Question about Motorola Mobility V551
Can't open the back....
I cannot find a way into the back of the phone. water leaked on it, and i need to open it up to try and dry it...save it
Remove the little soft gel like pads and there are tiny little screws underneath, remove the screws and be careful because they are
very tiny , need a T6 screw driver
Posted on Feb 02, 2008
My panasonic DMC TZ3 got damp . My water bottle leaked in my bag. I have fully dried it out and allowed it to air but it still will not go. Is there any hope??
In most cases if the water has seeped into the circuit with the battery in full power it is possible that the delicate circuit had failed due to shorting by water.
If you had removed the battery immediately and left the set for drying or opened up to dry the camera it might have saved the unit. Now it seems that luck must come your way.
So check this out and try;
http://www.fixya.com/support/r6041626-when_device_falls_into_water_when
Jul 23, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Tip
Using Bluetooth Technology to Connect Laptop and Cell Phone
Many of you get your mobile phone wet by one way or another. You worry as you mistakenly drop your mobile phone in water. It can also get wet if you are out in a heavy rain. However, there is no need to panic. It is possible to save your wet mobile phone by quickly repairing it. In order to save your mobile phone from water damage, you can consider these easy and simple solutions:<br /> <b>Act rapidly : </b><br /> The first thing you have to do in order to save your wet mobile phone is to act rapidly. Quickly remove all the detachable parts as well as covers possible such as the back cover, battery, the SIM card, memory card etc. Next, take a piece of cloth or a tissue paper to wipe the excess water you are able to notice within the mobile phone. Make sure that you dry it completely. If you don' t do this, the water inside the mobile phone will begin to evaporate and gather in places which will be difficult to reach.<br /> This will save your wet mobile phone and it will start working if it was under water for just a little while.<br /> <b>Using a hairdryer : </b><br /> Take a hairdryer and begin drying the mobile phone while giving more consideration to the place where the battery is located. The battery housing usually consists of tiny holes to let in air (so giving more space for water) inside the mobile phone.<br /> Make sure that you are not holding the hairdryer very near to the mobile phone. Keeping it too close to the mobile phone may harm the electrical mechanism of the mobile phone. Keep on drying the mobile phone from a safe distance for about twenty to thirty minutes.<br /> If solution number 1 and solution number 2 don't work, try solution number 3. <br /> <b>Drying for a long time: </b><br /> Take off the covers as well as battery from the mobile phone. Put the phone in a dry as well as warm place to let the water inside the phone evaporate gradually from the little holes in the mobile phone.
on Dec 22, 2010 | Computers & Internet
Tip
How to Save a Wet Cell Phone
Ever dropped your cell phone in the sink, or even worse... the toilet? Did you ever leave it in your pocket and run it through the washer? Did you ever swim with your cell phone in your pocket? It usually means you have to replace your phone, but sometimes if you're fast, you can save the phone! It's not being wet that kills a cell phone, it's being on and wet at the same time. This can short the circuitry out. If you're able to turn your phone off before it fries, you may well be able to resuscitate your drowned phone!
Get it out of the water as soon as possible. The plastic covers on cell phones are fairly tight, but water can enter the phone in a short period of time, perhaps only 20 seconds or less. Grab your phone quickly! If you can't get to it in time, your best bet is to remove the battery while it is still under water. Water helps dissipate heat from shorts that can damage the phone, so most damage occurs when the inside of the phone is wet and connected to a power source. This can go both ways. Being under water is more likely to short the battery to even more sensitive contacts, so be careful.
  1. Don't panic. Your phone will probably not be too damaged if you take it out of the water right away.
  2. 3Remove the battery. This is one of the most important steps. Don't take time to think about it; electricity and water do not mix. Cutting power to your phone is a crucial first step in saving it. Many circuits inside the phone will survive immersion in water provided they are not attached to a power source when wet.
  3. 4Try putting your cell phone, with battery removed, in an oven on warm and hold. The dry heat will dry that ish out in no time.
  4. 5Remove the SIM card if you have a GSM carrier, . Some or all of your valuable contacts (along with other data) could be stored on your SIM. To some people, this could be more worth saving than the phone itself. SIM cards survive water damage well, but some of the following steps are unnecessary i.e. don't heat it. Just pat it dry and leave it aside until you need to connect your phone to your cellular network. (This step does not apply to CDMA carriers such as Verizon, Alltel, US Cellular, Sprint, etc.)
