Back to:
Tags:
Copiers
Generic problem for all Copiers
Sharp ar 205 copiers (by 2 users)
posted by tiggerll on Jan 17, 2008
We have been having an issue with our copy machine. We have had service people out to try to fix it but no help. The toner light stays on and nobody can get it to reset. Can you help us?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 11, 2008
how to reset the ic?
Solution #1
posted on Jan 17, 2008
Not Rated (0)
courtdate
Rank:Guru Guru
Rating: 85%, 621 votes
REPLACE THE FAUTY TONER SENSOR
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on sharp ar 205 copiers:
I don't want to Accept this solution
Can you Help with these Copiers problems?
Ricoh Aficio MP1600SPF Grayscale Copier
My copier modle mp5500 functional problem is very hadrd....
Canon imageRUNNER 8500 Grayscale Copier
my copier not working only display the download mode....
Canon imageRUNNER 400S Copier
in lcd monitor its coming- main switch off and on error...
Kyocera KM-1505 Grayscale Copier
Hi - we keep getting a J 30 error message flashing on the...
Toshiba 1360 Black and White Copier
______ . . . . . . . . I have a Toshiba 1360 copier. The...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
