Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Nothing but Red Screen
When I turn on my tv, all I see is red. I hear the sound from the tv and I hear a poping and cracking sound. It then turns off by itself. What needs to be replaced and how. Thanks
  • matt42w Jan 17, 2008
    No. No liquid on anything. The red bulb is the only one that comes on and the red board at the bottom of the tv sparks in the rear left corner. (Looking from the front.) Any other ideas what it might be??
  • 4,402 Answers
Check to see if you noticed some liquid on some of the wires on the red crt could the crt coolent be leaking onto the board under the crt and the blue crt is missing alot of coolent!!!
Posted on Jan 17, 2008
  • Cary Farah
    Cary Farah Jan 18, 2008
    They are prone to CRT coolant leakage. This usually shorts the
    driver board and/or mainboard. It should be obvious if it leaked
    coolant. If you lucked out and only shorted the driver board those can
    be had for $50 new. Replacing the coolant is a simple fix as well. It usually
    leaks at the rubber seal, as if it wasn't tightened down enough during
    the other problem is the yokes become shorted and have to be replaced.
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
TV will not power on.
I guess your TV is DLP.
Please notice the follow symthoms:
When you on TV, did you hear some strange noise from the back of the TV. If yes, the color wheel needs replacing.
If no, check the lamp. Take a look to bottom of lamp, you will see white pot or sometime a pop up there due to lamp cycle is going to end. When changing lamp, check the ballast and power sup, too. If you see caps are poping up. Pull out those board and replace the poped caps.
Aug 13, 2009 | Televison & Video
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Red screen and only red bulb powers on.
The red tube and the red crt board sound like the problem. these would be the first thing that needs to replace 250 for tube +50 for crt board. + labor about 300 to 500 to repair
Jan 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
