Motorola Mobility MOTO U9 Pink  Cellular Phone Logo
Posted on Dec 05, 2009
My U9 stopped making outgoing calls idk whats the prob?
Outgoing calls Problem
Transfer SIM to another working device to check if outgoing calls will work. If problem still persists, please contact us via hotline or visit the nearest Smart Store. If you cannot make outgoing calls while roaming abroad, click here by Camera Mobiles Camera Mobiles Tablets
My Nokia 701 cant make outgoing calls. Whenever I try to call someone it disconnects before it even rings and displays "No Answer"
If its a case where you can receive calls and texts, and send texts no prob but you cant call out then its a caller-id problem with your mobile service provider. Ring up the support team and have them reset your caller-id on their end. Once done, power cycle the phone and the phone shoild call outbound no problem.
We cannot dial out on our phone but we do receive incoming calls
what is the exact error message/prompt that you hear when you try to make outgoing calls?
if you are a prepaid user, make sure that you have enough balance
if not, make sure that the call barring feature on the phone is deactivated, to check go to the settings of your phone, call settings, then call barring and make sure that outgoing call barring deactivated.
turn off the phone, remove battery and sim then wait for a few seconds then turn the phone back on, see if you can already make outgoing calls
Apr 14, 2011 • Cell Phones
2helpful
My motorola i335 won't make outgoing calls but
It means you have barred you phone from making outgoing calls, all you need to do is to go to your
menu of your phone,scroll to settings,press and scroll down, you will see call barring, press it or open it, you will see different options there, press on outgoing calls to enable the barring on it.
After you have enable it, you will be able to make outgoing calls.
Take care.
1helpful
My p990i didnt work with outgoing sms. . nothing more help
hi
the solution is quite simple just reach yor service provider and request for the sms settings which you will get for free as an SMS
save the settings and you'll be able to send the SMS, same goes about MMS
cheers
pls rate the solution
Motorola U9 feedback interference
you may have to check your call settings because they might be set on divert all calls
Block outgoing calls
http://superphonestore.com/product_info.php?products_id=6495&language=en&cPath=8
This is bulky, but it will stop anybody from making an outgoing call unless they have a physical key.
Xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
