Question about Watches
Can't get the back plate of a Timex Indiglo WR30M watch back on
Change the battery but can't see, to get the back plate back on the watch - Timex Indiglo WR30 M?
    Scholar:
  • 110 Answers
It is either a screw on case back or a "snap-on. I suspect that it is the latter since you don't mention that you used a tool to unscrew the case back. So getting the back on sometimes is very difficult. I have a special tool for that to apply even pressue and the necessary force and does not put pressure on the crystal. You have to be careful to not damage the crystal. If you don't get it done, then suggest you take it to a shop that has the right tool. If you have very strong thumbs you might get it done.
Posted on Dec 06, 2009
To open watch case, hold back of watch up with arrow pointer on the back plate pointing to the right. There is a pry point on the upper edge where you will see a small arrow pointing. Use a small flat end screw driver to pry the watch case open. Be sure to replace the back the same way with the arrow pointing away from the setting knob.
Take a 1-1/4 inch paddle bit and drill a hole in a 1-3/4 inch wide piece of wood about 1/8 inch deep. Then take another piece of wood about 2 inches long by 3/4 inch thick by 1 inch wide to lay across the back of the case plate. Place the crystal of the watch in the drilled hole. Used a vise or clamp with the watch between the two blocks of wood to press the back on. Be careful not to over press. Works great
Posted on Jun 05, 2010
  • rmhayes612
    rmhayes612 May 09, 2012
    The Timex WR30M back plate is about 1.25" diameter. Pry it off with a small screwdriver (note there is a triangle marking the location to pry agains). Change the battery. Now take a ~24" long 2x4 (actually 1.5x3.5) and whittle the edges a little so you have about 1.25" wide flat spot on one of the edges, at about the middle of the board (12" from one end). This is to clear the strap connectors on the watch body. Put the watch & watch strap around the 2x4 with the loose back plate against the 1.25" flat spot on the 2x4, watch crystal facing out. Place the watch crystal against the top of a wooden table and press down on the 2x4. The back plate will snap back in with moderate pressure.
I purchased this watch a few years ago, brand new, the battery died or was not working from the first day. I tried to open it, very difficult, got it opened to see the battery I needed. I could not close the back cover, struggled for a long time, eventually I ended up braking the crystal.
Today 2018-Oct-13 I purchased a battery of another Indigo that needed another battery.
There is a YouTube video, but I still could not get the cover on. So I used a C-Clamp the way he used a plyers. I had to take off the wrist band. I placed the watch face down with a large washer bigger than the crystal. It slip on the washer so I just flipped over my table mat on and it had a nice foam so it did not slip. I used the C-Clamp and still could not get it on. The o-ring seemed to have gotten out of shape and was squeezing out from the sides. Eventually after using a chisel to push the other side of the back that kept popping out when using the C-Clamp I got the cover closed, but the o-ring was partly out, I left it like that.
Quick TIP on How to open and close snap off watch back cover without special tools
Quick TIP on How to open and close snap off watch back cover without...
Posted on Oct 14, 2018
I tried everything and force wouldn't do it so I dropped by the watch repair place and the gentleman was kind enough to do it for me with the special tool he had and it worked. He didn't charge us which was a bonus.
Thanks for replying.
Posted on Dec 07, 2009
I found an alternative to the pill bottle cap. The back of my watch is just slightly smaller than a Kennedy half dollar . As I have serious balance problems, I wanted an approach that didn't involve me falling and breaking something.
I put the back into place with the Kennedy half on it, put padding on both sides of the watch. Gripped the whole thing with Vise-Grip® pliers and squeezed slowly until I heard the "pop." Huzzah!
Oh ... fun fact that most magicians know -- a 1901-1907 English Penny is the same diameter as the Kennedy half.
Posted on Aug 17, 2017
    New Friend:
This is probably a bit more risky but I don't have a vice or the wherewithal to make recesses in bits of wood. Taking the back off is reasonably straightforward with a small screwdriver positioned alongside the arrow as others have indicated. After replacing the battery I snapped the back on by lining up the back in the required position and placing a UK 1p coin on the front and back of the watch and using a long handled pair of pincers to apply pressure. It worked for me - although I imagine too much pressure might have broken the glass. Good luck.
Posted on Jun 28, 2017
Direction of arrow on back is not important except perhaps to help you open the back. It opens easily enough if you drop it on the floor by mistake, incidentally
To close it just take two pieces of wood not wider than 1 inch for the back and any size for the front where the crystal resides. Pop the whole works in a vise and with little pressure, the assembly pops together.
Posted on Sep 17, 2012
  • Robby Caruso Sep 14, 2013
    If you have a vise!! :-) I've never had a watch prove so difficult!
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
Dec 13, 2017 | Timex Watches
What is Indiglo battery
If you don't know what size battery you need, you can find this information on the back plate of your watch. All Indiglo watches have it stamped there, you may need a magnifying glass to read it though!
Jan 04, 2014 | Timex Indiglo Watches
How to remove stem on timex indiglo WR 30M ?
Insane as it seems, apparently the Indiglo wr30m watch stem does NOT have either a set screw or a release button. No vice needed though, just good fingernails. Pull it out one click to the 'set time' position and pull it out some more and it comes out.
Mar 06, 2011 | Timex 27191 Wristwatch
How do I change the day on my Timex WR30M Easyreader Indiglo watch. I can change the date, but not the day of the week. Help....
When you bought the watch, did you find a little manual in the packaging? The manual has all the info.
Dec 19, 2010 | Timex 27191 Wristwatch
Hourly chime
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 25, 2010 | Timex Indiglo Analog Watch
Indiglo does not work after changing battery
On a Timex a lot of times the back has to be on for everything to work. But I am going to assume the back is on. The indiglo could just be out. Timex repairs their watches for little or no cost. You would have to mail it to them for repair as they do not release parts to anyone. I believe their number is 1-800 for time
Jul 30, 2009 | Timex 27191 Wristwatch
Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
Dec 30, 2008 | Timex Watches
How to change battery for Timex Indiglo WR 30M
I second the vice advice...the only thing that worked was to put it in a vice and crank it one more crank then you think is possible. You will hear a little "pop" when it snaps into place. It was the only thing that worked!
May 14, 2008 | Timex 27191 Wristwatch
Watches Logo
13,786 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
