Question about Radio Shack Accurian APD-3955
Portable Accurian DVD player
5 month old player suddenly won't read disks, says "no disk", have cleaned with brush cleaner disk as recommended.
  • 3 more comments
  • cheechee Jan 19, 2008
    getting the same error as tawanda13. disc loads but player says no disc. it was working. never been dropped. is it possible that it needs to be cleaned?
  • tawanda13 Jan 19, 2008
    Have done that already, and it will still read cleaner disk and music CD's just not DVD
  • pcnlhammer Jun 28, 2008
    I'm having the same problem after a year of use. I've cleaned it. Tried running on battery power and on A/C. It just won't play.
    I'm very dissatisfied with this situation.
  • Anonymous Aug 01, 2008
    I having the same problem, it's less then a year old and I can't even clean it because it won't even read that, please help, I need contact information, so I can call the manufacture, I think under a year it's still covered. Someone please help!
  • egmcgrath8 Sep 05, 2008
    I am experiencing the same "No Disk" error. I have tried cleaning and "rebooting". Is there another solution?
This may sound overly simple but try disconnecting the power from the unit (i.e. unplug it from the wall), wait a few minutes and plug it back in, kinda like a hard re-boot.
Posted on Jan 17, 2008
Vizio vbr133 player . player starts to load disk and then reads no disk. tryed with different disk still reads no disk. error code HON7E
I was getting the same error and I could not get regular dvd or blu ray discs to play either. I dug out my old cd player lens cleaner and put it in and it started playing. I let it clean the lens for a couple minutes and now it is playing my movies again.
Jan 01, 2013 | Vizio VBR133 3D Blu-ray Disc Player
Problems reading dvds
Have you tried cleaning the lens of the portable player? You can purchase a DVD cleaning disc, this disc has microfiber brushes which clean the laser len assembly of the player as the disc spins.
Hope this helps
Jul 06, 2008 | Televison & Video
Tip
CD/DVD fix
If your CD or DVD player stops reading, insert a CD cleaner disk in the device & run it several times to clean the dirt off the optics. The CD cleaner disk has brushes on the data side of the disk which sweep the optics clean.
on Nov 30, 2010 | Computers & Internet
My portable dvd player will not read any dvds
  • I would give it a good cleaning with a disk player cleaning. Those disks have little bristles on them that "sweep" the lens and clean it real well. Remember that if the lens is so dirty that it won't play any DVD you may need to run that cleaner disk a few times to get the lens back to normal working condition.
  • A lens cleaner disk should be ran one time a week to avoid problems with playing disks be it CD or DVD or Computer.
  • Sometimes players go bad so keep in mind this could be the problem as well but I have had the DVD player in my garage get so dirty I had to clean it a few times to get it to work normal.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 11, 2011 | Sylvania SDVD8732 Player
Have the Samsung DVD-AR650. When I insert a blank
My last recommendation, before seeking a replace or repair; would be to run a cleaner disk. Optical drives can be affected by dust on the optical block lens or dust on the disk itself. Sometimes a dirty lens can even cause your drive to eject the disk when you try to read it. It is recommended you clean your lens every 3 months in an office environment, or once a month if you use the drive in an industrial environment. They range in price from $3 to as high as $130. In such an
Jan 01, 2010 | Samsung DVD-AR650
Trutech portable DVD player says 'no disc' all the time
You have problem with lease assembly. It may work if you clean it. You may use laser cleaner disk or take it apart and clean the lens with alcohol.
Jul 16, 2009 | TruTech LMD-5702RT Portable DVD Player
PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Feb 10, 2009 | Televison & Video
Dvd player
You need to Get a Disk Laser Eye Cleaner. It is like a DVD Or CD But it has Brushes on the Face that will Clean the Reading Lens. This should solve your Problem.
Jan 25, 2009 | Durabrand PDV-705 Portable DVD Player
I have a portable dvd player model number mdp1030 the unit keeps saying no disk I have tried numerous disks same results.
then i think the lens is not able to read the disk.
and so i would suggest you to buy a disk cleaner CD and run it in your DVD player and then use your regular disks.
if this is not working then it is some internal fault in your DVD players lens.
Aug 13, 2008 | Mintek Televison & Video
Accurian portable dvd won't read disk
if you here a clicking sound then you need to replace you ribbon wire. it is attached from a circuit board to its lens.
Jul 19, 2008 | Radio Shack Accurian APD-3955
Radio Shack Accurian APD-3955 Logo
451 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
