Question about Drive DME-HR700 Car Monitor
Car problem why does my car judder now and again then cuts out when i stop when i restart the service light comes on and it starts to run better
  • andy1962 Jan 18, 2008
    astra 2001 1600 8 valve no it does it no matter what the weather its as if its not getting enough fuel
Hi my name is vlad prokopchuk.
Posted on Sep 17, 2008
  • 2,039 Answers
What kind of car year engine when you give gaz the engine missing does the weather change thing tell all does thing it my job mecanic for 25 year cheers
Posted on Jan 17, 2008
  • pierre laplante Jan 19, 2008
    when the engine run bad disconnect the oxygen sensor its the sensor that in the exhaust and the best thing would be to get the car scan to see what the code cheers
Diesel engine runs then stops then runs stops every few minutes
Mate I use to drive a freightliner and it cut out on me one day, I eventually got it started but cut out again after about 5 minutes, I rang a mechanic to come out and he found a heat sensor wire came off the radiator and that caused the motor to cut out... Hope I haven't wasted your time.......
Mar 09, 2016 | 2007 Chrysler Grand Voyager
My Renault megane 2003 began juddering on the motorway doing around 70mph then the engine management light kept flicking on and off. I pulled over stop the engine turned all electrics off and restarted it,...
Check the timing belt. It should have been changed at 60,000 miles. Sounds like you have lost some teeth on the synchronous belt resulting in lost timing. Damage to valves can occur. look under plastic cover on the end of the head for the belt
May 29, 2017 | 2003 Renault Megane
I have 2005 clk 320 cdi. whilst driving I stopped at traffic lights and the car started to judder, but it seemed to stop and when I drove away the car did not seem responsive. there was no kick down adn...
Normally a low gear box oil lvl when the car moves what oil there is goes around the transmition when you idle it all goes to the bottom making it judder
Jun 11, 2017 | Mercedes-Benz C-Class Cars & Trucks
Volkswagon bora 130 tdi is juddering with asr light coming on and staying on bit like changing gear at low revs but it does go not away unless turn car off and start again or turn asr off before driving...
asr works in conjunction with stop a wheel it(the car)thinks is loosing grip, from spinning.By applying the brakes to the wheel that is loosing grip,so the car is applying the brake. hence the juddering. if it stops when you turn it (asr)off it must be a sensor fault.easy way is to plug in the diagnostic computer to pinpoint faulty unit. if you dont drive very enthusiastically,then turn asr off until next mot/service.get back if you need any more info ....
Mar 27, 2010 | 2001 Volkswagen Golf
Renault megane engine light flashing and car is juddering.
I have 2 meganes im working on at the moment both have the same problem. the electrical falt light is on coz the pipe has snapped (or come off) under the bonnet on the passangers side close to the window (theres a black box about 2 inch wide the pipe connects underneath). if I reconect the pipe and grab the engien with both hands it wobbles and the pipe pulls off. I suspect this is coz one (or all) the engien mountings are shagged. and this will be the cause of the juddering when driveing in first and second gears. solutions iv have come across for juddering involve changeing the coil pack but thats nothing to do with the problem my 2 cars have as one of them has new coils. they are 1.6 petrol, p reg and s reg
Jan 16, 2010 | 2005 Renault 181
Mini bushes problem
I have a mini one 2003. when i drive it its fine unless im cruising at about 40mph then i get a juddering. I have changed the air filter and used 2 bottles of injector fluid which when thats in the petrol it runs fine but as soon as i put more petrol in it starts juddering again. Also sometimes when i stop at traffic lights the engine feels that its gonna cut out, it revs up and down has has cut out once. Please can you help
Sep 30, 2009 | 2002 Mini Cooper
My 2002 vw passat's esp light comes on when you tuen on the engine, car sounds awful and judders. If you stop the car for a min or so and restart it clears the problema nd drives lovely again. This can...
Sounds like you're not running on all 4 cylinders all the time. Could be one or more dirty spark plugs, bad ignition coils, etc. You'll ruin the engine when you don't get it fixed quickly, even after repairing you might notice a significant hp-decrease.
My advice would be to take it to the dealer asap and have them troubleshoot. Since they can read the faultcodes from the car's ECU, it should give a good pointer to the cause.
Aug 16, 2009 | 2002 Volkswagen Passat
RenaultClio 1.5dci juddering when started if it was going stall
These type of engines have direct rail injection so each cylinder has an injector. The problem sounds like the engine is only running on 3 cylinders (or less). It could be a faulty injector. Are you losing coolant? Is it overheating? Is there steam or excessive smoke coming out of the exhaust tail pipe?
Apr 08, 2009 | 2005 Renault 181
Drive DME-HR700 Car Monitor Logo
90 people viewed this question
Top Drive Car Audio & Video Experts
xxxxxx xxx
Are you a Drive Car Audio and Video Expert? Answer questions, earn points and help others
