Question about Euro-Pro Shark Cordless Stick Vacuum SV775R Vacuum
Replacement charger we arelooking for a new charger for our mod #UV615
  • JAMIWARNER Apr 02, 2008
    I AM ALSO LOOKING FOR A REPLACEMENT CHARGER FOR THE SV775R VACUUM. IF ANYONE KNOWS WHERE TO FIND ONE PLEASE HELP! THANKS!
  • JenStorey Mar 12, 2009
    I have the same problem! We are looking for a replacement charger for our SV775R - would love any ideas! thank you1
I have a SV777R, cant find anything about this stupid product. Looks like I need a battery
Posted on Jul 04, 2008
6ya staff
SOURCE:
Lost charger for dirt devil power swerve, where can I find a replacement charger
Dirt Devil has the replacement charger available here: https://www.dirtdevil.com/power-swerve-cordless-stick-vacuum/BD22050-PARTS.html . There are a few third-party chargers that claim to replace the 440008693 charger.
I hope this helps.
Jun 09, 2018 | Dirt Devil Vacuums
HOW TO REPAIR THE RECOIL POWER CORD ON A KENMORE MOD 116.23613300 VACUUM
generally you need to replace the spring mechanism. contact the manufacture for parts/cost. Most local shops don't carry parts to repair vacuums, unless it's a new model, most vacuums are designed to work until they don't then you replace. unless you spend more than 400-500 bucks on it that is.
Nov 25, 2014 | Kenmore Vacuums
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Battery for Hoover Linx will not charge. Charger blinks very fast.
Jan,
your battery is Shorted. it is time to buy a new vac or a replacement battery.
sorry that is such a short hand answer but that is what the charger is telling you.
Apr 22, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
I put a new battery in my 5 year old Dyson DC16, after a couple minutes in the charger the vacuum turned itself on and ran until the motor (circuit board) burned up. I bought a new Dyson motor assembly...
Sorry to hear you're having difficulties with your DC16. Although your cleaner will no longer be under its original 2 year warranty, the new motor assembly would be covered by a 12 month warranty if you purchased it directly from Dyson. As long as the cleaner has been used in accordance with the terms and conditions described in the manual, we should be able to replace this for you.
Alternatively, we could arrange to have the cleaner returned to us for further inspection.
In either case, please get in touch with us directly so we can discuss the issue further. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. We look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 31, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Need replacement part for PIZZA baker mod: PS75891, it is a thermo switch No.E211649. this is counter top pizza oven
I don't see any parts available for this, most parts are propriotory and can't be purchased seperatly. I checked online and this is selling for around $60.00 new and it seems that this oven has been discontinued. If you know what part it is you might be able to match it up at a local electrical supply or appliance repair. I have no idea what a new switch would cost but at $60.00 replacement of the oven might be a better choice.
Dec 23, 2010 | Vacuums
NEED CHARGER MOD:HHD20-200
I have same problem. Please post it if you find source of battery charger HHD-20-200.
Apr 18, 2009 | Vacuums
Battery charger broken
CHARGER WONT WORK MEC B5265 CAN I BUY NEW ONE?
Dec 28, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Euro-Pro Shark Cordless Stick Vacuum SV775R Vacuum Logo
369 people viewed this question
Top Euro-Pro Vacuums Experts
Mark Bowens
Mark Bowens
Roxanne Jones
Level 1 Expert
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