  5. 6Dry your phone. You can put it in a bag of rice. Obviously you need to remove as much of the water as soon as possible, so you can save it from getting into the phone. Shake it out without dropping it, then use a towel or paper towel (ideally trying not to clog the wet paper in the gaps and grooves of the phone) to gently remove as much of the remaining water as possible. Dry the excess moisture by hand.
  6. 7Remove any covers and external connectors to open up as many gaps, slots, and crevices in the phone as possible.
  7. 8Use a vacuum cleaner if possible. Do not use a hair dryer (even on a "cold" mode) to dry out the phone, as this may force moisture further into the small components and likely melt them, deep inside the phone. If moisture is driven deeper inside, corrosion and oxidation may result when minerals from liquids are deposited on the circuitry. Using a hairdryer might be a temporary fix, but this will eventually cause component failure inside the phone. Instead, remove all residual moisture by drawing it away with a vacuum cleaner held over the affected areas for up to 20 minutes in each accessible area. This is the fastest method and can completely dry out your phone and get it working in thirty minutes (however, unless the exposure to water was extremely short, it's not recommended to attempt to turn your phone on this soon). Be careful not to hold the vacuum too close to the phone, as a vacuum can create static electricity, which is even worse.
  8. 9Use a substance with a high affinity for water to help draw out moisture. Leave the phone in a bowl or bag of uncooked rice overnight. The rice would absorb any remaining moisture. If available, it is preferable to use desiccant instead. Desiccant will absorb moisture better than rice. Turn the phone to a different position every hour until you go to sleep. This will allow any water left inside to run down and hopefully find an opening to escape.
  9. 10Let the phone sit on absorbent towels, napkin, or other paper. Remember that the goal is to evacuate all the moisture and humidity, not to trap it or add even more. Check the absorbent material every hour for 4 to 6 hours. If moisture is evident, repeat the vacuuming step and desiccant steps.
  10. 11Test your phone. After you have waited a day or so, make sure everything is clean and looks dry, and re-attach the battery to the phone. Try turning it on. If your phone still does not work, try plugging it into its charger without the battery. If this works, you need a new battery. If not, try taking your cell phone to an authorized dealer. Sometimes they can fix it. Don't try to hide the fact that it has been wet. There are internal indicators that prove moisture.
  11. 12Take the phone apart if your phone doesn't turn on at all. If you feel comfortable doing this, try taking it apart. First, make sure that you have ALL the right parts and know exactly where they go. Be sure to put everything back in its proper place once finished. As you're disassembling it, pat each individual part dry with a small towel and use the vacuum cleaner once more on the crevices. If this doesn't work, go to the professionals.
on Jul 15, 2010 | Cell Phones
My motorola e1 fall in water and when am trying to on it but it this not coming
if your phone is wet,do not try to switch it on before you dry the battery and phone separately,they need to dry on natural air,that means that you need to wait for availe.back cover need to be open,ofcourse.
Mar 20, 2011 | Motorola Mobility ROKR E1 Cellular Phone
Mobile in water not working now
Remove The Phone From The Water
The first step is to remove the phone from the water as soon as possible. The less time the phone spends submerged, the greater chance it has of being saved. The plastic covers that come with cell phones do provide some protection, but it takes a mere twenty seconds or less for water to get through these barriers and start causing damage to your phone.
Once you pull the phone from the water, remove the battery immediately. Cutting power is a crucial step when attempting to save a wet cell phone. There are many circuits inside cell phones that can survive getting wet, but only if they are not attached to a power source.
If your cell phone comes with a SIM card, remove it promptly. Do not heat the card, simply pat it dry with a soft towel, and put it aside until the rest of your phone is dry and back to working order. The good news is that SIM cards recover well from water damage. If for some reason, your phone doesn't survive the accident but the SIM card does, there are plenty of places that sell unlocked cell phones. Simply place your SIM chip into the new phone and go.
Salt Water Accident
Please take note; if your phone was submerged in salt water, you must rinse it in fresh water before the drying process begins. Even after the phone is dry, crystals can form and continue to cause damage and erosion.
