Question about Microwave Ovens
GE Microwave oven
I have a GE Spacemaker XL Microwave Oven. One of the lights underneath burned out and while trying to replace it the light broke and I not only shorted out the other light but now the vent fan does not work either. I replaced the two lights...this is how I know they do not work and of course I mentioned the fan also stopped working. When I select the lights or vent fan I can hear what sounds like a little "click" that seems to be in the area of the selection panel. Any ideas what I may have done and how I could correct it?
  • bophi131 Oct 07, 2008
    I have a brand new GE Spacemaker XL1800 Microwave Oven and the vent fan does not work. Everything else works fine, and I can press all the buttons on the control panel to cycle through low, medium, and high fan settings, but the vent fan won't turn on. Is there a quick/easy solution to this? or do I have to call GE customer support? Thank you.
  • Microwave Ovens Master
  • 9,098 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 03, 2008
Have ge profile spacesaver xl sensor. will not heat strange buzzing sound and burning smell. clock, light, vent still work
This is most likely a defective magnetron, especially with the burning smell. There are two other parts that can be a problem, the high voltage capacitor and diode, all three work together to heat food. If the magnetron is the culprit, probably cheaper to replace the microwave oven.
Mar 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the light that is inside the GE Spacemaker microwave?
with cord unplugged you can remove the main control panel and access to it
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Intertnal light in spacemaker xl 1800
if there is no plate to unscrew in front of the bulb , then the only way it can be changed is to open the microwave
WARNING: HIGH VOLTAGE CAPACITOR INSIDE WILL STILL BE HOLDING HIGH VOLTAGE
if you are not familiar with this then don't attempt the repair!
then you will need a technician
electech
Oct 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Oct 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
