Question about Canon CanoScan 2700F Film Scanner
Scsi isa card
Hi, I have updated my pc and I was wondering if I could use a different scsi card with oci connection if so can any one reccomend one please.
0 characters
1 Points
Epson gt 12000 scsi
We don't have enough information. The SCSI card has to match the bus of the computer ie: ISA, PCI, ect. is a good place to start. Then you have the problem of a cable with ends that match the card and the scanner. The Epson GT has a parallel interface which might be a simpler solution.
Jan 22, 2014 | Epson GT 12000 Flatbed Scanner
Can I use the scanner with Win 7?
You can only use usb to scsi adapter check this link for some models:
Dec 10, 2013 | Epson GT 12000 Flatbed Scanner
Hi I need the service manual with schematic of this old scanner (HP scanjet 4p) This device doesn't work : SCSI controller and O.S. (either 98SE and Windows XP pro) configure properly the...
The old model scanner came with an old ISA SCSI plug-in card. Even if you had the card, it will not fit into ANY of the card slots on today's motherboards. That card could inly be inserted into a a motherboad from the pre-pentium days - like a motherboard with a 80286 processor. If you ae using a diffrent SCSI controller card I doubt if it will work with this old scaner. FYI, service manuals do not contain schematic diagams and would not cotain the info you need to get that scanner to work with a different scci controller. Sorry, but the 4p is just too old.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Jun 25, 2011 | HP ScanJet 4c Flatbed Scanner
I have umax powerlook II pre-press scanner flat bed model. Now i want to connect with pc. So, i need scsi card for this connection where i can bought that card. If that is available in india please give...
Below given is the link of Umax India with the contacts available in india. Call your nearest dealer so that you could purchase the SCSI card for your flatbed scanner.
Oct 11, 2010 | Umax PowerLook II Flatbed Scanner
SCSI to USB conversion for Film Scanner
SCSI to USB converters are available, but I doubt they will be of much help for you, you'd still need a special driver for your scanner.
Windows 7 Professional, Enterprise, and Ultimate support "XP Mode", essentially a Windows XP environment running in a virtual machine. I'd try to get the SCSI interface card and scanner to run inside the VM as a workaround.
Feb 07, 2010 | Acer ScanWit 2720S Film Scanner
The pinout is specific for the original controller ISA board. So, even inserting the voltages (+5v and +12v) in the right pins, it would not be possible to connect to a Paralel port, the pinout is completely different.
I've found the pins to insert power, but this information turned out to be useless, since i cant connect the data pins to any valid port.
Here is what i found:
01 -
02 -
03 -
04 - +12V
05 -
06 - +12V
07 -
08 - +12V
09 -
10 - +12V
11 -
12 - GND
13 - +5V
14 -
15 - +5V
16 -
17 - +5V
18 -
19 -
20 -
21 - GND
22 -
23 - GND
24 -
25 - GND
Conclusion: Even IF you get the original controller board, it use a ISA standard, so your motherboard will not have where to put it, since all motherboards since the 2000's have only PCI slots.
Aug 11, 2009 | IBM ADF Flatbed Scanner
Trying to connect Umax PL 2100XL (SCSI) to G4 - scanner not found
I just told someone else this solution...KILL the SCSI junk...I had nothing but trouble with it with my Mac....I got a Ratoc Firewire to UltraSCSI solve the regular SCSI to ultra SCSI problem...I also bought an adapter....It works need for a SCSI card...or a just plug directly into your firewire port! If anyone can help me with my TA adapter startup problem...I'll be thrilled! Carole
Mar 23, 2009 | Umax PowerLook III Prepress Flatbed...
I need info on the make of scsi card that is bundled with scanner
It may be an old Adaptec SLIM-SCSI series. Very popular on Late 90s
1. Adaptec PCMCIA Fast SCSI Controller ( 1807600 ) - SCSI Controller ...
    "Adaptec Storage SCSI Controller Card, Storage 1807600, Adaptec PCMCIA Fast SCSI Controller."
2. Adaptec SlimSCSI 1460 review - IT Reviews
    "Adaptec is the king of SCSI connectivity devices and currently offers two PC Card (PCMCIA) SCSI cards. The 1460 is the jack-of-all-trades model, ..."
3. Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0 ...
    "Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0.2183.1 - Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter."
Jan 18, 2009 | Umax PowerLook 2100XL Flatbed Scanner
How do i connect a "fujitsu 4750 scanner to my PC.
my pc does not have a 50pin connector. so i need (i Guess) a converter that will go from the 50 pin to a usb on my pc?
May 28, 2008 | Kodak Digital Science 3520DP Path-Through...
New motherboard not compatible with scanner. isa pci
I think you only need to download the driver. in the device manager, the card should come up as an unknown device. I f the card doesn't show then it may have fried too :(
Feb 27, 2008 | Mustek PARAGON 1200 SP Flatbed Scanner
Canon CanoScan 2700F Film Scanner Logo
37 people viewed this question
Top Canon Scanners Experts
 Mike M
Mike M
D. E. Hev
Mohan Sriraman
Mohan Sriraman
Are you a Canon Scanner Expert? Answer questions, earn points and help others
