Question about E-Machines eMachines Desktop PC
Laptop screen died
I have an older IBM Thinkpad. For a couple days the screen flickered like a light bulb dying and then went out completely. Is this done? You can see screen a few seconds during boot up but the it goes black.Just wondering if there was a easy fix or to just not bother at all. Thanks.
  • 417 Answers
Try pressing F8 at boot up see if the safe mode menu comes in. If it does boot into safe mode and once in windows change the screen properties i.e uninstall as when you reboot in normal mode the windows will recognize the monitor and install drivers for it. If you cannot see the sub menu after pressing F8 then there is possibly a power supply to the monitor problem or the monitor is faulty. You can get reconditioned units for this laptop will try eBay first. Check out the prices then decide to proceed or replace.
Thanks J
Posted on Jan 17, 2008
My ibm laptop, was working great until this morning, the screen started to flicker, then the icons started to dim and completely disappear and then the screen went to a coloured test pattern and finally...
Check the power supply.Hope the notebook receives power from the battery or the Ac adapter.We need to ensure there is no issue with the power supply.boot the notebook to the safe mode.If it boots to the safemode perform a system restore.In case the notebook does not boot to the BIOS,connect to an external monitor.If we still do not get a display,its the video card
Mar 02, 2010 | IBM ThinkPad T40 2373 Notebook
ThinkPad R40 Screen issues/ video card?
clean your fan this is an overheat problem
Apr 30, 2009 | IBM ThinkPad R40 2722 Notebook
Laptop LCD display problem
The backlight is the light bult that illuminates the screen. Before it finally goes out completely it will turn your screen a pink color on startup (and then usually become brighter and the pink fades). It is also possible that the backlight, also called a Cold Cathode Flourescent Light, CCFL, died an immediate death. But usually they take a while and signal with the "PINKNESS" first. If you found that your computer is working just fine connected to an external monitor (and you moved the base of your laptop around while connected to the monitor to be sure and left the computer on for a long time) then you have verified that the screen is the problem. It is usually two things: (1) the inverter, a circuit board that increases the voltage to supply the LCD which eats around 700 volts (yeah baby); or (2) the backlight itself. The first problem is a relatively easy and inexpensive fix. You can find how to replace an inverter by downloading the Hardware Maintenance Manual for the T40, T41, etc., from IBM/Lenovo's site. Replacing the backlight itself, a bulb that is like a strand of speghetti and even more delicate, is a tougher job. I would suggest purchasing a replacement screen in that event rather than replacing the backlight yourself. (The HMM probably does not show you how to replace the backlight/CCFL as it is a potentially dangerous job.) That suggestion assumes you can find a cost-effective replacement screen and do not mind opening the TP and putting the new screen in. At least look at the HMM to see what is involved. Good luck.
Apr 07, 2009 | IBM ThinkPad T42 Notebook
When i switch on the my thinkpad it starts to boot up then the screen goes blank the battery light goes orange and and flashes and it makes a cranking noise.
Is the Battery making the cranking noise? If so the battery is telling you the battery is dying. I have a IBM ThinkPad 380Z and when on the charger it makes a beeeeep noise and goes off and on for almost the entire day and then stops and keeps a solid orange battery light on.
Try booting without battery
Feb 23, 2009 | IBM ThinkPad T40 2373 Notebook
One of 2 things happened....
1) You Blew the Power Inverter... The Power inverter is a thin rectangular circuit board that plugs into the display panel cable and also powers the LCD Bulb.. If This Part Fails - You Lose Light to the Display even though the display will still be on and viewable against a bright light....
2) The LCD Bulb is Faulty... When the LCD Bulb Fails it will typically give pre-warning signs- though not always.... It will give signs like the whole screen has a light orange or pinkish tone to it, but eventually it will blow and no light at all to the Display Panel....
Both Of These Are Repairable....
The Power Inverter Can Be Purchased Off of Ebay, For Around $15 to $30
The LCD Bulb Itself is also Replaceable.. Though It is a Job Only to Be Performed By An Experienced Laptop Tech... Bulbs as well can be bought off of ebay for a few bucks..
Feb 13, 2009 | IBM ThinkPad T30 Notebook
Charging new battery
usually 8 hours.
for first charge.
on a brand new battery
Jan 29, 2009 | IBM ThinkPad T41 Notebook
Ibm laptop
I would suggest changing the inverter first as it it the simplest and cheapest solution. inverters for the thinkpad can be picked up on eBay for a couple of ponds.
Jan 17, 2008 | Lenovo ThinkPad R51
Failed on restart, had all lights, now no lights and won't do anything!
sounds like your ac plug to the laptop might be loose you can try ans see if you can resolder it back. the other problem is your ac cord might be broken wiggle it around see if the light flickers.
Jan 03, 2008 | IBM ThinkPad R50e Notebook
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
