Question about Toshiba 57H82 57" Rear Projection Television
Toshiba 57H82 does not except commands from remote
The remote is ok the trouble is sensor in the set.
what part do I need and where do I get it .
Also need instructions on how to replace.
  • Cary Farah
    Cary Farah May 11, 2010
    whats the problem your having?
  • Boukhari Mustapha
    Boukhari Mustapha Jan 26, 2014
    la tele reste en veille meme en enpuiyant sur les programe de la tele sa marche pas et pas de telecommande quesque je peut faire
  • 1,694 Answers
Toshiba part # 23000852 remote receiver LED located behind
screen frame assembly.....Remove speaker grill...then remove
screen assembly....locate small PC board near RGB CRT's...
Replace soldered in part on
Posted on Jan 24, 2008
  • ernest_ejgf
    ernest_ejgf May 30, 2012
    Im hoping you see this some how even though u posted this over 4 years ago, how to i remove the speaker grill?
Toshiba projection tv model 57H82 color convergence is off. tried the TouchFocus and get and error. tried manually but the red will only move up and down. i need it to move left and right.
OK, the problem is one of the STK392-110 convergence amps has died. It is rare that both die at the same time, so either vertical or horizontal will go out, but not both. Also look for an open fusable resistor near said IC.
May 28, 2010 | Toshiba 57H82 57" Rear Projection...
Toshiba 57h82 "jittery" Screen
I had the same issue and i hooked my time warner cable box up and turned it to an hd channel and it comes in perfect so i set the output to only 1080i and now i can view every channel perfect
Feb 24, 2010 | Toshiba 57H82 57" Rear Projection...
This is jeff I just received an answer to my problem with my Toshiba 57H82 57 in. Rear Projection HDTV. The answer was " Try Wathing the Picture in Picture " But I don't know what Wathing Means
srry . watch the picture in picture . the sub video path takes a different route through video processing and may look ok. the pip control button should be at the bottom of the toshiba remote.
Oct 02, 2009 | Toshiba 57H82 57" Rear Projection...
Screen blank except for horizontal flat line - sound ok
Mar 03, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 Blurry Pic on HD inputs except Xbox 360
Probably your G-Hyper board. You will need expert servicer and should cost about 3-400.00
Jun 08, 2008 | Toshiba 57H82 57" Rear Projection...
57H82 Menu does not display
My best guess is you missed a connection on the mico IC cotrolling the OSD (On screebn display)... Scour the inside, I mean pack a luch and literally look it over real good... If you find nothing take a break and start again... My money would be on that!
Jun 04, 2008 | Toshiba 57H82 57" Rear Projection...
57H82 Service Manual?
Emailed and sent via Pando...
May 13, 2008 | Toshiba 57H82 57" Rear Projection...
Tv only watchable through component Toshbia 57H82
this is a known problem with these toshiba tv's, they will do nothing to help you we should form a consumer group and complain to Washington! The part that needs to be replaced is a hyper pcb,pd0637and is available from Tritronics, in Miami #1-800-365-8030.the part cost me $263.00
Dec 06, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57h82 replacing caps on hyper board
trace them with a continunity meter and all will be ok...
Sep 17, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
109 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