Let Your Phone Dry
The next step you must take to save a wet cell phone is to allow the phone to dry. A great method in providing an optimum drying environment is to set the phone on the vent found on the back of a television set or cable box. The low heat emitted will gently dry your cell phone. Another trick to help speed drying is to place the phone in a bowl of dry rice. This will help draw out the moisture. You can also try placing the phone in a plastic baggie with a few silica packs that come in purchases such as shoes and electronics. Silica, like rice, absorbs moisture.
The important part of the drying process is to place the phone uncovered, in a warm, dry place and allow the moisture to evaporate completely. Another alternative is to place the phone on an air conditioner. The cold air will not damage the phone and the air from an air conditioner is very dry allowing the water to evaporate quickly.
Drying should take approximately three days at which time you can check to make sure the phone is clean and dry. It is at this time that you can re attach the battery and check if the phone works. If it doesn't, wait a few more days and try again. If the phone still doesn't work, take it to your local dealer, they may be able to repair it. Be prepared; getting a cell phone wet will void your warranty and most cell phones are equipped with a water damage indicator so the dealer will know the phone has been H2O compromised.
Alternative Drying Methods
There is an alternative way to save a wet cell phone that includes an alcohol soak. Alcohol is hygroscopic which means that it attracts water. Soaking your phone in denatured alcohol, or a 95% alcohol solution (regular rubbing alcohol is about 75%), soaks up all the water in the phone. When the liquid is dumped out, only alcohol, which will evaporate, remains. Make sure that the alcohol you use is denatured with only methanol as the chemicals found in other types can be damaging. This kind of alcohol can be purchased at your local hardware store. The alcohol soak may work best for phones that have been damaged by salt water or other liquids such as coffee.
Battery Caution
When attempting to save a wet cell phone, make sure you do not heat the battery as it could leak or even explode. Lithium-ion batteries are especially sensitive. In addition, many cell phones have plastic parts that can melt. Above all, do not try to save a wet cell phone by placing it in a microwave. You will destroy the electronic components and possibly the microwave in the process.
The above steps will help to save a wet cell phone, but be prepared. Often the phone will survive but the battery will not and the purchase of a new one may be in order. Good Luck!
Dec 05, 2010 | Nokia 2690 Cell Phone
My mobile 8310 has fallen in the water, after
o.k. first off take the battery and SIM out and blow dry the phone .. the fast you get it dry the better chance you have of saving it. I have saved many phones this way, but, it is hit or miss of your phone will work again. Do NOT place the battery back into the phone until it is completely dry! playing with it before it is dry can fry it or ruin it because the circuitry is still moist. Only after it is dry will you know if it will work.
as far as the code goes you can try 4 zeros or 6 zeros. sometimes this is a generic code.
otherwise call your service provider they may have the code for your particular model.
Hope this helps!
Mar 26, 2010 | Dmobo BRAND CONDITION NOKIA 8310 MOBILE...
SonyEricsson T707 was dropped into water. On recovery (2mins ) later stripped outer covers off and removed battery and sim card. Used hairdryer on unit for about 20mins. Can you suggest anything else I can...
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. This reduces the risk of a short circuit which would render your phone useless. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, but fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one so as not to risk it leaking battery acid in the future.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. If you have dropped your cell phone in water, it is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open for maximum evaporation.
If you drop your cell phone in water that isn’t pure such as a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath. The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If drop your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours. Unless you have insurance for your cell phone which covers water damage, there is no point in sending it to the manufacture with the hope that they will replace it under warranty. If you drop your cell phone in water, the technicians will be able to tell immediately due to moisture sensitive stickers that are contained inside almost all cell phones. The best thing to do is to try the tips mentioned above and repair it yourself.
Jan 03, 2010 | Sony Ericsson T707 Cell Phone
SCH-U430 Won't shutoff
if you let it dry but turned it back on and it still doesnt work chances are its fried and cant be saved.
most phone are held down by screws but the plastic actually snaps together. using a sharp probe or very small ended tool you can pry it open and snap it apary
Jul 23, 2009 | Samsung SCH-u430 Cell Phone
Dropped phone in water
no much. probably it already has a short internal.
you can open the pone and try to use a hair dryer to dry out the phone, but I don't think that is going help.
Nov 07, 2008 | LG enV VX9900 Cellular Phone
Motorola Mobility V551 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
