Question about SanDisk Sansa e260 MP3 Player
Sansa keeps shutting off/ wont read memory disk
Okay, so I had about 700 songs on my Sansa, and i needed more memory. So I bought a 2 GB memory card. I put it in and plugged the sansa into my computer. It isn't reading the disk. I went to Windows Media Player where I usually sync music into my sansa, and when I tried to put music into my sansa, it shows that there is no more room. I don't know why it isn't reading my memory disk! I spent a lot of money on it too..
So then I just deleted all my music, thinking that the problem would be fixed. I tried putting music into my sansa again, but then the sansa keeps on shutting off, even when it is still plugged into the computer. Every single time I try to do this, it happens. What's wrong?
  • Smjett03 Mar 25, 2008
    When I turn on my SanDisk Sansa e260 MP3 Player it says refresh database but doesn't refresh and the screen turns white then black and is frozen. I bought a memory card for it but it still doesn't work. Could it be the battery?
  • 758 Answers
The issue you have described with your portable device in most cases can be resolved by formatting your device. Please follow these steps even if you have already attempted them once before.
Please note that this will remove all music from your device.
Formatting the device in Windows Media Player
1. Open Windows Media Player with your MP3 player connected to the computer
2. At the top of windows Media Player select the Sync tab at the top
3. The MP3 player should be recognized on the right hand side and say "Your Player Name"
4. Above the player name is a button that says "Format Storage Media" click this button to erase all the data from the player
5. Continue with the acknowledgement of erasing all data on disk.
Posted on Jan 18, 2008
  • Jean Sintulaire Apr 03, 2008
    I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
    http://www.sandisk.com/Retail/Default.as...
    The number for sandisk is 1-866-726-3475
    Please rate accordingly
    Thank you
    Computerrep
6ya staff
SOURCE:
Hi every one i bought new mp3 player sansa 250v2 it's a 2 gb . .but m not able to drag any songs . i want to know that weather i have to new memory card .and one more thing that this mp3 player is with 2...
hi i solved this problem my self and i would like to share this problem withall .first i format my sansa c250v2 then after when i was checking setting then i saw one new folder named usb .and i clicked on that folder and changed auto detected to MSC .THEN AFTER I SHUT IT DOWN AND ON IT THEN I SAW THAT IT'S WORKING
Mar 21, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
How to add 8gb memory card in sandisk sansa e270
You have a v1 unit and the maximum is 2GB MicroSD unless you install a different firmware called Rockbox. Then you can load the MicroSDHC cards in your computer and play them in the Sansa.
Mar 06, 2009 | SanDisk Sansa e270 MP3 Player
My Sansa WONT read my micro and wont upload songs
You should try to copy your music/files to your computer and format your SD Card. After that, copy your music/files back to the SD Card.
Feb 09, 2009 | SanDisk Sansa e200 MP3 Player
More memory?
I haven't tried this, but I see no reason it why it shouldn't work. I have used an 2gb expansion card in my Sansa and it works just fine. The only problem is it will only play music off of an SD card, no video. I guess this is only to much memory if you don't need it. Rough guess is that a 4gb will hold roughly 1000 songs. I would only go for the smaller sd card if there was a substantial price difference and you won't be needing the extra space.
Dec 06, 2008 | SanDisk Sansa e250 MP3 Player
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
Sep 20, 2008 | SanDisk Sansa e260 MP3 Player
My Sansa c200 says memory full
some times their is not enough space in phone memory! if you hav any pic or video in phone memory! move memory card or pc! then you can download songs! actually one songs is 3mb! check phone memory
Jun 30, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
How do i put songs on the mini sd card i bought for my Sandisk sansa connect mp3 player
I'm not sure but you should be able to find the settings for saving data in it's menu and change the location from internal/onboard to memory card.
I hope this helps, and Good Luck.
Jan 23, 2008 | SanDisk Sansa Connect MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
Can't copy songs on to SD 2 gig Card in Sansa e250
the card shows up as a separate drive letter, remember that
when the card is in the player, look for the second drive letter in My Computer and add the songs to it not the first; yes the card will show up in your library on the player only after you have unplugged it and restarted the player.
Oct 18, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
91 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
