Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Hoover Floormate has lost most vacuum capability
Our floormate has plently of vacuum when i remove the lower intake tank but when tank is in doesn't vacuum like it used to. i cleaned all the pasages but this didn't help. the unit used to have a squeegie vacuum affect but now doesn't. anyone have a solution?
  • daley Jan 21, 2008
    squeegee was cracked in several places. i replaced it and unit works fine. thanx!
  • 126 Answers
Check to make sure that the filter cover is in place. This is commonly lost or misplaced. It is a clear-blue plastic cover that lines up with the motor intake and acts as a link for the tank.
Also, check the squeegees and make sure they are not torn. If they are, they will not allow the suction to concentrate in the nozzle. Also, check the black plastic wheel assy under the machine. These are notorious for breaking at the pivot pins at the back and this will not allow the machine to sit on the floor properly and will contribute to this problem.
Posted on Jan 20, 2008
6ya staff
SOURCE:
Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
Oct 20, 2014 | Hoover Vacuums
Hoover floormate will not dispense solution
this is the original Hoover Floormate, and may have a few different things that may be wrong. First check the fresh water tank is seated or installed properly. Second, it may be the pin on the actual unit itself that is not pushing in the plunger (located on the water tank) all the way to release the solution. Check for clogs above the brush block assembly the small holes may be plugged with dried sop solution.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Sep 29, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate h3000 w/spinbrush will not dispense the cleaning solution how can i fix
The hot glue trick will work; but what you probably need to do is gently push down on the black pin from inside the tank. This will lower the solution release mechanism and the solution will dispense. I found this solution on this website and it took 10 seconds and worked well.
Mar 31, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
My hoover floormate will not dispense water
make sure check valve in the solution tank moves up freely. check that the sprayer tips are not cloged.
May 15, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
No Suction
The water channel hose could be torn. you can check by removing the lower tank and tilting it backwards, it is located in the lower section. could also be the filter cover. it is needed for full suction control.
Oct 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
The bottom tank is not filling up with water and it seems like less liquid is being released out of the top tank
Your diffuser may be clogged above the brushes. check the front squeegee to make sure that it is in tact. Remove the lower tank and look at the intake hose, these often tear over time due to plastic getting stiff.
Oct 06, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Won't wet pick up
the intake hose may be torn. remove lower tank and tilt machine back. look for the hose in the middle. Check for blockage in the nozzle and the squeegee condition. check filter cover to be in place.
Oct 01, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
I lost the instruction manual for Hoover Floormate Model #H3030. Can you help me?
The instruction manuals are found on the Hoover web site hoover.com
Mar 09, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Repack the Hoover Floormate
Did you ever get the handle off? I'm having the same problem.
Jun 28, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate SpinScrub won't dispense cleaning liquid
I had the same problem and was preparing to take it back, the last thing I tried was to 'reseat' the handle -- I removed it then snapped it very firmly back into place. That did it, it's working beautifully now!
Nov 25, 2006 | Hoover H3030 FloorMate SpinScrub 500...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
70 people viewed this question
Top Hoover Vacuums Experts
Kirk Thompson
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
