Question about Samsung SyncMaster 713BM 17" LCD Monitor
VGA input not displaying
The monitor flashes briefly and then turns black when turned on with in put from pc. When no input is placed into the monitor it displays the standard no input detected so i would assume that the LCD display and back light is working fine. Can anyone help?? If you require more description of the problem feel free to ask.
  • plantface Jan 19, 2008
    I loaded the driver on to my pc and tried the monitor with the correct driver installed but still no sucess, have you got any further ideas?
    Master:
  • 619 Answers
Hi, insert the monitor driver of screen on swicth reinstall driver in order to detect screen.
Posted on Jan 17, 2008
6ya staff
SOURCE:
No signal when i used vga monitor connector to pc, no problem in dvi
Michael,
I have both ASUS and LG monitors with multiple input choices. On both, when the monitor is turned on, it remembers the last input source. Both monitors (and presumably yours, as well) have an INPUT selection in their SETUP MENU.
So, I'm suggesting you search your monitor for an INPUT selection option, then choose "VGA" rather than DVI / HDMI / AV / COMPONENT / CABLE / ANTENNA, etc.
Hope this helps.
Sep 02, 2014 | Acer Computers & Internet
My screen keep going white
To me this is a hardware problem.
Let's diagnose, and see Shunka_Reid.
Connect a VGA monitor to the laptop.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
http://support.gateway.com/s/notebook/2009/gateway/nv/NV78/NV78lv.shtml
Number 3 - External VGA display port
General example of VGA connector (port), and VGA cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for the VGA cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
General example of a CRT type of monitor,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY.
Press, and hold the Fn key down, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap on the F4 key once more.
Do you get a good display on the external VGA monitor?
Post back in a Comment.
Also, has the laptop ever been cleaned on the Inside, to your knowledge?
Regards,
joecoolvette
Mar 04, 2013 | Gateway NV7923u 173Inch Laptop (NightSky...
Why does Sony laptop screen stays black when booting?
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Mar 31, 2012 | Computers & Internet
I have a Samsung SensR470 laptop and i have linked up the VGA, audio, and power cables but the monitor is not showing anything. when i turn it on, it just goes into sleep mode or otherwise shows the...
its because you failed to read the Samsung manual on your PC
go there and read, it has HOT key , all laptops have a hot key
Fn key that turns on the external display VGA jack.
on rear of this SAMSUNG.
SLEEP MEANS THE PC IS NOT SENDING THE HORZ AND VERTICAL, SYNC SIGNALS. AT ALL.
THAT MEANS WHAT>?
It means the PC, VGA jack is turned off.
bad cable
bad monitor.
The PC can also be bad VGA chips, or worse,.
your first failing here is not saying why you are using VGA jack
is the Laptop screen dead too> (my other shoe falls off)
dang that be nice to know , no?
or like we do run that VGA to a projector? for say doing power point presentations, (done many before retired)
RTM, the manual is free to read any time of day, 24/7
each PC maker uses there own rules here, its there call
there design and their rules.
my HP its, Fn+F4, (toggle:, internal, external ,both or auto)
but yours is Samsung, ask them. or learn to use google?
Jun 10, 2017 | HP w1907 LCD Monitor
Black screen on acer laptop
Black screen is a number of things.
*If you`re laptop turns on but you see no display at all..does`nt even post,Then its the GPU on you`re motherboard thats faulty & will need replacing. Or
*Its you`re screen inverter which is a small circuit board located inside on the bottom of you`re LCD screen which needs replacing.Theyre cheap and not expensive.
*Do a test for example : Connect you`re laptop to a PC monitor Via VGA to VGA cable.Connect to youre laptops PC input to your monitor PC input,Then turn you`re laptop on.If it displays on you`re monitor then its the problem with your LCD laptop screen,Or the inverter needs replacing.
If theres no display on the pc monitor then its You`re motherboard onboard GPU (graphic Card) - Which you will need to replace the motherboard.
Oct 18, 2010 | Acer Aspire 5500 5570-2609 Laptop
When I turn boot up my gt5220 the monitor briefly flashes and then goes into power saving mode- desktop stays on, fans running and all, until turned off by holding power button down or unplugging it.... my...
first try to connect another power source if it does work that is good then try the other options 1- rams 2- vga card 3- cpu 4- of course there is always the motherboard option....
i had the same problem several times mostly it is the power supply ( the power source ) sometimes gives a weak voltage or amps....
Dec 02, 2009 | Gateway GT5220 PC Desktop
My hp w22 monitor turns on 4 about 2 seconds then
w22 monitor connected to what ,my guess the vga cable
is the PC on,? what PC is it, with VGA port
is the PC making sounds, it must, the fans must work
2 to3 in desktoop
1 in the laptop (VGA on rear, most)
test the monitor on a good PC yet,be super easy, why not do that.
the manual is here, read that?
as you can see its 12 years old,, and may have ccfl tubes, bad.
http://h10032.www1.hp.com/ctg/Manual/c00771554
ccfl tubes when 5 to 10 years old fail
turn yellow
black
dim
or stobe
or are good one day not next or hour by hour or minute
a fact.
save all this pain, pick it up go to good PC and test it.
why wait, and even risk PC damage ,guessing as most do untrained.
Jan 20, 2018 | HP 22" Widescreen Flat Panel TFT LCD HD...
My monitor not turn on when the computar turn on to . and when you try to turn on the monitor its like flash for 1 sec and tune off to black . to turn the monitor on i need to prees the botten 30 time on...
First you sec your monitor power cable is not loos or power in properly if ok then you sec your monitor VGA cable is properly conect to your pc if ok then you disconnect your VGA cable in your pc then you power on your monitor and sec that youre monetor screen. show a masege or not masage like tiis : CHEEK SIGNAL CABLE or NO SIGNAL : if show this signal then you men your display card is not responding or monitor shows nothing then you meen your monitor is faulty then contact any monitor techenican and solve your monitor problem.
Jul 19, 2008 | Computers & Internet
Power light flashes with no display
That usually means that the connection between the PC and the monitor has been interupted- check that the cable (probably has blue ends) between the two is firmly connected, and power it back up. If that doesn't work, you have one of three problems; a broken VGA cable, a broken monitor, or a broken video card. Finding out which- you'll actually need someone tech-savvy there to help you figure that out. Try plugging the monitor into a different computer. If that fails, use a different VGA cable (cables are pretty cheap at monoprice.com), and if that fails, it's your video card.
May 23, 2007 | Mag Innovision InnoVision 786 PF 17" CRT...
Open Questions:
SBCglobal MAil CuStOMeR {1.~855:.536**5666}#[email protected] Service PHoNe MICHIGAN call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
Nov 11, 2019 | Best Computers & Internet
Norton Antivirus tEcH sUpPoRT pHoNe #@#[+I855^26O*OO64~]@@ nUmBeR USA Norton Antivirus USA phone number {+I855~26O*OO64^} is ranked Norton Antivirus is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. Norton Antivirus email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Norton Antivirus support number When you are using the Norton Antivirus for the cable, telecommunication, internet services or anything, then etgezryou will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, the user can dial the Norton Antivirus support number and ask for the help. Once you dial the Norton Antivirus customer support number, you come in contact with a team of experts at the Norton Antivirus customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Norton Antivirus support phone number will help you with that simply and quickly support number
Nov 11, 2019 | HIS Computers & Internet
See all Samsung SyncMaster 713BM 17" LCD Monitor Questions
Samsung SyncMaster 713BM 17" LCD Monitor Logo
322 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
