Freud FT2000E 3 Router Logo
Anonymous Posted on Dec 05, 2009
Collet on Freud router won't release bit
1/2'' collet on Freud FT2000 router won't release bit. Have to completely remove the collet nut entirely and tap collet off the bit. There's no foreign matter or debris that's catching it, nor are there any visible fractures in the collet. I assume, however, that a new collet is needed.
  • Anonymous Jun 10, 2010
    Back in December 2009, I wrote asking why my Freud FT2000 router wouldn't release the router bit when the collet nut was loosened. "allstarbob" wrote and said to sandpaper the collet. That didn't make much sense to me, nor did it help.
    The real answer became obvious when I got a new collet and the problem remained. The culprit was the collet nut. The inset (or whatever you call it) inside the nut was worn, so it didn't catch the "head" of the collet to draw it out when the nut was loosened. That is, the nut loosened, but the collet and bit stayed TIGHT. Please tell allstarbob that a new collet nut did the trick and to remember this for future reference. DWA
  • Anonymous Mar 18, 2014
    FREUD FT2000 ROUTER sparking
Anonymous
Level 2:
  • Expert 142 Answers
  • Posted on Dec 05, 2009
Anonymous
Expert
Level 2:
Answers
142
Questions
0
Helped
77408
Points
367
A new collet won't hurt, but you may try sanding down the inside of your existing collet with 120 - 180 grit sandpaper. also, buff down the router bits
any condensation or moisture that may have gotten on these items can cause almost invisible oxidation that you can remove easily by sanding. DO NOT USE WD40!!!
Testimonial: "Tks! Will try sandpaper inside collet. Not sure buffing bits will help, since likelihood of ALL of them having a surface problem is pretty low."
Collet stuck in shaft.
On some models the collet stays put on purpose. You don't have to remove the nut either. But if you really do have to remove the collet and it is the type that is supposed to come out (maybe you need to use the 1/4 inch collet) then just stick a bit into it without the nut and give the bit a sideways whack with a piece of wood. If the collet has been pressed in tight by the nut without a bit in place, then you won't be able to fit a bit into it, and maybe the collet is ruined. Find the largest diameter shaft you can to fit into the hole and pop that sideways. Good luck.
I have problem with my collet in my router. As soon as I tread the nut on the collet squeezes to the point I can't get a bit in. If I put the bit in the collet then try to tread the nut on it will not...
Never tighten a router collet empty. This will bend the collet smaller and it will be too tight.
Simply replace the collet. Call the Mfg the collet may be off specs a few thousands of an inch.
When not using the router store the nut loose on the threads enough it doesnt fall off.
Bit wont tighten down in collet
Get a new collet and nut the 1/2" collet is crappy, it is too thin and pushes out of the nut easily.
You may also make sure that the collet did not seperate from the nut. remove the nut completely and if the collet is not attached, remove the collet from the spindle, insert inthe nut and then insert the bit through the collet while holding it and then put the hole thing back on the spindle (mtor shaft) and tighten it.
Back in December 2009, I wrote asking why my Freud FT2000 router wouldn't release the router bit when the collet nut was loosened. "allstarbob" wrote and said to sandpaper the collet. That didn't make...
Thanks for the follow up....
I'm glad your problem was resolved in the end.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Router bits
Mike, The fit is just a little more snug than you expect. The collet is springy, and will expand to fit your bits, even if they were oversize (which is very unlikely). Put on a leather glove and just push the shank of the bit into the collet. Do not try to file down the shank of your router bits, you will only make them run eccentric. You don't need to remove the collet. Just loosen the locking nut about a half turn after it is easy to turn. Good luck. Thanks for using FixYa. Al Kupchella
The router bits will not fit in the collet. When the collet snaps into the collet nut the bit does not fit.
The collet is loosely screwed on, correct?
Is it close, or 1/4" off. You may need an adapter for different sized bits.
I have noticed, particularly with Freud bits, that they seem a bit oversized. Try putting the bit in the collet before you insert the collet into the router.
If you're very careful, you can use fine emory cloth (like 400 grit or higher) to polish the bit by cutting a long strip and clamping the bit in a vice, then gently polish the shank a little to allow it to fit into the collet. Pull back and forth on the ends of the sandpaper like you were buffing shoes, but I would only recommend this if you can use a micrometer to check the shank and it is in fact oversize.
You could create a dangerous situation if you polish too much and the bit is not held securely in the collet and flies out when the router is under load.
Another technique is to sand a slight chamfer on the end of the bit to help it slide into the collet.
Or return it and try another brand.
2helpful
How does one change from one collet size to another size. My Freud router came with the 1/2" collet installed and I need to change to the 1/4" size supplied with the router to fit a bit I want to use....
I just did this on my black and decker router. You need to unscrew the nut that holds the collet and remove it altogether. Then slip out the collet in there and replace it with the new size. Take care to notice how it goes in when you take the old one out. Then rescrew the nut that holds it in place and tighten. My router had three collets and only one of them works for each size, so if it doesn't tighten properly, it may be the wrong size. Good luck.
Hi I have A freud 2000 and have had it for several years but I only recently removed it from the box (long Story) I was trying to put in the 1/4" collet adapter ad it would not go in at all as long as the...
I have had a similar problem with my hitachi m 12 v. I ground the end of a long flat piece of metal so that it would fit around the collet. Mine had sort of a lip on it that the home made tool would fit under. the thing I made was shaped like an  open end wrench. I had to grind it down so it would be thin enough to fit under the lip and just fit around the collet. Then I hit it with a small hammer. a few times on each side of the collet. I kept going from one side to the other until the collet popped out.
Top Freud Tools & Hardware - Others Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Freud Tool and Hardware - Other Expert? Answer questions, earn points and help others
