Question about JVC AV-27230 27" TV
Main Menu TV Main Menu would pop up on the screen, go through each setting. I called and learned how to re-set the T.V. from the remote, That worked for a day or two, and the problem started again,but this time when the main menu appeared, it stayed on for a minute or two and went away. A couple of days later the T.V. stopped completely, will not turn on ! Good Power, Good Fuse, Good Cord
  • 25 Answers
Power supply regulator and horizontal output transistor.
Posted on May 13, 2008
Need code for vizio tv trying to program dish remote to vizio tv
Easy!
Still have dish service? their box? Go to box's menu "setup" option, choose "remote control". "On screen" logos will guide you through the procedure.
No box, no service? Knock on your neighbor's door and ask him to look at "menu". find your brand, write down code(s)! Last resort: call dish customer service and ask them to program your "clicker" they are all 'learning" and will be programed via "box'. Be creative! Or, worst case: get universal remote and set it up for both: dish and TV!
Luck is on your side!
Nov 08, 2011 | Televison & Video
Main setup menu froze on screen unable to remove,also TV just stays on have to unplug from outlet. Press Rest button, and home button on remote nothing happens. Do have background channel TV from cox cable...
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
sj
Oct 20, 2011 | Mitsubishi VS-70707 70" Rear Projection...
How to adjust color for better picture
Hello there,
For the Best Picture use the HDMI Cable and here are the Settings for the color setup.
Adjusting Your HDTV Settings
Using the On-screen Display (OSD)
The remote control or the control buttons on the side of the TV can control all the function settings. The
OSD allows you to adjust contrast, brightness and other settings. The TV will save changes made to the
settings, even if the TV is turned off.
The OSD consists of several menu options. The main menu options may vary depending on your
selected input source.
Note: Some of the main menu options may have additional submenus, for example, the TV Rating
submenu for Parental Controls.
The remote control or the buttons on the side of the TV can control all the function settings. The HDTV
Settings App allows you to adjust contrast, brightness and other settings. The TV will save changes made
to the settings, even if the TV is turned off.
The HDTV Settings App consists of several menu options. The main menu options may vary depending
on your selected input source.
1. Press the VIA button.
2. Press ? or ? on the remote control to select the HDTV
Settings App, and then press OK. The Main Menu will be
shown on the screen.
3. Press ?, ?, ?, or ? on the remote control to select one of
the menu options:
? Input
? Wide
? CC
? Sleep Timer
? TV Settings
? PIP
? Network
? Bluetooth
? Help
4. Press OK to select the option or feature you want to adjust.
5. Once the menu option is displayed, press ? or ? on the
remote control to select one of the items to adjust.
6. Press OK to select it, and then press ?, ?, ?, or ? to adjust the selection.
7. Press BACK once to return to the previous screen. To return to your program once adjustments
have been completed, you can do one of the following:
a. Press EXIT on the remote control.
b. Press the RED button on the remote control.
c. Highlight and select the RED X in any menu.
i hope this was helpful don't forget to Rate
Jan 26, 2011 | Vizio M550NV 55 in LCD HDTV
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
How to acess set-up menu without factory remote
The manual can be found near the bottom of the Product page for this TV.
From the manual, pg 11 -
If you misplaced your Remote Control you can still access most settings via the MAIN MENU screen when you press both CH UP (8) and DOWN (9) on the TV set. Some features of your TV Set will not be accessible without the Remote Control. If you lost your Remote Control, contact a Sharp Authorized Servicer by calling 1-800-BE-SHARP for a replacement.
Let us know if this fixes it for you.
Feb 11, 2009 | Sharp 25N-M100 25" TV
Menu button won't work
The codes that are provided to operate the tv from a Dish remote will not offer full functionality with most TV's. The menu button on the Dish remote even when able to bring up the menu screen on TV's is unable to navigate the menu screen due to the complexity of the TV's set up. The newest receiver that Dish has on the market is the 222k which is a dual tuner/two room HD receiver without DVR that has LEARNING REMOTES that might be able to accomplish the goal you are trying to obtain. I hope this answers your question and remember to keep the original TV remote in a safe place so that you can use other functions on your TV as well. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 12, 2008 | DISH Network IR Remote Control
Reseting lamp counter (LG)
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) Come back to this blog and post your HOURS on our site
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Jun 30, 2008 | Televison & Video
Need to reset lamp life indicator on lg rear projection tv model no 525sz812-tb
9) To Check if it was a success
Jun 21, 2008 | LG Televison & Video
Hisense flat screen has locked
Try turning the main power switch on the back of the tv off.
Then hold the menu button and push that switch back on while still holding the menu button.
Keep holding the menu button until the setup menu pops up.
Next, be sure your input is set correctly(air or cable).
Next, do an auto channel search.
That did it for me. After I shut it off I had to do it one more time but it did the job. A friend of mine gave me the tv for free because nobody he new could figure it out. I took it home, got lucky, and figured it out in about ten minutes.
jb
Jan 18, 2008 | Hisense TA42P40M 42 in. Plasma Television
Guide pop up
Maybe there is a setting for the guide in the main MENU settings to adjust when the TV GUIDE displays? Or just turn it off completely? Pretty basic answers, I know, sorry...lol : )
Nov 08, 2007 | RCA F36648 36" TV
JVC AV-27230 27" TV Logo
82 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
