Question about Coby MP-C582 MP3 Player
Mp3 battery my mp3 won't charge or turn but when press the power button you heard this sizzling noise coming from the speaker whats the problesm
    Problem Solver:
  • 6 Answers
You either have a bad battery, or there's a bad connection on the chip inside it. It's most likely not worth fixing due to the price it would cost to have an electronics shop fix it. Sorry.
Posted on Feb 28, 2008
I perchased my rca mp3 player last month and loaded my music onto the device and now it wont turn on ,I just took it out of the package and charged it per the instructions and loaded my songs onto it but...
remove the battery from the unit then press and hold the power on button for atleast 1 minute this should reset the system then return the battery then charge the battery for atleast 2 hours just to ensure your battery is full charge..the turn the power again.The player should be ok now..
Aug 29, 2011 | Car Audio & Video
It froze up
Make sure the player is fully charged.
  • 1. Connect the player to your computer.
  • 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode,
  • 1. Turn device OFF.
  • 2. Slide the Hold switch down to Lock (orange color showing).
  • 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged
  • 1. Leave the player connected for approximately 2 hours to charge.
  • 2. Disconnect the player from the PC.
  • 3. Verify if you can turn on the player.
  • 4. Reset the player if necessary. To reset the player:
  • 1. Press and hold the Power/Menu button for approximately 20 seconds.
  • 2. Release the Power/Menu button.
  • 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Or try and see if it will come on with out the battery but hooked to your computer.
Feb 02, 2010 | SanDisk Sansa e260 MP3 Player
Mp3 player froze when plugged into pc. screen is blank but lit. is charged. what do i do?
If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery but hooked to your computer.
Feb 02, 2010 | SanDisk Sansa e250 MP3 Player
My mp3 player doesn't turn on even if I charge it. Do you think I need a new battery?
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, to switch the player to MSC mode
1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Skip this step if you think it is charged. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary. To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa m230 MP3 Player
My mp3 dosent want to turn on and its charged
First try and reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Jan 30, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
My sandisk sansa clip 1gb wont turn on
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
Mp3 was dropped in water and doesn't work anymore
Well the only real thing you can do is to dry it out until no water is left in it and it might work..Usually when these things see water and there on it fries them..but sometimes when they are exposed to water and they are turned of and wait for water to dry they will work again,,Thats not a good sign when you said you heard it sizzle..Thats it shorting out the main board..You might be replacing if when the water dries it doesnt come on thats what happen.Sorry Have A Great Day
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Apr 05, 2009 | RCA opal MP3 Player
Fully charge sony walkman NWZ-E436F does not turn on power at all
well u might have gone wrong u should charge ur walkman for abt 3 hrs first use untill full appears and it is recommended that even if u dont plan to use u r walkman u should atlest charge the battery once a while for battery mentainance try to reset ur update the player firmware.or even then if it dont comes send it to sony or have a converstion with sony support
Jan 31, 2009 | Sony Walkman NWZ-S616F MP3 Player
Powers off at random, or won't turn on at all
hmmm..the sizzling may be some junk inside on the motherboard...you know how to open this paperweight up?
Mar 13, 2008 | IBM ThinkPad R31 2656 Notebook
Wont Turn On
I had the same problem with no power. Take out the 4 screws, take out the battery, clean your connections with an eraser, re-assemble it and it should work.
Aug 30, 2007 | SanDisk Sansa e200 MP3 Player
Coby MP-C582 MP3 Player Logo
54 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
