Question about Samsung SCH-u740 Cellular Phone
Silent mode (vibrate only) capability
Does this phone allow you to turn off the ringer, when you're in a business meeting or another location where you don't want to disturb others? I know there's a beep once option and vibrate can be turned on. Thanks.
  • 1,017 Answers
Although there is no real profile support in the SCH-u740, a simple downward press on the volume rocker lets you quickly silence the phone, while pressing upwards will reactivate the normal ringer.
With the phone open, a long press on the 'T' or '#' key will toggle the VIBRATION mode. The device comes with 11 ringtones built-in, but they are very basic sounding.
Posted on Jan 18, 2008
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring '
Aug 02, 2012 | Apple iPhone 3G
Nokia 1661 not ringing solution
please try below options:
1) verify that your profile is not set to silent (vibration/meeting) mode
2) verify your ringer tone volume is not set to minimum
3) last option is to visit the service center
Aug 16, 2011 | Nokia 1661 Cell Phone
I don't want my phone to be in silent mode!!! Help!
To turn off the ringtone:
Press and hold the Power key on the top of the phone, then tap Silent mode.
Press and hold the down the Volume key until the volume bar is empty and the Ringer volume icon has a x next to it.
To set the vibrating alert:
1.From the Home screen, find and tap Settings.
2.Tap Sound & display.
3.Mark the Phone vibrate checkbox.
Tip: When in silent mode, press the Volume key up once to activate the phone vibrate mode.
Do the opposite to turn it back on.
Jul 13, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Hello there,i have a samsung cell phone model SCH-R351.My phone is on silent mode.What can i do to get it off silent mode and turn the ringer on
In the Settings menu, select Sounds. The Sounds menu appears in the display.
Select the Master Volume sub-menu which allows you to set the default volume for incoming
calls, messages and alarms. You can set the volume to Silence All, Vibrate, Low, Low/Medium, Medium, Medium/High, or High. The Vib. on soft key allows you select vibrate in addition to the sound.
Hope this helps. If so, please rate this solution.
-best regards,
Mar 10, 2011 | Cell Phones
Can the jitterbug ringer be turned off?
You can set your phone to Vibrate or silent mode so that the phone vibrates rather than rings. With the phone on and open, look at the inside screen while adjusting the ringer volume using the rubber volume button on the outside of the phone. As you adjust the volume, the inside screen will display the ringer volume level. It ranges from Max to Vibrate. Simply turn it down until the level reads Vibrate.
If you would like more step-by-step instructions, please call our Customer Service department at (800) 733-6632. We are available 24/7.
Feb 14, 2011 | One Touch Jitterbug One-Touch Cellular...
Hi, I have a samsung cell phone R450 that says silent mode activated and I don't know how to disactivated can you help me please?
Silence the tones your keypad makes when you press a key.
To enter Silent Mode:
In standby mode, press and hold . # button,“Entering Silent Mode” briefly appears in the display and your phone returns to standby mode
To exit Silent Mode:
While in Silent mode and standby mode, press and hold # button “Exit Silent Mode” briefly appears in the display and your phone returns to standby mode.
Adjust the Ringer:
1. In standby mode, press the volume key on the right side of the phone up or down. Options are:
Ringer Off
2. When you are satisfied with the setting, press OK.Your phone returns to standby mode.
Thank You
Aug 17, 2010 | Cell Phones
My iphone keeps buzzing and shows an icon of the ringer with a slash thru it it wont actually ring, just vibrates altho the ringer is on
"An icon of the ringer with a slash through it"?....Usually that means that the ringer is OFF.If you're sure that the ringer is in fact ON , then check your profile.If it's in the Silent or Meeting profile, the ringer is switched off by default and it goes to vibrate.
Jan 09, 2010 | Cell Phones
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
Stuck on silent mode and cannot get the ringer to ring
All you have to do is hold the pound (#) button down. It will then say exit silent mode. If you ever want to put your phone back in silent mode, just hold the pound (#) button down.
Dec 22, 2007 | Samsung SCH-a870 Cellular Phone
Samsung SCH-u740 Cellular Phone Logo
139 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
