Question about Goodman GMS90703BXA Heater
6 flashes my heater is flashing 6 times which says open role out or open fuse any suggestions
  • 1,420 Answers
Follow the wiring diagram and find all safety switches. Test them to see which one is open. Reset it or replace it and find out why it opened. Something caused it to open.
Posted on Jan 21, 2008
Goodman gms90703bxa tripping overheat limiters, keeps flashing 6 times, open roolout
When unit come on you need to watch the flames that shooting in all should blue. If there is any red flame kick out that would trip the flame role out switch. If the is the case you need a need heat exchanger.
Feb 09, 2015 | Goodman GMS90703BXA Heater
6 flashes
it is open role out or open fuse
Jan 26, 2008 | Goodman GMS90703BXA Heater
It is flashing an E68 lights start to flash and beep
Hello Wanda Leach - Typically error code E68 can indicate one or two issues. First problem could be that one of the keys (buttons) is stuck closed (active). Enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again. If button is free but the error code still exist, the electronic control will need to be replaced. Second issue could possibly be a current leakage to ground on heater or fuse opened. However, I would strongly suggest contacting a professional to the check the resistance of the heating element (should be approximately 14ohms) or the resistance between the ground and both heater terminals. It should be open when heater terminals are disconnected. If the readings are incorrect, replace the heating element.
Sep 30, 2012 | Frigidaire Electric Dryer
What is code flashing 6 times mean?
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Sorry to read about your problem, I hope this helps you out.
Circulator blower runs continuously. No furnace operation. Integrated control module diagnostic LED is flashing SIX (6) flashes.
6 FLASHES
1 Rollout limit circuit is open.
2 Flame rollout. i? Misaligned burners, blocked
flue and/or air inlet pipe, or failed induced draft blower.
3 Loose or improperly connected wiring.
4 Check burners for proper alignment.
5 Check flue and air inlet piping for blockage, proper length, elbows, and termination. Correct as necessary.
6 Check induced draft blower for proper performance. Replace, if necessary.
7 Tighten or correct wiring connection.
Turn power OFF prior to repair.
i? See i?Vent/Flue Pipei? section for piping details.
i? Ensure the correct pressure switch replacement is used.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
Dec 29, 2010 | Goodman GMS90703BXA Heater
Strandby power indicator flashes 6 times repeatedly
According to the symptom the problem is of thermal fuse which needs replacement, the part number is given below:
1-910-006-44
The method to change it, is given below:
1-Remove rear cover
2-Remove sub-woofer speaker box
3-Remove metal backing plate
4-Remove Exhaust fan
5-Remove Optical block screws
6-Remove Open thermal Fuse
7-Install new Thermal Fuse
8-Reassembly Connection & Wire-dress.
Act according to the instruction and it will solve the problem.
Thanks
Nov 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony wega problem look like im not the only one!
This sounds like your lamp failed and opened you thermal fuse. 6 blinks is open thermal fuse and that would normally only open if your lamp failed. Replacing the lamp is simple, but the thermal fuse is a very difficult repair with considerable disassembly.
Mar 20, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Red Light Flashing 6 times
A 6 blink usually indicates a bad thermal fuse caused by the lamp temperature getting too hot. I strongly suggest replacing the sirrocco fan that mounts on top of the optical block too. Usually this fan gets clogged up with dust so the lamp temperature gets hotter than it should causing the thermal fuse to open up. Replacing the thermal fuse, sirrocco fan and cleaning the dust from the inside and fans will cure this. A Sony authorized servicer should be able to repair this for you. Good Luck
Jan 05, 2008 | Sony KDF-E55A20 55 in. LCD Television
Goodman GMS90703BXA Heater Logo
76 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
