might not work if you are installing the product on a computer running a newer operating system that released AFTER the HP product released. Downloading the software provides the best results for your older product. Even though it takes more time than using the CD, downloading the latest software can help you avoid installation issues.
Downloading is the recommended method if your computer operating system released after the HP product released. About the software: The software on the CD is current to the date of the product release. The software that you can download from the HP Web site is the most current software available for your product. HP often updates software and drivers AFTER the product and CD release to the market.Step three: Install the software
Jan 16, 2010 | HP Photosmart C5180 All-In-One InkJet...
Can't connect Lexmark C532n to a iMac 24 using an ethernet networ
how are you hooking this printer up to begin with? ethernet? when you installed it was it hooked to a usb cable? if it wasnt on usb you should uninstall the previous installation hook it up with a usb cable to install it, this should make it show up in system properties. then madify the install to a network printer from there
Mar 24, 2009 | Lexmark C532n Color Laser Printer
Linksys Wireless Adapter WUSB54G not recognized by windows
hi.. every wireless router must be configured first using the ethernet cable and not the USB cable.. i think thats the problem.. but i am not sure.. you can try this out.. i was asked to do so for my wireless router..
Oct 31, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Connecting modem via ethernet cable
I'm not an expert in window based units but since it worked with Vista OS and not with XP. Sounds like you might try re-installing XP again. Take note on any windows that refer to the ethernet port during installation. It is likely you might of hit "next" without reading all the text. I know I have in the past. I changed over to mac and I know longer have any problems only at work but give then I give it to the IT Dept and wait and wait and wait.
Sep 05, 2008 | Westell Wirespeed LiteLine 6100...
Computer will not recognise camera.
hey,
have you tryed to plug camera into another computer, maybe a windows?
have you tryed to use another usb cable?
also connector in camera can have bad soldering
check this movie
hope this help you get closer to solution
;) /michael
why pay when you can play
Dec 19, 2007 | Cameras
Itronix GoBook IX250 Notebook Logo
94 people viewed this question
Top Itronix Computers & Internet Experts
Steven Wander
Steven Wander
Larry Chandler
General Systems...
Are you an Itronix Computer and Internet Expert? Answer questions, earn points and help others
