Question about Sony Handycam DCR-TRV18 Mini DV Digital Camcorder
Usb installation cannot install to my hard drive to transfer pics
  • Beverly Black
    Beverly Black Jan 17, 2008
    thanx very much ya time ;)
    President:
  • 4,402 Answers
· go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
· Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
Posted on Jan 17, 2008
I have a handycam (DCR-TRV18) BUT I lost my USB DRIVER CDROM. So I want to get the USB driver for connecting it to my PC. Thanks
Posted on May 12, 2009
Wd 1600 not working
Western Digital My Book hard drives use USB 3.0 and USB 2.0 speeds to transfer data from the hard drive to the computer and vice versa. When your My Book external hard drive is not performing properly or not turning on, you can troubleshoot the problem before sending the hard drive back to the manufacturer. Correctly powering up and installing the My Book are essential for transferring information and avoiding corruption.
Run your fingers up and down the power cable that connects to the back of the My Book hard drive and the wall outlet in your home. Feel for breaks or tears on the cable and replace the cable if needed. Check the pin on the back of the hard drive where the power cable meets the drive. Make sure the pin is straight and will make contact with the power cable properly. If the pin is bent, send the hard drive to Western Digital for repair. Plug a different device into the power outlet you are using to make sure it works properly. Use a device that you know powers on correctly. b> Slow Transfer Rates b> Open your computer's tower and check over the PCI adapter card that gives you the ability to achieve USB 3.0 speeds. Make sure that the adapter card is installed correctly per your manufacturer's installation manual. If the PCI adapter card is not installed correctly, you will not be able to transfer data in the 3.0 speed. Disconnect any other external hard drives connected to the system. When two hard drives are connected via USB, they share the transfer rate bandwidth and slow your transfer speeds down. Run a Windows Update to change the USB driver on your computer. Click "Start" then "All Programs" and then "Windows Update." Run the update and choose your correct USB 3.0 driver from the list. Click "Install" at the bottom to install the driver. Hope this helps.
Jan 05, 2013 | Western Digital My Book Essential Edition...
Please help me with this
USB 3 has the fastest data transfer speed through a computer with USB 3 port. If your computer does not support USB 3 then it cannot transfer data at USB 3 speeds.
If you install a hard drive into an USB 3 hard drive adapter case and the data transfer speed would depend how fast a hard drive you install in this USB 3 adapter case.
A SATA hard drive is faster than an IDE/PATA hard drive. Make sure you get the correct USB hard drive adapter case with the SATA or IDE/PATA connector that matches the hard drive.
Nov 03, 2012 | Computers & Internet
Hi there. When talking about USB 3.0. Can say say that there is a USB 3.0 hard drive? Or can I say that if I have an external USB 3.0 hard drive case and place a hard drive in it it would have the USB
I have a Sony VAIO GRZ610, old i know. Won't power up,
If you cannot get the laptop working then try this method.
Remove the hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this as an USB mass storage device (external hard drive) and you can open the various folders and files, then you can backup and or transfer your data to another computer. If yiu install the hard drive in an USB hard drive case then you can use this hard drive as an external USB hard drive.
Aug 29, 2012 | Sony VAIO GRZ610 Notebook
Installing a program on desktop from notebook which has no disc drive.
If u hv a USB capablity then copy to usb and transfer using that. Otherwise if u hv a "cloud/web" account like Google then try transferring thru that by saving into the web and downloading from there. Blutooth transfer could also work. cheers
Aug 04, 2012 | ClickFree 500GB Clickfree C2 Portable...
Iintend to change my sata hard drive to a SSD hard drive.How do I format before change
When you install Windows on your new SSD hard drive you can then transfer data from your old hard drive using an USB hard drive adapter or install the old hard drive into an USB hard drive adapter case and use it as an USB external hard drive after you have transferred your data to your laptop.
When you connect the USB hard drive adapter to the laptop, the laptop will see it as an external storage device, you can then open the various folders anf files and copy them to your new hard disk.
Apr 07, 2012 | Dell Computers & Internet
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Does anyone know how to transfer pictures from the camera to a memory card? I thought my card was in there when I took the picture, but it wasn't.
most all cameras cannot move pics from internal memory to memory card. You first have to save them to your hard drive with a usb connection. Then you can move the pics to the memory card if you have a card reader. Or... replug the camera into usb after installing the memory card. Then you can move the pics to the memory card. Note: if trying the later you have to name the pics following the same naming convention as the pics already on your memory card. otherwise, they will not show up or will replace those that already exist on the card.
Aug 09, 2010 | VistaQuest VQ-5115 Digital Camera
Hangs on large installations or data transfer
THat means that there is something wrong with the drive already. I can transfer up to 100 Gig of a single file to large USB drives so generally transferring is not a problem. Try formatting the drive then transfer again. Or your USB port on your computer is only a USB 1.1 and not USB 2.0
Feb 07, 2009 | SimpleTech 320GB SimpleDrive External by...
Re: flash drive
First thing to do is to connect the flash drive to your computer via USb port, then if the flash drive is already detected and computer is done installing the driver for it, Just double click Mycomputer icon then you should see there the flash drive, double click on the flash drive then after that you can just copy the pics from your computer and paste it to the flash drive...
Note if the falsh drive is not detected by the computer try to connect it on a different USb port and hopefully it will be detected that time...
Hope that helps..........
Sep 21, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sony Handycam DCR-TRV18 Mini DV Digital Camcorder Logo
227 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
