Question about Soyo P4I865PE+ DRAGON2 (SFP4I865PE) Motherboard
PC won't boot
For the last couple of weeks my PC has begun restarting itself for no apparent reason after being on for a few hours or so. I shut it down and left it down (thinking it may be an overheating issue). Now the PC won't boot up. It runs POST and brings up the Windows loading screen and then restarts itself from there. The OS will not load and I'm not sure what the problem is.
  • lulusicous Jan 18, 2008
    Ok, so I checked the temp and everything seems normal (no overheating). I also pulled the memory, but now I'm experiencing issues with trying to reinstall Windows. I had to change my boot sequence to CD-ROM and was able to get it to pick up the disc. However, now it gives me an error: I can't remember what all it was something like INF file.sys or something and then it says it is missing or corrupt and that it cannot continue startup.
  • lulusicous Jan 21, 2008
    I started the process over and now I can't locate the drivers that I need for the hard drive. I've looked on the Intel site and the motherboard site and have had no luck. Do you have any ideas on what I can do?
    President:
  • 2,351 Answers
When you can get it to start, go directly into the bios. Once there find hardware monitor. (if your bios supports that). If so, here you can monitor cpu & motherboard tempture. Just let it sit. If its a heat issue you will be able to see it in the bios. Also lets see if the pc restarts by itself. If no restart takes place I would guess this is a software issue. Possible virus/worm. Pull the system memory & reseat. Reinstall windows.
Posted on Jan 17, 2008
  • Mike Peluso
    Mike Peluso Jan 18, 2008
    Ok, during reinstall of windows I see windows gave you an error message & it would not continue. That's not uncommon either.
    Now you know why you are having trouble with your system. Windows is messed up. Windows saw another installation of windows. It tried to maintain the original windows already installed. It found a problem with your old files, it tried to repair them but failed. So what you need to do is start again with your new installation. This time around you want to do a qucik format & than install. This format will earse all of the older windows & all your files. I hate giving out bad news! There is no other option though. If you can get into your old windows you can copy your My Documents folder to either a second drive (if you have a second drive in the PC), or burn the folder to a CD/DVD. Either way you need to format & reinstall windows. Than reinstall the drivers for the motherboard & than update windows through windows update. With a little luck everything will work as it should. Best of luck.
    map9966
Won't turn on
Susan,
Dealing with overseas tech support people can be frustrating. If the laptop is only a few days old, you really need to contact them first.
Im sure its still covered under warranty, so start there first.
If it wont boot, it could be a number of things.
If you get no where with them, please post back and someone here will try to help.
Dec 26, 2012 | HEWLETT-PACKARD HP Pavilion g7t...
I have an Aspire One Netbook that is about 3 years old. During the last two weeks, it will unexpectedly shut down for no apparant reason. The "Blue Screen of Death" just appeares for a second...
I suppose that battery is bad. Connect with cable to main and cross finger...
If this is not the problem..., then bios problem or need new internal little bios battery.
JMG
Jul 17, 2011 | Acer Aspire One Netbook
Our Toro, guaranteed to start, won't start. We can cut awhile, then it will not restart. Plug is fine, getting a spark, and not at all wet, can't seem to find the problem. This doesn't...
I have the same problem. One time this happened and it restarted after a few hours and worked fine for 5 more cuts over a couple of months time. Now again it quit mid cut of my yard and would not restart. When trying to start it would fire for a few seconds and than shut off again. I wated a week to try it again and now it does nto fire at all. This is about a year old mower with only about 10-15 hours of total use.
May 11, 2011 | Toro Lawn Mower With Toro Power Tools
Boot up menu restart; will not power
Boot up to the safe mode screen & select last known good configuration.
Jan 15, 2009 | Gateway 4026GZ Notebook
Laptop boots then shuts automatically off
Try this, if you have a fast hand, the second it boots, push Ctrl+Shift+Esc and end taskeng.exe.
If you can't do it fast enough, try booting into safe mode, going to scheduled tasks, and removing any suspicious ones.
If you don't know how to boot to safe mode, push f8 until you see a screen which allows you to choose safe mode.
Dec 18, 2008 | Toshiba Satellite P105-S6177 Notebook
Samsung HLM5065W DLP shuts itself off for no apparent reason
I just had the same exact problem. New bulb and all. Tech. said it was the Light Engine assemble was going bad. Here is some photos of the Light Engine.
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Nov 22, 2008 | Samsung HLM5065W 50" Rear Projection...
System Recovery message appearing during boot up for no apparent reason
The change would be in your bios i believe. are you comfortable with working in there ?
Robert
Aug 20, 2008 | E-Machines eMachines Desktop PC
DS Lite restarting itself
It maybe that you dont charge it?? The game card may have been damaged not sure... you might have touched the power sliding thing... Try and leave your DS on for a few minutes and see if it turns off.
Mar 21, 2008 | Nintendo DS Lite Console
Soyo P4I865PE+ DRAGON2 (SFP4I865PE) Motherboard Logo
105 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
