Washer issues My washer makes a weird noise when I try to wash clothes in cold water--the usual setting I use to save on the electric bill. For some reason, it washes fine with hot water (which is VERY hot) but the cold setting won't work. What do I do? I can't afford to pay someone to come fix it and my fiance is in Iraq.
  • Sara Feb 21, 2008
    well, now it works sometimes...I didnt do anything to it! so as long as its working, im leaving it alone!! lol
  • squirfy Nov 15, 2008
    I have the same problem. Some neighborhood kids turned my water off at the meter and when it was turned backon it would not work. Only cold wather though.
    Sniper:
  • 88 Answers
So...is there no cold water coming in?
If so, turn off the cold water and disconnect the hose from the washer, then ( with the hose in the sink or washer) turn on the water at the supply and verify normal water pressure. Check the screens in the inlet valves where the hose connects to the washer, make sure there is no gunk blocking water flow. Finally, if this doesn't help....you can either replace the water valve, or if you want to get intense, you can remove the washer cabinet and check with an electrical meter for voltage at the cold water wire harness. If you don't have 120v at the valve with the washer timer turned to the wash position and turned on, (where it would normally fill) you need to replace the timer, which supplies voltage to the water valves. Hope that helps...post again if you have more info or q's.
Posted on Jan 17, 2008
Maytag Bravos MVWX700XL2 won't spin the clothes and is making a weird whining/whirling noise when attempting to do so.
Check for a broken or damaged motor coupling first! I had the same problem on my machine and it fixed the problem for about $20! Of course, I was able to fix it myself. Google or YouTube your particular washer brand and model along with the words "how to replace motor coupling" and you should find all the help you need. I'm lucky to have a great appliance repair store near here that is also VERY willing to help us DIY types, so I didn't even need Google! Best of luck to you!
Jul 16, 2018 | Maytag Washing Machines
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
My top loader whirlpool (3yrs old) appears to be causing stains: after careful monitoring it appears the fabric softener container conitunes to leak/drip/run down the central column - so staining sheets,...
You can try a few differnt things, staining is usually caused by not hot enough water to disolve or hard water issues. A Washer cleaning use one gallon white vingar fill up washer with hot HOT water let sit over night than run washer next day on HOT hot. Second try washing in warm to hot water dluting softner more breaks down better. Also dluting the softner more in the cup will help washing in cold causes alot of these issues, Make sure water heater turned up hot enough, make sure washer has hot water fill?
Aug 23, 2011 | Whirlpool Washing Machines
What is thebest tepmerature for white garments
Set your water temperature to "cold" on your clothes washer. Unless your clothes have oil or grease stains, cold water is usually adequate to clean white and colored clothes. In fact, washing clothes in cold water allows fabrics to retain their color and strength longer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 17, 2011 | Hotpoint Aquarius WD640 Front Load...
Hoover 200m 4.5kg washing machine will not use cold water to wash. How do I switch it to cold water wash?
You can fix one of two ways.
1/ replace the cold water solenoid valve
This is located directly behind the cold water hose fitting
at the top of the machine
Remove the small electrical control panel by removing the
three small screws.
2/ If you only need the cold wash program you can save
money by swapping the vaves around. They are easy to
remove and they are held in place by a plastic insert which
lifts up to remove them .
Make absolutely sure that your Machine is disconnected from the mains supply before you replace these valves
Regards
Bill K
Tuart Hill
WA
Apr 11, 2010 | Hoover HTC243 Top Load Washer
Sides vibrate during spin causing a lot of noise and machine moves. could it be out of balance?
1- Clothes are not balance inside the tube. Try to rebalance the clothes when it happens. It usually happens when towers leaning on on side when water level selector not set appropriately. 2- Try to level the washer by adjusting the leg screws at the bottom of the washer. 3- It make a lot of noise since the whole washer moving against the floor. When it spin only the tube then it won't be like that.
Jan 02, 2010 | Kenmore HE3T Washer
Green whites?
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My machine will not rinse cloths. The cycly stops once it gets to rinse and it makes a lite buzzing noise.What could it be?
Most washers today are cold rinse only. The buzzing noise you hear may be the cold water valve.
1. Check cold water to make sure it is on.
2. Remove cold water hose from back of machine. Inspect washer cold water valve for debris. Can usually be cleaned with spray bottle with hard spray.
3. Cold water valve has failed.
If you need further assistance please let me know..
Regards
reg501
The FixYa Team
Jun 22, 2008 | Washing Machines
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
