Question about Mitsubishi VS-6043 60" Rear Projection Television
60'' 11 year old Mitsubishi Projection TV
When i turn the TV on it stays on for two seconds then shuts down immediately after. I tried everything that i could think of to try and keep it on but it just fails. If there is any suggestions that you could give me to fix this problem that i have with my TV, it would be very appreciative of you. Thanks for your concern,
John
We just picked one up for free on the side of the road that did the exact same thing. It turned out being the power supply. We got it fixed at a local repair shop for $150.
Posted on Apr 02, 2008
So where is the relay switch?
Posted on Mar 28, 2008
HELLO THERE WE ARE HAVING THE EXACT SAME PROBLEM. TURNS OUT THAT IT IS THE RELAY SWITCH mY TV IS ALSO 11 YEARS OLD. HAD THE SAME PROBLEM 4 YEARS AGO
Posted on Jan 22, 2008
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
My 64 in mitsubishi tv (9 years old) turns off immediately why? I tried unplugging and it still just turns off
The TV either has a power supply fault or a fault that is shutting the Power supply down. So that there will;be no more damage or indeed a fire. You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Televison & Video
TV will not turn on
you either have leaky capacitors near the voltage regulators, cooling fluid leaking on the boards, and/or bad solder connections on the yoke plugs. this model is known for all 3 problems, but you probably need a qualified tv repairman to fix this right.
Sep 17, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Tv does not stay on
If you have a rear projection, it is the bulb. Ypou need to replace it.
Jul 24, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
When i power up the tv, it immediately shuts off
How old is the tv? Sounds like the bulb. Is there any kind of lamp light indicator blinking or on? Averager life of a bulb is a few years, but could very well be shortened. Also check any surge protectors you might have. Maybe you recently had a surge and it needs to be reset. Last but not least try recycling the power on the tv. Unplug for 10 seconds then plug back in. happens a lot with cable boxes, recievers, and tv's from time to time.
Mar 17, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
I just took my Mitsubishi WS-65315 65" in to be repaired for the same problem and was told that it needed a new main circuit board part number 930b899005 as was told they wanted to charge me $1100.00. So I told them not to do the repair and picked up my tv and found that same part at Sears parts for only $225.00. Some of these TV repair places are theifs.
May 10, 2007 | Mitsubishi WS-48315 48" Rear Projection...
Televison & Video Logo
194 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
