Question about HP PSC 1210 All-In-One InkJet Printer
Cleaning how do you clean the rubber rollers on printer drive. there appears to be black ink on them. there are black marks (lines) on the back of the paper.this is not good when you are printing on both sides of the paper, or in my case printing on both sides of address cards
    Genius:
  • 1,003 Answers
Open front and top cover (PRINTER shut off) APPLY RUBBING ALCOHOL TO A MICROFIBER TOWEL AND CLEAN ALL EXPOSED WHEELS
Posted on Jan 21, 2008
Why do i get thick black line(stripe) when scanning and copying with the hp 4315
Sounds as if you have dirty drive path for the paper. Printers are bad about ink leaking (especially if not used often) and cleaning well involves some disassembly. The ink is very messy so wear rubber gloves. Clean around print cartridges, rollers, and also the glass for scans.
Jul 26, 2014 | HP OfficeJet 4315 All-In-One InkJet...
Printing
No black line while you scan, but it only appears while you are printing?
Mar 18, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Black marks on the printing
You could have a build up of ink on your rollers, and as the paper is pushed through it is leaving marks. It could also be causing your ghosting effect or double lines. By having your printer cleaned by a certified technician it should reslove your issue.
Jun 09, 2010 | Epson Stylus Photo 1290 InkJet Printer
Ink leak?
It's not the cartridges, the waste ink is coming up thru the bottom to the exit rollers. The only fix is to have a shop open it up, clean up the ink mess and install a shield that stops the ink from coming back up when it should go to the absorbers. The new machines all have this shield and the ink tube cut back to make the ink go where it should.
Feb 21, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Pages comes out with large black line running down page. I've tried cleaning it helps a little but I still have a black line.
If the large black line is on the back of the page, it is because too much ink is built up under the transport and transferring to the exit rollers. There is a mylar shield needed under the transport after cleaning the rollers to keep the ink from coming up again. Usually a shop repair, around $89.00
Jun 22, 2009 | Canon MP830 All-In-One Printer
I have a black line of ink on the back side of the paper when I print anything. It fade through to the front. The line goes down the middle of the paper and is about 1/4 in wide
Cause: Possibly a leak in an ink cartridge. Pull all of your cartridges and inspect for leaks....it will be obvious and you will probably get it all over everywhere if you are not carefull, so be prepared to immediately toss it in the waste bin.
Solution: Sounds like you have ink (wet?) inside the paper path on one of the rubber rollers. It sounds like it is so saturated with ink that this will continue for a long time until it either runs out or you replace the roller.
Look for the roller that is where this line appears. Using another piece of paper or a paper towel soaked with alcohol (rubbing), touch it and see if ink doesn't appear on the paper. If it does then you might be able to clean it by continuing to soak up the ink on scrap paper by pressing it out of the roller. It won't completely fix the problem and it won't do it right away but it will get it started.
Jun 21, 2008 | Office Equipment & Supplies
Black line down the page
Is the line on the front of the page or on the back? If on the back, you need to clean the platten which is the piece of plastic under the paper.
If its on the front, and you say "It lools like a rubber cover may be missing off of one of the rollers", could you upload a picture of this roller? I don't recall any covers on rollers in Canon printers.
Try this, print out a blank page. If line is still there, print out 10 blank pages. If line is still there and has not faded, this is unusual and may need servicing. There may be a problem with the encoder strip (it's a clear plastic strip with black lines running the length of the printer slightly behind the head), Try cleaning it on both sides with a little windex on a q-tip. It's delicate so be careful.
If the line looks faded after printing 10 blank pages, some ink has dripped onto something that is contacting the paper. This could be a roller, the bottom of the head carriage or even a hair or piece if dust that is stuck in the machine or on the bottom of the head. In this case, I would recommend cleaning everything. Revove the head (tell the machine you're going to replace ink, and when it moves the head into the centre position unplug the power cord.
Remove the head and clean off any dust or hairs on the bottom. Run a Q-Tip along the bottom of the carriage assembly wherever you can. Clean any accessable rollers. If you can get at it, clean the wiper on the purge unit (the unit the head sits over when it is parked), as well as the seals.
Reinstall the head and ink, close the lid, power up and retry printing.
I hope this helps. If not, there could actually be a fault with the printhead or one of the circuit boards
Dec 28, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Wide black line down middle of paper
I have same problem, with new ink cartridge, also tried cleaning the print head, no luck.
Oct 20, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Dirty print
Hi , clean the absorbent below ,open or any hole can the injection can reach to the use ink basin located in the floor of printer.suck all ink with injection and fill in a clean container.
clean the rubber roller and carriage with the obsorbent cotton or clothe.
Oct 15, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
HP PSC 1210 All-In-One InkJet Printer Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
