Question about Sony Playstation 3 (PS3) Console
Help when i turn the ps3 on it says hard drive curropted. reseting do not turn off then it turns it self off then back on and does the same thing over and over. do i need a whole new harddrive now?
  • Anonymous Jan 18, 2008
    My PS 3 hard disc says it is corrupt, trys to restore it self, but does it again.
    HHHHEEEEEEEEEEEELP
    Problem Solver:
  • 17 Answers
Try to format the hardrive in the ps3 system if you cannot access the option in the ps3 in formatting your hardrive you can remove the harddrive from your ps3 and connect it on the PC and format it there
Posted on Jan 18, 2008
PS3 froze will not turn on.
Usually, this problem comes from either having too much dust on your hard drive or not having correctly functioning power cords. Take out your hard drive, carefully dust the inside, reset the hard drive, and put it back in. To check the power cords, replace the ones on your computer with the ones from your ps3 and try to turn it on. There are various guides online if you need help with the hard drive reset and dusting the interior. I am not sure if this voids your warranty or not so be careful. Personally I would try this first though, because Sony charges $120 to fix your machine and it could take months for them to do it.
Sep 17, 2011 | Sony Playstation 3 (PS3) Console
Hard disc is curropt and needs to be repaired but does not repair and will not allow navigation
How to Access Playstation Recovery Menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
have you tried options available in this menu?
Dec 19, 2010 | Sony Playstation 3 (PS3) Console
Hard drive corrupt won't restore
the only thing that you can do is to replace your hardrive and then reset it this will clear any error messages that you may have had because of your hardrive being corrupted
Hope that i could Help!
Jul 15, 2010 | Sony Playstation 3 (PS3) Console
I have a corrupted file on my ps3 and it trys to repair it self after 30 seconds.it goes right back to the same screen. HELP!!!
Your problem may be more widespread than just that one file. The file system on your hard drive may be corrupt. You can try to reformat the entire hard drive in an attempt to remove all the errors in the PS3 data, or you can buy a new hard drive. You may have to replace the hard drive if the hard drive is failing, and therefore not reading or writing data properly.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
After installing the new Hard Drive you will need to format the drive. When you turn on the PS3, you will see onscreen instructions to help you with this.
Nov 24, 2009 | Sony PlayStation® 3 (60 GB) Console
Ps3 turns on, but icons don't show up.
It sounds like it isn't loading from the hard drive. Take your hard drive out and see if it works on a different PS3. If it does the same thing then your hard drive is toast.
Aug 04, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 turns on for 2 seconds then the light turns red and flashes
Okay, so I sent in my PS3 after this happened and they ran a diagnostic scan on it. This is caused by overheating. If you turn off your PS3 and leave it off for a while to let it cool, try turning it back on. If this fails and nothing works, guess what? It's fried. Completely. This is not a hard-drive problem, this is the motherboard and processor. If you have the ability to back-up your hard drive, do it, because you need a new PS3. Sony will not fix this and just send you a new one with a new, clean, hard drive. Sorry folks, it's that bad.
Oct 13, 2008 | Sony Playstation 3 (PS3) Console
I left my ps3 on all night with a movie on pause, and now I can't get it to do anything. I took the movie out and shut the system off for a while and every time i turn it back on the screen is black. what...
I the hard drive might have overheated if you didn't have your system near a fan or source of cool air. Try unplugging the unit for a few hours and let it do a self master reset, and then turning on the unit and see if the hard drive reboots.
Jul 23, 2008 | Video Game Consoles & Games
Hard disk problem
thats the hard drive replace it with a new one and it soude work fine
Jul 03, 2008 | Sony Playstation 3 (PS3) Console
Ps3 problems
Reset the default by having the PS3 in standby mode (red light on) then press and hold the power button for about 10 seconds after the unit turns on. You will hear a beep and about 10-15 seconds later you should get the XMB on your screen by using the default RCA cable.
OR
You need a new or refurbished hard drive. I have had PS3's that wouldn't do a thing till the hard drive was replaced. Hope this helps. Good luck.
Jun 21, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
53 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
